Benton BX-1(M), BX-2, BX-4, BX-5 Multi-Stage Automatic Battery Chargers - Page 5
Page 5 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 81 to 100 of 334
  1. #81
    Klerksdorp
    Thanked: 155
    Franz, provided it was not damaged through abuse, we would have replaced it within the first year. This is a Repcom Warranty, not from our suppliers.
    Speaking of abuse, I "forgot" I had connected a charger to PraDog and simply drove away. I stopped twice to investigate the strange noise I heard before I realised I was dragging the BX-2 charger along with me... Half a block and no further signs of "abuse" . In this case the Quick-Release connector could not release as it was inside the bonnet, the leads were too short for the connector to reach outside the bonnet.
    That charger still works to this day.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  2. #82
    May 2010
    Bergbron, Roodepoort
    Thanked: 160
    Looks like I got a dud
    Franz
    Land Rover Discovery II V8 slow & thirsty
    Venter Bush Baby with a few extras
    Chev Utility Club 1.8 the workhorse
  3. #83
    Thanked: 23
    What is your charger doing Flagster?
    2013 Amarok d/c TDI 103kw 4motion
    stuff I have in the classifieds | the story of my dad
  4. #84
    Krugersdorp
    I've got a 60 ah battery that is flat. More or less, how long will my Benton BX1 take to recharge it? It has been charging for 24 hours.
    2000 Toyota Hilux 2700i Raider DC 4x4 - OME, dual battery, Front Runner RR
    2006 Toyota Yaris Sedan
  5. #85
    Thanked: 7
    Don't want to speak out of turn Erik, but a Benton will not resurrect a completely flat battery. If the Benton doesn't see around 7V it will not charge it. If the battery is giving more than 7V then it shouldn't take more than a 6 or so hours.
    Gavin
  6. #86
    Thanked: 11
    My BX-1 has just stpeed working! No LED showing that it's on, no power coming out.
    Where can I take it on the East Rand?
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
  7. #87
    Krugersdorp
    Quote Originally Posted by gavpike View Post
    I haven't measured the battery.
    I see the user manual mentions that it must be >7.5 V. Funny that it shows it is charging.
    I suppose I could jump start it and then let the vehicle run a while and then put it on back the charger once the voltage is high enough. Don't know much about this...
  8. #88
    Klerksdorp
    Thanked: 155
    Refer the attachment below for charging info.
    If the battery is completely dead, you need to give it a bit of a kick by using a normal battery charger for a few minutes, simply to give the battery some residual voltage and then the BX-1 can take over.
    Benton charger failure:
    We have had some reports of chargers failing after they have been connected to normal MSW Inverters. The Chargers, as with many other electronic products, are simply not made to run off the square-wave shaped output of a cheap inverter. This is detrimental to operation of any sensitive electronic device and the Benton should not be connected to such an inverter. It is designed for a 220v AC Mains supply only.
    -F_D
    White Fang:
  9. #89
    Krugersdorp
    Aha, so we learn - I should read the manual properly. Thansk for the replies.
  10. #90
    Klerksdorp
    Thanked: 155
    Introducing two new items from Benton:
    BX-4 INTELLIGENT MOTOR BIKE CHARGER
    The BX-4 is a fully automatic 3-Stage battery charger suitable for ewither 6v or 12v Motor Cycle batteries (Manual select). Battery Capacities from 1.2 to 20Ah are catered for, 6v or 12v.
    The three stages are:
    1. Diagnosis & Bulk Charge:
    Here the charger senses the state of charge of the battery and commences the Charge cycle, terminating when the battery voltage reaches 7.2v (for 6v battery) or 14.4v (for 12v battery).
    2. Trickle Charge:
    This allows periodic cycling of the Charge to prevent over-charging the batteries. Should the battery voltage fall below 6.5v (6v battery) or 13v (12v battery), then the Charger will switch to Maintenance Mode.
    3. Maintenance Charge:
    Should the battery reach the voltage levels in Step 2 above, then Maintenance Charge mode commences, charging the battery at a constant 750mA. Once a fully-charged state is achieved, the Charger reverts to the Trickle Charge rate as in point 2 above.
    -F_D
    White Fang:
  11. #91
    Howick
    Thanked: 78
    Quote Originally Posted by Family_Dog View Post
    -F_D
    How do I tell what wave shape my inverter is putting out?
    Steve
    Jetta 2.0 TDI 2012
    Pajero 3.2 SWB 2009
    Jurgens Xcape
    Discovery II TD5 2004 (Sold)
  12. #92
    Klerksdorp
    Thanked: 155
    And for those of you who like brute force...
    BENTON BX-5 9-STEP AUTOMATIC INTELLIGENT BATTERY CHARGER
    The BX-5 is a fully Automatic Battery Charger capable of charging either 12v or 24v batteries through a 9-step process:
    *1 Diagnosis & Recovery:
    The Charger automatically senses they type of battery and whether it is a 12v or 24v one.
