Adjusting static timing
Results 1 to 6 of 6
    Pietersburg
    Default Adjusting static timing
    I would like to adjust the timing on my Ford Escort Mk 1 1600cc X-flow.
    I would like to make use of the static timing method, but cannot remember exactly how its done.
    Is there anybody that can help?
    Deon
    If you can't fix it with a hammer,you have an electrical problem...
    Quote Originally Posted by dcsmax View Post
    Get your no: 1 cyl on fire. (valves tappets loose)
    Turn crank pulley to desired deg.
    Loosen dizzy and remove dizzy cap.
    Switch on ignition.
    Turn dizzy slowly untill points spark.
    Replace everything and tighten.
    '94 Hilux 4x4 3.0 D/Cab. KZTE Eng.
    2007 Fortuner 4x4 4L V6 AT
    Pietersburg
    Quote Originally Posted by TopHilux Hilton View Post
    Hilton,
    WHen using a 12v globe to indicate exactly when points spark, how would I connect the globe?
    Deon
    I've never used a globe, but I can only amagine it must be connected to the points somehow...
    Klerksdorp
    Thanked: 157
    Connect it across the points, it should burn when the points are open. When they close, the bulb must go out.
    Use a very light-wattage bulb, such as those that Midas sell in those brass testers, or a dashboard bulb (12), do not use a high-wattage bulb.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
    May 2007
    No.1 piston to TDC (at whatever degree's before you want to adjust to). Loosen distributor. Test light to negative of coil. Turn distributor anticlockwise till light goes out, back clockwise till light comes back on, and fasten distributor.
    I am not a complete idiot - there are still some parts missing
    Please don't send me a PM without direct contact details
    97 SVM 3000
    86 HiLux D/C
  1. Replies: 0
    Last Post: 2011/09/18, 07:40 PM
  2. 5.4km per litre
    By Bushwizard in forum Mitsubishi
    Last Post: 2009/04/06, 03:43 PM
  3. Replies: 0
    Last Post: 2009/03/13, 06:50 PM
  4. Discovery I Tdi 300 timing belt cover dust seal
    By Thys Willemse in forum Land Rover
    Last Post: 2008/01/02, 12:33 PM
  5. Replies: 10
    Last Post: 2007/10/16, 08:18 PM
