Dash Cam with Full HD/GPS logger/G-sensor (V2) DEALER ADDS - Page 48
Page 48 of 50 FirstFirst ... 23 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 941 to 960 of 995
  1. #941
    King Williams Town
    Thanked: 573
    Default Re: Dash Cam with Full HD/GPS logger/G-sensor (V2) DEALER ADDS
    Help needed. My Eagle eye dash cam has now started messing around. When vehicle is switched off dash cam comes on and switches off a few times. If I remove it from the power cable the battery indicator shows it's still charging ie battery indicator running up and down as if charging. I have reformatted the card but nothing helps.
    Feed back. After formatting the memory card a few times. The dash cam would not record only take pictures. I did a factory reset in the dash cam menu and hey presto it tells me the card is full. Reformated card and now dash cam is working perfectly.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  2. #942
    Dec 2011
    Thanked: 1401
    Welcome back. We missed you.
  3. #943
    Kyalami
    So my Dash cam decided to stop working, bought it in 2014/11, not even 2 years. Only the red light stays on when plugged in, cannot turn it on at all. Is it still under warrantee? Any advice?
    --Kar
  4. #944
    Thanked: 246
    Default Re: Topcctv.co.za - Dash Cam with Full HD/GPS logger/G-sensor (V2)
    Some lightning footage taken with my dashcam yesterday.
    https://youtu.be/LqI3Ew7uCEA
  5. #945
    Port Nolloth
    Thanked: 143
    Hi,
    I have one of the original dashcams bought a couple of years back. I'm running Windows 10. When I plug the dashcam into the PC it is not recognised as a drive and datakam app doesn't see the device. Tried updating USB drivers but windows say sorry you've got the latest. The unit powers up via the USB port so the cable is OK. Any ideas?
    2004 Facelift Disco 2 - Raine - sold
    2006 Defender 110 csw - Jaeger
    "Land Rovers don't get stuck, people do, so always look before you leap and if you're unsure, don't do it" Chris Horne
    2017 Local is lekker year - Exploring the West Coast
    2018 Back to CKGR - Piper 01 25th August, Passarge 02 29th August
  6. #946
    May 2012
    Thanked: 33
    Quote Originally Posted by Keith Newnham View Post
    Hi,
    Use different cable
    Current: 2015 Ford Ranger 3.2L XLT M/T D/C 4x4 (since: 31/08/2016)
    Previous: 2013 Ford Ranger 3.2L XLT M/T D/C 4x4 (05/01/2013-31/08/2016)
    Previous: 2010 Nissan Navara 2.5D LE M/T D/C 4x2 (Sold: 30/10/2012)
  7. #947
    Klerksdorp
    Thanked: 157
    Keith, I also suspect the cable. Have just pulled out an old unit lying here for years without use, internal battery flat as hell but if you set the menu to 'MSC', it works fine with Win 10.
    I suspect you might be using a charging cable and not a data cable.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  8. #948
    Port Nolloth
    Thanked: 143
    Quote Originally Posted by Prodigal View Post
    Use different cable
    Thanks Prodigal, tried that same result.
  9. #949
    Thanked: 644
    No difference between data\charging type cables if your aim is getting data through it.
  10. #950
    May 2012
    Thanked: 33
    Quote Originally Posted by Rustie View Post
    Disagree, a charging cable may be missing D+ and D-
  11. #951
    Port Nolloth
    Thanked: 143
    Thanks Prodigal and FD , tried a 3rd cable, the one I use on my DSLR, now it all works Learnt something new ... not all cables are equal
  12. #952
    Klerksdorp
    Thanked: 157
    So I thought too, but there is a difference. Charger cable only charges, charger/data cable does both. Found that out the hard was myself!
    -F_D
    White Fang:
  13. #953
    Oct 2012
    Thanked: 8
    I am looking for a new plastic clip (held by the two little screws). My dash cam fell off the windscreen and this piece broke.
    Are there parts available?
    Ex:07 Disco 3 TDV6 SE
    2011 Disco 4 SDV6 SE
  14. #954
    Jul 2014
    When will cam be in stock again?
    2013 Chevrolet Trailblazer LTZ 2.8 4X4 AT
    2017 Conqueror Companion
  15. #955
    Gaborone, Botswana
    Thanked: 384
    Does the SD Card get tired after some years?
    I have a lot of broken files and missing video when I transfer to the PC. A format did not improve the situation.
    When I buy a new card, what do I look out for? (Specs) We do not have many options over here. You buy what is available.
    Kobus
    HDJ81 VX
  16. #956
    Thanked: 246
    I do think that the older a card gets, the more prone it will become to errors/failure. I have experienced the same.
    However, the battery on my dashcam has packed up and does not charge anymore. The result is that when external power is loss by switching ignition off or pulling the plug, it just dies. And, I think, when this happen it does not have time to do a proper shutdown.
    The mini USB connector that plugs into my unit also became very loose fitting. Due to the above problem it would then also just loose power and switch off without shutting down properly. I have used small nose pliers to clamp the mini USB connector to ensure a tighter fit. And, touch wood, that seems to be holding for now.
    But then the card has also started to give me warnings that it might be on its way out where it will give me an error regarding the card. I can't recall the exact error. I then format the card and sometimes I have to do it a couple of times.
    The error you describe also seemed to get worse the longer I use the card (with loop recording) without doing a format. It is almost like a full HD on your PC that slows down the PC as it has less "working space".
  17. #957
    Gaborone, Botswana
    Thanked: 384
    Thanks Danie.
    My Cam is set to shutdown 10sec after the power falls away. The battery still outlives that. The missing and damaged files are random in the middle of a continuous recording. (The USB Connector is still tight.)
    I think I will go and get a new SD Card.
    Will report back.
    Kobus
    HDJ81 VX
  18. #958
    Jul 2007
    Despatch
    Thanked: 19
    My dashcam stopped recording. When switching on, the timer doesnt run and after a 12 hour drive, there is no footage on the disc. I have reset to original settings a few times and it still doesnt work. When switching on now it shows a quick 5 second smaller blue screen notice, Input FTT card
    What can the problem be? The memory card buggered and thus not recording anymore? Do I have to buy a new memory card now?
    Offroad junky'03 Nissan HB 3.0TD D/C 4x4'14 Citroen DS4 2.0 HDI swambo's platkarPreviously;'07 Hilux D4D D/C 4x4'16 Ford Ranger 2.2 DC XL Hi-Rider'12 Disco 4 SDV6 SE - Beauty'06 Disco 3 TDV6 S (De-cat, EGR blanked, remap, Johnson rods suspension rods, 285/65-R17 Kuhmo KL61) - Beast'04 Terracan 3.5 V6'96 Ssang Yong Musso 602 (non turbo manual)'04 Ford Ranger 2.5 TDI D/C 4x4 with Solid front axle and 33" Maxxis
  19. #959
    King Williams Town
    Thanked: 573
    ORJ Try formatting card in.camera
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  20. #960
    King Williams Town
    Thanked: 573
    Question,having the dashcam screen mounted,does the hot sun damage it or cause it to go faulty
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  1. Topcctv.co.za - Dash Cam with Full HD/GPS logger/G-sensor
    By wildgear in forum Commercial Member Adverts
    Last Post: 2015/02/28, 07:45 PM
  2. GoPro for dash cam?
    By Wetkit in forum Cameras & Photography
    Last Post: 2013/09/17, 03:07 PM
