Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers - Page 9
Page 9 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 161 to 180 of 334
  1. #161
    Klerksdorp
    Thanked: 129
    Quote Originally Posted by Adam Stander View Post
    Hi FD, sent my parcel to you today.
    I'll send you a pm with the tracking nr as well.
    Adam, we sent your BX-2 back via Courier this afternoon - should be with you tomorrow. It's working A-OK!
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  2. #162
    Thanked: 34
    Quote Originally Posted by Family_Dog View Post
    -F_D
    Now how's that for service!
    And I didn't even buy my product from you guys.
    Thank you very much Eric, you guys rock.
  3. #163
    Blouberg
    Thanks FD. Delivered. Will pick it up later from the office.
    Brilliant and quick service.
  4. #164
    Thanked: 34
    Thank you very much Eric, just received my parcel.
    Much appreciated. You guys customer service is exceptional.
    And to top it all, they didn't even charge me for the work done!
    Can you tell me what was wrong with the charger?
    Okay, now to getting the charger back on duty:
    My daughters car has been standing for a while with a very flat battery. Dash lights don't even show.
    Thought I'd put the charger on and see what it does. At first nothing.
    Then tried the mode button to see if I can get it to something else, still nothing.
    Kept it in for second and skipped to 13.6V supply, but then goes back to orange led on mode and nothing else.
    Then moved Benton over to my new LC90ah and voila, picks up the battery, all the buttons and the steps work perfectly.
    Try jump starting the flat battery with proper cables. Nothing! 1st time this happens!
    Left the Prado to idle while jumpers connected for about 10 minutes, try again, flat car starts. Okay, getting somewhere...
    Left flat cart to idle for 20 min and put it off.
    Connect Benton: Picks up battery and all steps and buttons work! Moved it to the 12v snowflake.
    Will now leave it on the car and see what happens. Hopefully this battery can be saved.
    Unfortunately I can't seem to find the user manual for the charger so I just mucking about actually.
    Tried the internet but seem to get a broshure only. It does give lots of info though.
    >If battery is below 8v Benton won't start as safety..... should have read that part before connecting
    Seems I should rather disconnect battery and try the 16V option?
    Anybody have the BX2 manual electronically, or a link to the manual?
  5. #165
    Klerksdorp
    Thanked: 129
    Adam,
    Here are some abbreviated instructions for operating the Mode button:
    Benton BX-2 Mode-Button Operation
    With no battery connected:
    Hold the Mode button in for 3 seconds. The charger should switch over to the 13.8v Power Supply mode.
    With battery connected:
    Hold the Mode button in again, then rapidly depress it once - it should also go to 13.8v mode. Pressing it again (quickly) changes to the other modes.
    If your battery is totally flat, the charger will not operate, then you need to select the 16v 'Boost' mode.
    Here is a PDF file of something that we typed up some time ago, from the minute ant-sized fonts as used in the user manual
    -F_D
    White Fang:
  6. #166
    Thanked: 34
    Thank you Eric
    I placed the battery on the 16v Boost last night and will leave it on the charger for the whole weekend to see if it can be saved.
    The charger and all its functions seem to work perfectly and that makes me very happy.
    Attached is a document I downloaded from another site which has similar info you have in your document and some more.
    I'm sure you'd be able to use it as well.
    Not a manual, but comprehensive datasheet. (Was 6Mb, this is the smallest I can get it)
    Benton BX-2 charger.pdf
  7. #167
    Blouberg
    Quick question....want to charge my deep cycle in my car a bit to get it back to 100%
    Do i need to disconnect it or just make sure the car is switched off?
    There is already some of those connectors connected on the battery so assume the previous owner also had a Benton
    Sent from my GT-N5100 using Tapatalk
  8. #168
    Klerksdorp
    Thanked: 129
    Just switch the car off and connect. Please just check that the old connector contacts are not corroded through in any way, or you will have problems.
    -F_D
    White Fang:
  9. #169
    Blouberg
    Thanks.
    Saw now the connectors is CTek so different.
    One more question, was told that the National Luna intelligent Solenoid will never fully charge your battery...
    The reading on the fully charged battery is 12.67 and the one charged by the Solenoid is 12.56...
    So not much of a difference?
    Are the CTek people talking crap?
    Will charge the battery and see what the voltage is after words.
  10. #170
    Klerksdorp
    Thanked: 129
    I've never worked on an NL system but as far as I understand it is just a solenoid connecting the battery, with nothing else. I would go with the C-Tek guys here, you want as little added wiring between the BX-2 (or C-Tek) and battery as possible. Connect the charger to the one battery only, never two in parallel, it fuzzes the charger intelligence otherwise.
    -F_D
    White Fang:
  11. #171
    JHB
    Default Great Service
    So I sent my 1 faulty charger off to F_D, He received it & the next day it was booked for service, and now its already been collected by the Courier company for Delivery!!!
    Excellent Service. Will definitely recommend F_D for chargers
  12. #172
    Klerksdorp
    Thanked: 129
    Actually, we took one day longer for the repair as Junior was out of office for a day - true story! Thanks Andrew, hope it serves you well.
    -F_D
    White Fang:
  13. #173
    FD please PM me a quote for the BX2 and BX5 chargers.
  14. #174
    Klerksdorp
    Thanked: 129
    Email winging its way to you...
    -F_D
    White Fang:
  15. #175
    Thanked: 67
    I know this is an old thread, but one Q. Do you get a Benton that can operate as a Dc to Dc and as a Ac to Dc?
  16. #176
    Klerksdorp
    Thanked: 129
    Not yet I'm afraid. Hopefully they should be working on designing one.
    -F_D
    White Fang:
  17. #177
    Thanked: 67
    tx
  18. #178
    Jun 2013
    Thanked: 72
    Hi Eric,
    I have an AGM battery (95Ah) in my car as a second battery, and a deep cycle (102Ah) that I am looking for a charger for. Which Benton would be best suited, and what is the price at the moment? Im in Pretoria...
    Thanks!
  19. #179
    Mar 2013
    Secunda
    Quote Originally Posted by TheWall View Post
    Ok, decided on the BX-2.
    If it can charge the 7ah batteries it is a bonus...
    Hi The Wall
    Have you tried charging the alarm batteries with the BX-2?
  20. #180
    Klerksdorp
    Thanked: 129
    Quote Originally Posted by PajeroMan3500 View Post
    Hi Eric,
    Thanks!
    Pajeroman, a BX-1 Pro for EACH battery would be fine, or even shared between the two batteries but still charging them individually, but if you do this you might consider instead a BX-2 for a faster charge. PM your email address to me for more details.
    -F_D
    White Fang:
  1. Benton BX-1 Battery Chargers
    By JDeV in forum Camping, Fridges, Accessories
    Last Post: 2015/02/12, 06:05 PM
  2. Differences between a normal lead-acid car battery and a deep cycle battery.
    By Eggie in forum Vehicle & Technical Chat - General
    Last Post: 2012/01/25, 08:50 AM
  3. Battery chargers
    By Paul Dold in forum Camping, Fridges, Accessories
    Last Post: 2011/11/22, 05:14 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Automatic switch over system between battery charger and solar panels.
    Last Post: 2009/10/08, 03:32 PM
