Electrickery for camping - Page 30
Page 30 of 30 FirstFirst ... 5 20 21 22 23 24 25 26 27 28 29 30
Results 581 to 592 of 592
  1. #581
    Mar 2011
    Walker Bay
    Thanked: 268
    Default Re: Electrickery for camping
    Found the measurements - 84 x 43 x 25mm (LxWxD)
    Paul
  2. #582
    May 2016
    Beyerspark
    Thanked: 77
    Quote Originally Posted by Advocatus View Post
    Agree with the wires on the side. I'm busy installing mine in a small plastic box with perspex cover that is the size of the meter screen. Wires are then concealed going through the back of the box. . No wires visible then.
    I'm also looking to install into a box, the added advantage is that if the box can close you can hide the bright light in the evenings when you want to.sleep. SWAMBO don't like lights when she's trying to sleep.
    Can you tell me where you got the box from?
    Drive: Nissan Hardbody DC TD 16V 2007
    Camp with: Jurgens Xplorer 2010 with a couple of mods
  3. #583
    Jan 2008
    Thanked: 7
    Quote Originally Posted by Gerhardvr26 View Post
    Plastic box from Communica - less than R40.00.
ID:	477733 Click image for larger version.
    I still need to cut out the screen size on the lid.
    JR
    98 Nissan Hardbody 3l, Front Runner detachable roof rack, own drawer system and dual battery.
  4. #584
    May 2016
    Beyerspark
    Thanked: 77
    Thanks. Are you also adding an in-line switch? The problem is that I can't find a way to reset the readings on the meter. From what I read it will reset when there is no power and since it is permanently connected to the battery there is always power. That makes it difficult to keep track of how much was added back into the batteries by the solar panels on a given day. I'm planning to add a switch so that I can cut the power to reset it when I want. That will also solve the issue with having a bright display in the caravan at night when I don't need it.
  5. #585
    Thanked: 276
    An in-line switch will provide you with the (only) means to reset the meter.
    Unfortunately if you leave it off during the night, your fridge will also be "sleeping".
    Perhaps devise a simple flap to cover the display for the night or position the meter where it does not matter?
    Perhaps someone has a better idea?
    Eggie.
    - apology to Edward Langley.
  6. #586
    Jan 2008
    Thanked: 7
    Eggie, spot on as usual as to the in-line switch.
    I think these meters are build for prolonged display, however, I disconnect the meter from the battery when not camping or using any load for long periods.
    I only use the meter to monitor the load (fridge & lights), as it indicates average amps drawn; thus to calculate the amount of hours left for a safe state of discharge of the battery - when there is no input into the battery or when using solar and getting some overcast days. For measuring the input from either the DC-DC charger or solar I have another setup to inform what goes into the battery - ( see post 353).
    JR
  7. #587
    Wartburg
    Thanked: 305
    Advocatus, where do you get these meters from? They look more robust than many of the others.
  8. #588
    Jan 2008
    Thanked: 7
    Mike, from our friends at 4x4 direct.
    http://www.4x4direct.co.za/558-meters
    JR
  9. The Following User Says Thank You to Advocatus For This Useful Post:
  10. #589
    Wartburg
    Thanked: 305
    Thanks Advocatus - should have looked there first.
    Now to find a simple small panel mounted clock. Plenty hideous stuff out there.
  11. #590
    Somerset West when not in Jhb
    Thanked: 55
    https://m.banggood.com/YB27T-Car-Clo...l?rmmds=search
    ORRA Callsign: X130
  12. The Following User Says Thank You to Subok For This Useful Post:
  13. #591
    May 2016
    Beyerspark
    Thanked: 77
    Thanks Eggie. In my case an inline switch will work fine since I've got the monitor between the WRND and the battery measuring what goes into the battery. I like to know what the solar panels are giving back to the battery.
  14. #592
    May 2016
    Beyerspark
    Thanked: 77
    Opened up the device. Drilled holes into the back and threaded the wires through the holes. Took all of 10 minutes. Mounted it to the side of a cupboard in the caravan. Looks damn neat and no wires showing. Will post a photo tomorrow.
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
