This is a very nifty little tool Gerhard! The forum logo is a nice touch! Maybe sell the rights to DirkAre you going to leave the path as 4ePajero
I have completed the little utility.
The utility has an Input area and an Output area.
The coords are pasted / typed into the Input area (in any of the popular formats) and it will then be translated to all the popular formats.
You can Input either one point at a time, or a pair of coords.
Please download the utility from this URL (all older versions removed):
http://www.mediafire.com/?m2imymojyuo
Carpe Diem Scrotum
Cape Town Weather and Imagery
Gerhard
Can I just suggest one more input format?
33° 49' 3.69" S 18° 29' 26.77" E (Southing and Easting at the end)
This is the default GE format.
Carpe Diem Scrotum
It already does (as input)
Would you require the E & S at the end of the coords in the output?
Gerhard
Unless I did something wrong, it didn't work with it at the end (of the input) and wasn't part of the "templates" you have
Carpe Diem Scrotum
Remember to choose the "Two points" option.
(I added the option to add S & E to output)
I pasted your example to it, and chose to add the 'S' & 'E' at the end:
OK cool.. can you send me your latest version please?
Carpe Diem Scrotum
What's the difference between the two versions?
Carpe Diem Scrotum
Carpe Diem Scrotum
Latest version here.
(Recognises more characters for minutes and seconds).
Link in post #13 fixed.
Thanx 4ePajero, this is great!!!
Somehow if you convert two Coordinates, the DDD MM.mmm Coordinate calculates the wrond point on POINT#2 and BOTH and you end up with a different location. As seen in the screenshot, the input is in DDD MM.mmm format but the DDD MM.mmm output is different
Then futher if I can make a suggestion, Is it possible to have an option to replace the S or W with a negative sign (-) example -25.258 27.569
Other than that, this is a great application!!
Help Please.
When I enter S26 02 17.2 E28 24 00.4 into the converter input I get S26 2.2867 E28 24.2867
If I do the two points singly:
For S26 02 17.2 I get 26 2.2867
For E28 24 00.4 I get 28 24.0067 - not the same as when a two point coversion is done.
Am I doing something wrong?
File fixed...
Not I do not maintain this application. I am posting on behalf of 4ePajero
Carpe Diem Scrotum
Thanks.
Where do I get the latest file?