    *2 Bulk Charge
    80% of the energy is returned in this charging phase through a High-Charge Rate (25A) before reverting to a Medium Charge rate of 12.5A for a 12v Battery. For a 24v battery, half the above charge rates apply.
    For a Lead Calcium Battery, the charge rate is maintained at 5A until the voltage reaches 14.7v.
    *3 Absorption:
    The Charger now applies a constant low-charge rate of 1.5A to the battery in order to prevent damage to the battery from a constant high rate of charge. During this phase, a charge of close to 100% is obtained. The Charger will switch to the Trickle Charge Mode when it senses that the battery is fully charged.
    *4 Analysis:
    After the Absorption phase, the charger senses the battery bconditrion for five minutes. Should the battery voltage fall to below 12.3v for a 12v battery (or 24.6v for a 24v battery), it indicates that the battery is not retyaining its charge and the battery is faulty.
    *5 Trickle Charge
    The battery is now fully charged and ready for use. The charger will now supply a charge rate of less than 1A to the battery in order to compensate for any drainage due to tracking devices, alarms etc which may be connected to the battery. Should the battery voltage fall below a pre-determined level, the Charger will switch to Maintenance Mode.
    *6 Maintenance mode:
    If the Charger senses that the battery voltage has dropped below 12.8v (for a 12v battery), it commences a pulsed 1.5A charge until the battery reaches 12.8v, when the Maintenance Charge is then stopped.
    This cycle of Trickle Charging and Maintenance Charging is continued indefinitely, thus keeping the battery in a full state of readiness while it is not in use.
    *7 Boost:
    The purpose of the Boost Mode is to recover a severely discharged battery. The Boost Mode also breaks down Lead Sulphate crystals within the battery cells into active electrolyte again, thereby extending battery life.
    The Boost Mode (16v @ 1.5A for 12v battery, 32v @ 1.5A for 24v battery) is active for 4 hours on a 12v battery and 2 hours on a 24v battery. Upon completion of the Boost charge, the BX-5 reverts to normal charging rates.
    *8 Manual Special Maintenance 13.6v:
    The BX-5 provides a constant charge rate at 5A and 13.6v, suitable for maintenance of a 12v battery where maximum capacity is required, such as for Golf Carts. The Charger features an automatic overload protection.
    *9 Supply:
    The BX-5 will provide a DC supply of 13.6v at up to 5A if required, featuring reverse-polarity protection.
    The BX-5 is supplied as above, including Laptop-sized Carry Case.
    -F_D
    White Fang:
  13. #93
    Klerksdorp
    Thanked: 155
    Quote Originally Posted by Plod View Post
    Easiest way to judge is by the Inverter price. If it cost below R6,000, the chances are it is a MSW (Modified Sine Wave) Inverter. A Full Sine Wave (or Pure Sine Wave) Inverter will not be less than R6,000.
    We are in the process of evaluating a DC-DC Charger and I will post more on this once we are satisfied with the performance of the unit. Pricing will be very reasonable.
    -F_D
    White Fang:
  14. #94
    Howick
    Thanked: 78
    Thanks FD.
    Steve
    Jetta 2.0 TDI 2012
    Pajero 3.2 SWB 2009
    Jurgens Xcape
  15. #95
    Pretoria South Africa
    The BENTON Range of automatic regulated Battery Maintenance Chargers is currently available in two models, 12V 3.8A (BX-1(M)) and 12/24V 7A (BX-2). They are an excellent alternative to other regulated Maintenance Chargers at reduced cost. There is no risk of overcharging batteries.
    BX-1 FEATURES:
    The Charger is described as:
    FEATURES
    Five-step fully automatic switchmode-mode battery charger and maintainer, designed for charging a variety of SLA (Sealed Lead Acid) batteries, widely used in motorbikes, cars and other vehicles. The batteries may be of various types, i.e.:
    * WET/Flooded (Liquid Electrolyte),
    * GEL (Gelatin type Electrolyte, absorbed into the plates),
    * AGM (Absorbed Glass Mat) batteries.
    Their capacity ranges from 12V/1.2Ah to 12/120Ah. The Benton BX-1 battery charger also charges batteries in cold conditions. Using state-of-the-art technology, the charger enables the recharging of the batteries to almost 100% of their original capacity. It recovers slightly sulphated batteries. It diagnoses and rescues drained batteries. It provides a trickle charge and maintenance charging which increases battery life and gives superb performance. It also features low back-current drain and low ripple.
    PRODUCT SAFETY FEATURES
    * Electronically safe against User-errors. The Charger will not damage vehicle electronics. It is totally safe for months-long connections and maintenance of irregularly or seasonally used batteries, even while the charger is still connected to the vehicle. It provides optimal conditioning without damage. There is no risk of over-charging!
    * Full protection against wrong connections and against short-circuits ensures safe charging operation.
    * The new BX-1(M) now auto-reverts to the selected Charge mode after a power-interruption. The previous model BX-1 had to be manually restarted after a power outage.
