Marius's Touareg R5 life thread.
Page 1 of 161 1 2 3 4 5 6 7 8 9 10 11 26 51 101 ... LastLast
Results 1 to 20 of 3203
    Dec 2011
    Thanked: 1497
    Default Marius's Touareg R5 life thread.
    INDEX
    *** This page index will only work if your settings are set to 20 posts per page
    Go to your User options and scroll down to where you can set "Number of posts to show per page"
    Page 1
    Misfire 2 months after purchase
    speculation on causes
    Page 2
    Car at NTT VW East London. Poor service
    Injectors out
    Page 3
    Low compression on cylinder 5
    Page 4
    Legal discussion on what is to happen now
    Page 5
    Further legal discussion
    Cause of low compression discussion
    2SO to blame?
    Page 6
    Possible engine found
    Page 7
    Possible workshop found to do the swap
    Page 8
    Car is moved from VW to Ian's auto clinic
    Page 9
    Engine supplier is a scammer
    Page 10
    Trying to trace the scammer
    Weighing other options
    Page 11
    Got hold of the scammer but call was dodgy
    Still weighing up options
    Page 12
    Scammer lead went dead
    Considering bringing the car home and pulling the engine
    Page 13
    Engine arrives back home after diagnosis of low compression on cylinder 5
    Page 14
    Stripping begins
    CCV Discussion
    Page 15
    CCV Discussion continues
    Further stripping
    DIY Crank turning tool
    Page 16
    Engine comes out
    Engine out pics
    Page 17
    Cylinder head off
    Looking for engine replacement options
    Page 18
    Considering a rebuild
    Page 19
    More pictures of damaged bore and piston
    Ombudsman discussion
    More engine pics
    Page 20
    Reason of failure discussion
    Rebuild versus replacement engine discussion continues
    Page 21
    Ombudsman and previous dealer discussion
    V8 Lexus motor option discussion
    Page 22
    V8 Lexus motor option discussion continues
    Rebuild option rediscussed
    Page 23
    Romzotwa finds a possible 2nd hand engine at a breaker
    Kortgat starts fundraiser thread for replacement engine
    Members start helping out to check out possible replacement engine
    Page 24
    Oil analysis of replacement engine being organised
    Page 25
    Oil analysis results
    Oil analysis discussion
    Compression test being organised
    Page 26
    Compression test results
    Pumpe duse, common rail and plasma coating discussion
    Page 27
    Plasma coating and oil spec discussion
    Tandem pump discussion
    Speculation to reason for original failed engine
    Page 28
    Replacement engine arrives
    New tandem pump discussion continues
    Page 29
    Engine prepped, ready to go in
    Thermal covers discussion
    Catalytic converter removal instruction
    Oil spec discussion
    Engine sleeve discussion
    Page 30
    Oil discussion continue
    Thermal cover pictures
    Page 31
    Engine weight on pallet 223kg
    Tandem pump arrives
    Engine drop in
    Torque converter install discussion
    Engine install pics
    Page 32
    Windscreen damage
    Wiring harnass wrapping discussion
    Page 33
    Codes cleared
    Engine start video
    Page 34
    Finished engine picture
    Oil pressure scare
    Page 35
    Another engine start video after the system has fully primed.
    Vagcom injector measuring blocks at idle
    AntonvBosch starts discussion on his treg that got electrical faults
    Page 36
    AntonvBosch discussion continues
    Tandem pump disassembly link to tdiforums
    AntonvBosch Alternator not turning discussion
    Sump taken off old engine toshow dipstick
    Page 37
    2 stroke oil discussion starts
    Alternator discussion continues
    Geartrain cover removed on old engine
    2 stroke oil discussion continues
    2stroke oil sulphur ratios discussed
    Page 38
    Page 39
    Engine removal short notes
    Windscreen repair pictures
    New engine Pump Jet Valve error on cylinder 5 (N244)
    Possible faults for error discussion - touching on 2SO again
    Page 40
    Injector discussion continues
    Injector removal, install and coding discussion
    Page 41
    Injector connector removal notes and pictures.
