Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers - Page 8
Page 8 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 141 to 160 of 334
  1. #141
    Thanked: 37
    Thank you very much FD.
    I will do that.
    You're help is much appreciated.
  2. #142
    Feb 2013
    Thanked: 36
    Just want to thank FD for the great and fast service. Ordered a BX2 charger Tuesday afternoon or more like early evening, only paid the money around 6 PM. Courier rocked up early this morning with my package.
    Thank you Eric, only problem I have now is that all batteries are full so have to drain the deep cycle a bit to properly try out the charger.
    P.S Eggie said the BX2 should be able to charge a 7.2 Ah lead crystal battery no problem because it can take a fast charge, but he won't recommend trying to charge any other type 7.2 Ah battery because it will almost certainly be damaged.
  3. #143
    Klerksdorp
    Thanked: 157
    Pleasure! Glad it was delivered so promptly - I always get nervous when sending parcels this time of the year.
    Keep an eye on the 7A batteries and let us know what happened - the battery should draw what it needs from the charger, the charger will never "force" amps into the battery so theoretically there should not really be a problem.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  4. #144
    Thanked: 76
    Quote Originally Posted by Family_Dog View Post
    Adam, the unit is not normally meant to be serviced, although we have done this because of a Mode switch problem. (The contacts are covered with some anti-corrosion stuff which could prevent correct operation, we used to spray them with a good Contact Cleaner (Kontakt60) but we have since obtained switches so we now replace them).
    We made our own triangular tool to open the charger from a Philips screwdriver as a donor.
    Now it might be a pica-fuse (small little fuse mounted directly on the PCB - can't remember the value) but it could also be a SCR.
    You're welcome to send it to us after January 14th when we reopen and we'll take a look at it.
    -F_D
    Just done this with mine, after no luck with the selection switch, I squirted electronic lubricant in the switch, fiddled with it a bit and then it was working beautifully again , I replaced the funny screws with normal star headed screws.
  5. #145
    Thanked: 37
    Dirtbasher, I hope it's such a small fault only, but hearing things like "pica- fuse on PCB or SCR" and taking my electronics experience into considiration I should perhaps leave it for the big dogs.
  6. #146
    Thanked: 76
    Quote Originally Posted by Adam Stander View Post
    Its a common micro switch problem , this one however is a non standard micro switch, other wise i would have replaced it with a superior quality switch.
    It's a cheap charger that most people would have chucked in the bin , at least I've done my duty recycling it be useful again , when I find a replacement switch I will modify the unit so it NEVER give me issues again.
  7. #147
    May 2013
    Bothaville
    FD
    I have a BX2 bought about 4 years ago if I remember correctly.
    Not done through you though.
    The mode button has given me problems nearly from the start (should have sorted it then but didn't) in that it doesn't move from one function to the other with every click.
    More like every 4th or 5th click.
    Not such a big problem as it was actually only used now and again to charge a battery and the functions a nice to have.
    But, now it's stopped working completely. The power light is on, but connected to a battery it does nothing at all.
    I thought about opening the unit to check for a blown fuse perhaps, but it has some odd screw heads that seems do not want opening.
    Any idea of where I can look for the fault? Fuse perhaps?
    Where can I have it looked at? Serviced?
    My BX2 has a similar problem. Only the yellow light remains on, and it never moves to any other settings when pressing the mode button. When I keep the mode button depressed it moves over to the "power supply" setting.
  8. #148
    Klerksdorp
    Thanked: 157
    In practically all these cases, the fault lies with the Mode button. It seems as though the contacts were sprayed with some anti-corrosion gunk which sometimes causes problems through intermittent connection. We have pointed this out to Benton and we have spare contacts in stock, we simply replace them.
    Alternatively, if you get a purpose-made contact cleaner (Servisol or Kontakt 60), you can do this yourself. Open the charger carefully (obviously disconnected from the mains - leave it disconnected for a while before opening), apply a liberal spray of CC and then carefully reassemble. The tool for opening the charger is home-made.
    -F_D
    White Fang:
  9. #149
    Thanked: 66
    In layman terms what is the difference between the old BX-1 and the BX-1 (Pro) ?
  10. #150
    Thanked: 37
    -F_D
    FD how would you like me to send it to you?
    Nobody in Pta I presume?
  11. #151
    BX-1 and BX-2 working great no complaints TX. FD.
    Another battery to recover tonight for a lil Honda thats been standing...
    Supply mode and wait let it do its thing !
    2005 Ford Ranger SuperCab XLT 4000V6 Manual 5 Speed 4x4
    Petri
    1997 Ford Explorer XLT 4.0 L SOHC V6 Auto AWD 4x4
    Pieter
    2013 Audi Q5 2.0 TDi S-Tronic Quattro
    Daily Drive
  12. #152
    Klerksdorp
    Thanked: 157
    Adam, if by Courier:
    REPCOM
    19 Knowles St
    Wilkoppies
    Klerksdorp
    2571
    Or if by post:
    REPCOM
    PO Box 6118
    Flamwood
    2572
    -F_D
    White Fang:
  13. #153
    May 2013
    Bothaville
    -F_D
    Thank you very much for the feedback. Would it be possible for me to bring the charger to you some time?
  14. #154
    Klerksdorp
    Thanked: 157
    Christo, no problem. We re-open on Tuesday but we are in the Klerksdorp phone book.
    -F_D
    White Fang:
  15. #155
    May 2013
    Bothaville
    Thanks I appreciate it.
  16. #156
    Thanked: 37
    Hi FD, sent my parcel to you today.
    I'll send you a pm with the tracking nr as well.
  17. #157
    Klerksdorp
    Thanked: 157
    Smart, will let you know what we find.
    -F_D
    White Fang:
  18. #158
    Blouberg
    Hi,
    Has anyone tried charging the alarm batteries with the BX-2 yet?
    Want the BX-2 but also need to charge alarm batteries...
    So need to keep 105ah deep cycle charged (Spare battery) Would like to keep this one connected to be fully charged if there is power failures.
    Need to charge the 105ah deep cycle in the car before trips.
  19. #159
    Rayton
    Hallo Family dog kan jy asb vir my jou tel no pm het vrae oor battery laaiers dankie
    Nissan Navara V9X 3.0 V6 DCi 4X4
    De Cat
    Upgraded front Brake Disc and Pads
    Braided brake hoses.
    Cooper ST MAXX 265-70-17
    75 mm AA Lift Kit
    Campmaster 4X4 Trailer
  20. #160
    Blouberg
    Ok, decided on the BX-2.
    If it can charge the 7ah batteries it is a bonus...
  1. Benton BX-1 Battery Chargers
    By JDeV in forum Camping, Fridges, Accessories
    Last Post: 2015/02/12, 06:05 PM
  2. Differences between a normal lead-acid car battery and a deep cycle battery.
    By Eggie in forum Vehicle & Technical Chat - General
    Last Post: 2012/01/25, 08:50 AM
  3. Battery chargers
    By Paul Dold in forum Camping, Fridges, Accessories
    Last Post: 2011/11/22, 05:14 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Automatic switch over system between battery charger and solar panels.
    Last Post: 2009/10/08, 03:32 PM