    * Fully controlled by internal Micro-Computer Unit which makes it faster, powerful, reliable and smarter. It detects the state of charge of the battery plugged into it and initiates charging.
    * Dust and Splash-proof (IP65).
    * Double insulated.
    TECHNICAL DATA
    Input Voltage: 220~240V AC.
    Charging Voltage: 14.4V or 14.7V.
    Charging Current: 3.8A 10% or 0.8A 10%
    BULK CHARGING TIME
    Battery Size: 60A - 80% Charge, 14 Hours
    Battery Size: 100A - 80% Charge, 23 Hours
    Battery Size: 120A - 80% Charge, 24 Hours
    Battery Capacity: 1.2 - 120 AH/r
    FORUM PRICE: Please send me a PM
    BX-2 FEATURES:
    BRIEF DESCRIPTION:
    Using state of the art technology, the Charger enables the re-charging of Batteries to almost 100% of their original capacity. The BX-2 Charger automatically diagnoses, recovers, charges and maintains batteries for months, fully automatic operation from Charge to Maintenance modes. Six operations options are available - 28.8V, 29.4V, 14.4V, 14.7V, 13.6V Supply and 16V Boost.
    * It recovers slightly sulphated batteries.
    * It diagnoses and rescues drained batteries.
    * It provides Trickle Charge and Maintenance Charging which increases Battery life/
    The BX-2 Charger 7-Step Fully Automatic Charger provides six output options to meet numerous requirements as listed in the table below as well as a 13.6v DC Supply and 16v Boost.
    It features a 10-Stage charging strategy, i.e. Pulse Charge, 7A, 5A, 3.5A, 1.5A 200mA, Boost Charge, Maintenance & Power Supply.
    It has a Memory Function. The Charger returns to the last selected Mode automatically when power is restored. (This function is disabled for 13.6v SUPPLY and 16v BOOST modes).
    TECHNICAL DATA:
    CHARGING VOLTAGE: 28.8v or 29.4v; 14.4v or 14.7v; 13.6v or 16.5v
    CHARGING CURRENT: 7.0A or 5A or 3A or 1.5A
    AMBIENT TEMPERATURE: -20C to +50C
    TYPE OF CHARGER: Seven stage, fully Automatic, Switch Mode with Maintenance Charging
    TYPE OF BATTERIES: 12V & 24V Lease Acid Batteries, (WET, MF, AGM and GEL)
    BATTERY CAPACITY: 14 - 230Ah (for 12v); 14 - 120Ah (for 24v)
    HOUSING PROTECTION: IP65
    NEW!!:
    Other units now available include the BX-4 charger, which is a 3-stage charger for batteries of 6v or 12V DC and offers a charging rate of up to 750mA for the smaller batteries, and also the BX-5 unit which is suitable for either 12v or 24v batteries, charging at up to 25A in 9 automated stages.
    -F_D
    Hello from a seriously uninformed (older) person.
    What is a "PM" and how do I send a "PM"?
    I am trying to contact "Family Dog" concerning the prices of the Benton range of battery chargers.
    Thank you, Buks de Vry sussandevry@yahoo.com 0732031234
  16. #96
    Klerksdorp
    Thanked: 155
    Hi Buks,
    A "PM" is a "Private Message". By clicking on the user-name (in this case my user-name) you will see a pop-up menu appear, one of the choices being "Send a Private message to <user-name>").
    I will now send *you* a Private Message" which you just need to open.
    Regards,
    -Eric
    White Fang:
  17. #97
    Sep 2008
    Vanderbijlpark
    Thanked: 98
    Hi Eric,
    Kindly send me the latest Benton prices, many thanks.
    ZS6VL
  18. #98
    Klerksdorp
    Thanked: 155
    Hi Andries,
    Email sent to you...
    Regards,
    -Eric
    White Fang:
  19. #99
    Sep 2008
    Vanderbijlpark
    Thanked: 98
    Hi Andries,
    Regards,
    -Eric
    Thx Eric! Sorry for the two requests, Gmail's usually reliable and accurate spam filter decided your messages were spam. Got both of them this morning.
    ZS6VL
  20. #100
    Klerksdorp
    Thanked: 155
    Heh... not sure if I should be honoured or offended to achieve that level of fame...
    Maybe I should try a new subject line in the future.
    -F_D
    White Fang:
  1. Benton BX-1 Battery Chargers
    By JDeV in forum Camping, Fridges, Accessories
    Last Post: 2015/02/12, 06:05 PM
  2. Differences between a normal lead-acid car battery and a deep cycle battery.
    By Eggie in forum Vehicle & Technical Chat - General
    Last Post: 2012/01/25, 08:50 AM
  3. Battery chargers
    By Paul Dold in forum Camping, Fridges, Accessories
    Last Post: 2011/11/22, 05:14 PM
  4. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  5. Automatic switch over system between battery charger and solar panels.
    Last Post: 2009/10/08, 03:32 PM