    Page 42
    Picture of first drive
    Licensing procedure with microdots from DEKRA
    Microdots under UV Light
    Page 43
    Injector adjustment
    D1S HID replacement bulb discussion
    Bulb replacement pictures
    Page 44
    HID vs Halogen discussion
    AntonvBosch Alternator discussionAlternator discussion continues with rough running engine
    Chriseleven radiator fan running on discussion
    Piston 5 on old engine out - pics and discussion
    Page 45
    0-100 km/h video
    Touareg Launch mode discussionFurther discussion on reason for failure on cyl5 (heat failure specifically)
    Page 46
    EGR discussion starts
    EGR disable DIY instructions and Video
    Page 47
    Airbox pictures of the inside
    Macro picture of failed piston
    First long trip feedback
    Page 48
    EGR & CCV discussion
    Catch can discussion with V6 TDi
    Suspension bushes ordered from Porsche
    Suspension bushes fitted DIY.
    Page 49
    AntonvBosch engine failure options discussed
    Night time cockpit photo
    EGR & economy discussion
    Page 50
    Photo compilation video
    Passenger door sag fix
    Door sag fix discussion
    Economy, range and fuel tank size discussion
    GPS vehicle changed to touareg (plus pajero model download)
    Page 51
    Fuel economy discussion
    Touareg with over 700'000km on the clock
    Page 52
    AC problem starts
    Fuel economy discussion continues
    Page 53
    AC issue found
    AC problem discussion continues
    Touareg dash cam - dodging dog
    Page 54
    AC pump clutch pictures, failure and discussion
    Another dog dodge dash cam video
    AC issue discussion continues
    Page 55
    Air strut lifespan discussion
    GPS install in center cubby hole on top of dash
    AC bearing assembly strip pictures
    Boost pipe O-rings clean
    Page 56
    Boos pipe o-ring clean discussion continues
    Page 57
    Ferndale outing pics
    Smoky idle discussion
    Touareg W12 turbo videos
    Replacing turbo seals
    Vacuum pipe diagram for VGT, EGR and intake manifold shutter flap
    Page 58
    Gonubie Pine forest outing
    Cleaned up engine bay picture
    Fuel economy history
    Turbo dismantled pictures
    Nearly Head On Collision on dirt video
    Page 59
    Link to another R5 engine swap thread
    Kortgat's link to to 507.00 and bearing failure
    Oil spec discussion
    Almost head on collision on N2 video
    Double Mouth Camping
    Cold Start Throttle body video
    Offroad wheel cam timelapse video
    Touareg with Lexus V8 discussion
    Page 60
    New Tyres - Apollo Hawkz 235/65/17 R/Ts
    Air suspension explained
    VGT Turbo actuator video
    Gauteng trip economy
    Page 61
    Webasto heater kicks in for the first time
    Page 62
    Oil spec discussion
    Spotlights installed
    Page 63
    Hogsback photos
    Nearly hit a buck - dash cam video
    Headlight ballast failure due to short circuit & water ingress
    Alternator coupling and freewheel failure (plus video)
    Page 64
    Alternator removal pictures and DIY instructions
    Alternator freewheel failure theories
    Freewheel clutch theorems and explanation videos
    Page 65
    Alternator issue sorted
    Cold start smooth running engine video
    G28 engine speed sensor issue
    Key covers from ebay
    Page 66
    Mercedes case of debris ingestion causing failure
    Probable causes discussed of merc engine failure - broken glow plug tip?
    SSP links
    Page 67
    Video of R5 engine running without tappet cover
    Still looking for a ballast
    Page 68
    My rebuild story makes the winning letter in the WegRy/DriveOut December 2013 magazine.
    Ballast ordered.
