Meters for monitoring battery input - solar panel output etc
Results 1 to 20 of 37
    Mar 2011
    Walker Bay
    Thanked: 268
    Default Meters for monitoring battery input - solar panel output etc
    Any suggestions for digital meters to monitor various key areas of the charging set-up in our 4x4's.
    I have a simple National Lunar "meter" but am looking for something more comprehensive - reasonably priced - and which is easy to install without large shunts etc.
    Paul
  2. The Following User Says Thank You to Paul Dold For This Useful Post:
    Thanked: 392
    Default Re: Meters for monitoring battery input - solar panel output etc
    4x4 Direct.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Experience is something you don't get until just after you need it.
    Thanked: 392
    Nico Swart
    ZS6NJS
    Mar 2011
    Walker Bay
    Thanked: 268
    Many thanks but there is a post suggesting their meters may require large bulky shunts and maybe are not the easiest to install?
    See Subok's post: http://www.4x4community.co.za/forum/...ing?p=3433047&
    I am wondering what is new on the market.....
    4x4 Direct.
    Paul
    Thanked: 392
    I bought one of their amp/volt meters specifically because of the fact that it has a built in internal shunt. Only three wires to connect.
    Fitting mine this weekend.
    I also do not want large bulky external shunts.
    Nico Swart
    ZS6NJS
    Mar 2011
    Walker Bay
    Thanked: 268
    I see 4x4 Direct also has these:
    http://www.4x4direct.co.za/battery-a...y-monitor.html
    and found these as well:
    http://www.4x4direct.co.za/558-meters
    Paul
  8. The Following User Says Thank You to Paul Dold For This Useful Post:
    Thanked: 392
    Too fancy for my liking. I hate to toggle between functions/screens and there is more that could go wrong.
    This is all I require.
    For a more or less accurate reading, it does mean that I have to disconnect all loads from the battery for about 15min, but I'm fine with this.
    The fridge compressor shuts down longer than this in any event on a normal temperature day.
    Nico Swart
    ZS6NJS
    Mar 2011
    Walker Bay
    Thanked: 268
    Thanks - which model did you buy?
    Paul
    Thanked: 392
    Can't remember any model no.
    But I got this one. Round one is easier to install. (cutting holes)
    Nico Swart
    ZS6NJS
    Hillcrest, Malaysia
    Thanked: 2640
    Without shunts you cant monitor current. Without current you may just as well stick to the NL meter.
    At the relatively small currents we are talking here you do get Meters with a built in shunt. Would be best to get two so you can monitor battery charge/discharge current and load current independently.
    ZS5KAD Yeasu Ft-897D
    2 V8's a V6 and an inline 4
    The nice thing about going the extra mile - the road is never congested.
  13. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  14. #11
    Witbank
    Thanked: 55
    I have a big liking for the Victron BMV601 meters. It has a shunt but its easy to mount the actual display far from the battery and shunt. So space and install not to tricky.
    Gerhard
    Jeep Grand Cherokee WK2
    Audi Q3 2.0 diesel (SWAMBO)
    Suzuki Alto 1 Liter 3 cylinder thing to get me to work
    And a Summit Everest trailer that SWAMBO loves.
  15. #12
    Hillcrest, Malaysia
    Thanked: 2640
    Quote Originally Posted by WillysCJ View Post
    Paul said reasonably priced. I also like the Victron meter, but it is normally seriously overkill for a camping dual battery installation. Intended more for yachts and off grid cottages etc.
  16. #13
    Witbank
    Thanked: 55
    Ha ha.
    Guess it depends on the definition.
    You spend R2500 on a battery. R2000 on a charger and R4000 on some solar panels.
    Then adding R2000 for a propper meter that allows you to really camp with the knowledge that your meat will stay frozen for the duration of the trip and the time left on your battery before it dies/forced to take a long drive.
    I was just suprised no one even mentioned them. I have one in my trailer and one in the Jeep system and I cannot imagine going without them anymore. They are my only point of reference on my marginal systems. Otherwise I had to spend quite a bit more money just to be safe.
    Gerhard
  17. #14
    Mar 2011
    Walker Bay
    Thanked: 268
    Anything Victron is excellent but expensive!
    Paul
  18. #15
    Jun 2015
    Look at Geek, i got my one thear
  19. #16
    Jun 2015
  20. #17
    Jun 2015
    Quote Originally Posted by calitzfamily View Post
    I've never had a problem perching from geek, just taks time
  21. #18
    Thanked: 75
    Paul
    have you looked at Watt meters, I used these before switching over to Gerhard's DIY Batt monitor, same price as two W meters though
    http://www.elexco.co.za/index.php?ro...product_id=442
    Easy to install too.
  22. The Following User Says Thank You to DirtBasher For This Useful Post:
  23. #19
    Mar 2011
    Walker Bay
    Thanked: 268
    As a matter of interest what are the advantages of Gerhard's DIY Batt monitor over the Watt energy meters?
    Any tips on connecting-mounting the Watt energy meters - I am using the
    Ctek D250S DC-DC system with solar panels and lead crystal battery. Presume one for solar panel input and a second for the battery.
    Quote Originally Posted by DirtBasher View Post
    Paul
    Paul
  24. #20
    Witbank
    Thanked: 55
    Paul. The DIY meter is not for everyone. Its diy first of all and its not comercially packed and so on.
    The difference however is it does counting. It does not just give a view of whats happening now. It tells you what you put into the battery and what you took out the battery over the total charge. So you will at all time get a view of how many AmpHours is left in your battery and the est time before its flat.
    So it tells you amps and watts. But also does a sumation of Amphours removed and amphours replaced and whats left.
    Its similiar to the Victron data.
    Gerhard
  25. The Following 2 Users Say Thank You to WillysCJ For This Useful Post:
