Electrickery for camping - Page 3
Page 3 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 28 ... LastLast
Results 41 to 60 of 597
  1. #41
    Hillcrest, Malaysia
    Thanked: 2608
    Smap thanks for the feedback - will add it and update the post. (also now see I dont show a main fuse in the unprotected line feeding the power distribution box ..)
    in my setup that lead is about 250mm long, NO place to short to earth ... but best to ensure a safe message goes out
    I would like, without opening a can of worms, to caution against too many fuses in a system.
    The belt and braces approach is a worthy cause, but one has to be practical. Fuses and their connections are another thing to fail or cause problems. AND THEY DO. One of the biggest sources of failures is lose fuses or the connections to the fuses.
    If Ctek thought it was necessary to put a fuse in the output lead they would have done so, as would all the other charger manufacturers.
    Almost universally the chargers output will be protected in some way against a short. Either a physical fuse or an electronic circuit that performs the function of a resettable fuse, or it will just fail.
    If you must put in a fuse put it as close to the aux battery as is practical. If there is a cable short the fuse will isolate the battery and the charger will protect itself.
    ZS5KAD Yeasu Ft-897D
    2 V8's a V6 and an inline 4
    The nice thing about going the extra mile - the road is never congested.
  2. #42
    Sunnydale
    That is exactly what I meant Fluffy. You do not want to unleash a couple of hundred available amps without being able to stop it. Maybe just a bit "omslagtig" the way I put it.
  3. #43
    Apr 2008
    Kuils River
    Thanked: 31
    Dankie Chris.
    +1000 dat dit 'n sticky word.
    Francois Johnson
    (swambo: Christel)
    Our rides
    • 2010 Isuzu KB300LX DTeq 4x4 D/C
    • Metalian Maxi Trailer, Maxine
  4. #44
    Jun 2013
    Thanked: 818
    Thanks for this, great piece of work
  5. #45
    Mar 2011
    Kenmare
    Thanked: 45
    En hier dog ek jy is net n mooi gesiggie, nice man, dankie
  6. #46
    Well done Chris, nice job.
    Bryan
    Disco 4 SDV6 S (me)
    Jeep Cherokee CRD (swambo)
  7. #47
    Hermanus
    Chris, dis die beste wat ek nog gesien het en baie leersaam. Mooi man.
    Give the man a single malt!!
  8. #48
    Thanked: 277
    Netjies Chris, sommer baie netjies.
    Jy steek natuurlik jou kop ver uit as jy so "techno" raak, maar ek sien niemand waag dit tot dusver om jou te kritiseer nie. Voorwaar netjies.
    Ek stem saam met Poen dat die LC (lood kristal) tipe batterye net die ding is vir ons tipe toepassing. Dis baie geld, maar ook baie goed bestee.
    Eggie.
    - apology to Edward Langley.
  9. #49
    Toronto
    Great set of Articles, well done Chris, this is extremely useful.
    Dylan
    LandRover Discovery III TDV6 S 2006
    GP 0112
  10. #50
    Apr 2012
    Louis Trichardt, Limpopo
    Thanked: 171
    Do not mean to hijack the thread...
    Here are a few pics of a extra batt set I built for someone. Its mounted on a steel frame covered with alu plate and serves as a platform to house the extra batt and his fridge to the front of the plate.
    It is mounted between the 2 back seats. The double batt is fed from a CTEC 250 S and there are multiple Hella, Cigarette and BH connection plugs mounted on the sides of the batt box.
    Alu tie-down strips are mounted onto the platform to strap the fridge tightly to the platform and the platform is bolted onto the chassis to make it projectile safe just incase.
    All is made safe with multiple fuses, all connections soldered and exclusive use of heat shrink.
    Pity I never took pics after everything was installed but sure I can get some if I ask for the vehicle.
ID:	287951   Click image for larger version.
ID:	287952   Click image for larger version.
ID:	287953   Click image for larger version.
ID:	287954   Click image for larger version.
ID:	287955   Click image for larger version.
ID:	287956   Click image for larger version.