    Page 69
    Rat chewed airpipe
    Speed sensor connector issue
    Page 70
    Driveout/Wegry Magazine December 2013 publication
    Trip back from Cape Town - Injector electrical failure on #3
    Page 71
    Sorting out Rental and flatbed from TuffStuff
    Reenen keeping us company
    Page 72
    Trip home
    Injector failure discussion
    Page 73
    TuffStuff service discussion
    Swartbergpas pictures
    Injector removal
    Page 74
    Injector removal tools
    Wiring loom replacement
    Crimp versus solder discussion
    Page 75
    Suspected parrafin in diesel tank
    Picture of bad diesel from Oakvlei Motors versus good diesel from Caltex
    Page 76
    Paraffin contamination discussion
    Fuel filter inside
    Page 77
    Transporter versus touareg 2.5 engine differences in starter casting
    Tyrone 12 smoke issue on transporter discussion
    Draining the fuel tank
    Page 78
    Fuel tank diagram
    2SO discussion over failure
    Further failure discussion
    Results of fuel testing comes back negative
    Page 79
    Misfire is still present
    Discussion on possible causes
    Tandem pump suspected discussion
    Page 80
    EGR disconnected but issue persists
    Further tests
    Page 81
    Intank fuel pumps removed and mesh screens checked.
    Tandem pump flow suspect
    Page 82
    Further tandem pump discussion
    How to check tandem pump flow via return line on filter
    Page 83
    Fuel filter changed - car running good and return flow test within spec
    Concise list of issues on engine so far
    Page 84
    Fuel filter schematic with thermostat and flow paths.
    Whole fuel story summed up
    Page 85
    Hogsback outing
    Overtaking power video
    Oil change with oil flush
    Clean oil on dipstick
    Page 86
    Oil part numbers and prices for gearbox, transfer case and differentials.
    Page 87
    Dealer phone call - clueless about touareg oils
    Camping at dad's place
    Brake fluid change
    Differentials, gearbox and transfer case oil change
    Page 88
    Gariep GTG pictures
    Spider in the road video - dashcam
    Dad drives the car
    Front upper control arm suspension bushes replaced
    wrong pollen filter from Goldwagen
    Upper control arm install timelapse
    Page 89
    air suspension coding via VCDS
    a destroyed R5 engine due to neglect and wrong oil - lots of pics
    oil spec discussion (including some dealers' ignorance on spec)
    Page 90
    a V10 being detailed in the UK
    propshaft carrier bearing plus contact details of supplier
    Page 91
    Propshaft carrier bearing DIY thread
    propshaft bearing discussion
    My propshaft removal pictures
    Page 92
    Propshaft balancing
    LED light bar installation
    LED Lightbar dashcomnight drive
    LED Lightbar comparative night shots
    Page 93
    Front brake pads and rotor DIY
    Top 15 most viewed list made
    Rear brake pads and discs swapped
    Meeting Wedgy
    Page 94
    TuffStuff bubble stickers arrived
    Projector spotlights installed
    Car running well - concise events leading up to it from the initial engine change
    stripping dad's gen1 pajero - pulling engine out
    remote jamming crooks
    Page 95
    remote jamming discussion continues
    Hogsback snow trip
    Hogsback snow hill climb video
    Last pic of clean oil after service experiment
    Pollen filter fitted
    Trip to Douglas
    Air box pipe loose
    Page 96
    Touareg vs Fortuner comparison
    Johan Slabbert's Fortuner pictures
    Airbox duct discussion
    Timelapse video - Queenstown to East London
    Page 97
    Suzuki Grand Vitara discussion
    Swaybar bushes replaced
    DVD headrests and Double Din unit go in
    Page 98
    Double Din Nav software working
    Old engine internals going to stuffed engine
    Waterpump workings discussed with picture
    Trip with the Hilux boys to Hogsback - Awesome trip & awesome people!
    Page 99
    Michel's pass videos
    Mpongo game drive
    0-80km/h brake start video for XJJunkie
    Page 100
    Handbrake discussion
    Sand driving discussion
    Passenger door card off to find sticky door handle issue
    Farm quarry 4x4 playing
    Page 101
    280'000km reached
    Old engine sold
    Brad harrison plug installed
    Battery distribution panel pictures
    Hogsback Hobbit Run outing
    Aftermarket double din radio FM reception issue
    Fakra connector experiment
    Tyre rotation
    Rims repainted
    Clean coolant condition
    Page 102
    Long distanceeconomy discussion
    Helping Wedgy install a racechip
    Some outstanding economy figures from PTA to East London
    Blower motor giving issues
    Page 103
    Recovering a Microbus Video
    Indicator issues
    Rear differential clearance
    HID install
    Stutterheim to East London - 8.0l/100km
    Prius discussion
    Page 104
    Prius discussion continues
    HID discussion
    Gonubie Pine forest video
    Pine forest cleanup
    A/c freewheel pulley replaced
    Power steering pump replaced
    Ballast failure due to water ingress - aftermarket retrofit
    Page 105
    Lightweight bonnet discussion
    Wattlechop camping
    Stutterheim quarry off roading
    Caravan towing feedback
    Pine Forrest outing
    Page 106
    DANGER of water ingress - Picture of intake pipe behind wheel liner
    Offroad ideos at pine forest. (Including beating a Prado)
    Oil change
    Bash plate fitment
    Wiper idler bracket seized and broke
    Swartberg pass lunch - panorama picture
    VIDEO - touareg recovering prado
    Page 107
    Wash day with a polish and a wax
    Transkei Eco Trail to the Jacaranda wreck (with video)and camping at Umthombe Kei
    Isuzu stuck at EL show
    Great fuel economy to Umngazi and back
    New (second hand) Tyres on the way
    Page 108
    265/65/17 Bridgestone Duellers fitted - plus feedback on them
    Touareg Tows Landini Tractor Video
    Queenstown 4x4 trip
    Page 109
    Tow eye discussion
    Dual battery installation
    Page 110
    Touareg automatic start video
    More dual battery pictures
    Water beads on bonnet of the car after waxing and polish
    Touareg Towing ESP feedback in crosswinds
    Air inflation and suspension discussion
    Space saver spare discussion
    Page 111
    Touareg vs Fortuner packing space
    Freelander vs touareg p'ing contest
    Page 112
    New battery installed
    Recovering an Isuzu stuck on grass - with video
    Recovering a mazda drifter on trailer due to breakdown
    Page 113
    Mpongo off road trip - That was awesome!
    Gravel road driving at speed - with video
    Right rear brake light globe
    Fuel consumption figures from Northern Cape to East London
    Radio switch for when car is off
    Page 114
    Another incident where I can clearly feel that shell 500ppm gives better performance than caltex 50ppm
    Looking for a full size rim as spare
    Found a full size spare rim - pic of spare on the roof
    Page 115
    Built in sun shades in rear doors discussion
    Muddy driveway
    Ciskei Monument & Katberg drive and Hogsback lunch
    My first speeding fine in the Touareg
    Page 116
    Aftermarket aerial install
    Three years since purchase
    Page 117
    Stuck in driveway due to cattle blocking the way
    Air suspension rebound clunk - eccentric bolt wear in the bush
    new bolts ordered for clunk - still some play so new bushes ordered as well
    Dashcam video - muddy puddle
    Dashcam video - shortcut through pine forest time lapse
    Removing control arm DIY instructions
    Prototype 1 for holding spare wheel on roof carrier
    Prototype 2 for holding spare wheel on roof carrier
    Auxialliary battery venting discussion
    Page 118
    Tether for spare wheel discussion