ID:	287957   Click image for larger version.
    '13 Toyota Hilux 4x4 XCab
  11. #51
    Pta
    BEST Thread I have read so far!!
    Thank you.
    LC '79 MEANO Double Cab Mod with "The"Aussie 4.5liter V8 Diesel "Beast"
  12. #52
    Thanked: 8
    Thanks Chris, when i decided to add a Batt to the Jeep, info like this was "skaars". Luckily, Leeu (a member here) took pity on me! Great info.
  13. #53
    Somerset West when not in Jhb
    Thanked: 55
    Thanks Chris! Literally thousands of discussion posts on this (and other) forums combined.
    I agree to make it a sticky and to perhaps close the thread. Another discussion thread on the subject can be opened and useful info transferred to the sticky?
    I am at the 'solar panel stage' of evolution and would appreciate more info on the wiring of the panel/controller for semi-permanent mounting on the roof of a vehicle in combination with a solenoid-type dual battery setup, so that the panel will charge the dual battery when stationary while say, sitting at a water hole on a game drive. This is for those of us who dont have a trailer waiting at the camp with the panel keeping the fridge going. Apologies if i missed this in your original post.
    Finally, I suggest that the forum knighthood be bestowed on Chris for this valuable contribution.
    ORRA Callsign: X130
  14. #54
    Hillcrest, Malaysia
    Thanked: 2608
    Quote Originally Posted by Eggie View Post
    Agree Eggie.
    Let's all make a pact to not pollute this thread with unnecessary critique of some of the finer points that hold no value other than to show how clever we are.
    If you would like to discuss an issue, maybe start another thread and reference this one.
    Obviously an incredible amount of thought and work went into this one.
  15. #55
    Clanwilliam
    Thanked: 143
    Got to love the Toyota wheels on the diagrams!
    2011 FJ Cruiser
    2018 Hilux 2.4 4x4 D/C
    Afrispoor Serval
  16. #56
    Bellville
    Thanked: 943
    Quote Originally Posted by Metalmachine View Post
    That looks GOOD !!
    I would support a fitment centre that delivers work of that standard.
  17. #57
    Bellville
    Thanked: 943
    the pdf has been added to POST ONE.
    THANKS for the feedback, it has been added to the pdf document.
  18. #58
    Bellville
    Thanked: 943
    Quote Originally Posted by Subok View Post
    ... I am at the 'solar panel stage' of evolution and would appreciate more info on the wiring of the panel/controller for semi-permanent mounting on the roof of a vehicle in combination with a solenoid-type dual battery setup, so that the panel will charge the dual battery when stationary while say, sitting at a water hole on a game drive.....
    two options here, again most start with option one, and most move on to option two at some stage ....
    ONE -
    Make a "slide" mount for the solar panel. The mount could be permanently mounted to the roof/canopy, or a temp fix to roof rails ...
    You then make use of Brad Harison Connectors (which reminds me I still want to add a chapter on connectors). Your solar panel(s) connect to a lead with a BHC, which in turn is permanently connected to the dual charger. So every time you stop the solar carries on charging.
    IF you camp under trees you then have the option to slide out the solar panels, and use an extention lead to connect it to your system.
    Slide frame for the solar panels (final resting place of my old canopy .. )
    panels in frame (sorry I dont have a better pic of this)
    TWO - exactly the same as one, except that the panels are fixed (cant slide out). right or wrong, it is just too much of a shlep and people hardly ever use the slide function ....
    second time round I just bolted it on .... (may well still wish I kept a slide of sorts ... maar dis mos maar hoe ons leer)
ID:	287974   Click image for larger version.
ID:	287975   Click image for larger version.
  19. #59
    North of Zambezi
    Thanked: 237
    Excellent contribution Chris!
    Bertie
  20. #60
    Thanked: 8
    Hi Chris
    Excellent information.
    Could you tell me where I could get that voltage/ amp meter in your illustrations.
  1. Electrickery
  2. Disco 3 electrickery fundi
    By Will F in forum Land Rover
    By Estee in forum Land Rover