    Lower front control arm bushes
    Page 119
    Air suspension relay
    chipping discussion
    Double Mouth weekend
    Lunatic on road - dash cam video
    Page 120
    Hella Spotlights installed - luminator X
    Pampoenkop hill climb in Pine Forest - video
    Tandem pump removal/install thread
    Page 121
    Leaking air strut
    Wheel liner removed - panorama picture
    Hit a bushbuck
    Almost at 300'000km
    Page 122
    Catch can setup
    Filters and oil service - changed to Fuchs oil
    ticked over to 300'000km
    Page 123
    Air compressor special at Midas
    Misty evening photos
    Aircon issues discussion
    Economical - 8.4l/100km - Stutt to East London
    Page 124
    Tyre sizes
    Pine forest outing on new years day (2016)
    Climbing Banzi's hill - video
    Rutty climb in the pine forest bowl - video
    Attempting a sand dune with tyres at 2.5 bar - video
    Page 125
    Recovering family in Bloem with a broken Audi
    Haga Haga weekend
    Rendezvous camping
    Page 126
    Transkei 4x4 Trip
    Rutty climb video
    Nongqawuse pool location
    Serious rock climb video
    Discussing auto versus manual in serious offroad situations
    Page 127
    Hogsback Camping weekend
    Speed sensor failure
    Page 128
    Helping Kortgat with Dual battery cable routing
    Road trip to Douglas - Molteno wind farm
    Page 129
    Weekend away to Khala Moya cottage
    Exhaust leak fixed with drill and tap on cylinder one
    Jump starting Kershmeister's (Brendan) Isuzu at the airport
    Achilles desert hawk XMT mud tyres ordered and fitted
    Page 130
    Tyre discussion
    Pine forest sand video with muds fully inflated - video 1 - video 2
    Pine forest pictures
    Thread purpose questioned
    Page 131
    Thread purpose discussed further
    Page 132
    Wheel speed sensor failure
    Road trip towing back from Gauteng
    Economy discussion with muds/mods
    Original radio going back in due to aftermarket having poor reception
    Page 133
    Radio reception with diversity antenna discussion
    310'000km service
    w12 touareg discussion
    Page 134
    Swaybar bushes again
    Upper left control arm replaced
    Center console and wood trim wrapped with carbon fibre vinyl
    Secrets of the touareg
    Page 135
    Pine Forest group photo outing
    Boot won't open with suspension error beached on hump
    Sand driving drone footage - http://www.youtube.com/watch?v=qMkZATxLol0
    Cold start glow plug duration video - https://youtu.be/qgbES9f7kok
    2so going in
    EGR & Fuel temp resistor mod discussion
    Page 136
    Tyre size discussion
    Injector readings video -https://www.youtube.com/watch?v=Ktms9lVYxWQ
    Page 137
    Cape Town scenic route over seweweeks poort pass
    Tyre life on the Achilles XMT update
    Engine oil clean after 3500km since service
    Lady rolls into me - VIDEO
    Page 138
    High emissions sticker
    Goldwagen lower control arms
    Page 139
    Pine forest night drive
    Gutting CAT discussion
    Camping at yellow sands
    Page 140
    Steelies fitted
    Stutterheim forest drive
    Maxpider 3D floormats
    Page 141
    Rear middle seatbelt retractor repair
    Wheel bearing play - rexbo.eu order
    Page 142
    Wheelbearing removal and install discussion
    Wheel bearing tools and walkabout VIDEO
    Page 143
    Wheel bearing arrived and fitted
    Page 144
    Wheel bearing discussion continues
    Small drift VIDEO
    Page 145
    320'000km on the odo
    Page 146
    Page 147
    Page 148
    Page 149
    Page 150
    Page 151
    ______________________________________
    2 months ago i traded my pajero in on a touareg.
    Last week back from jhb it developed a misfire on cylinder 5.
    It also started using oil pretty badly - i suspect via ccv as crank vapours are pretty heavy.
    Doing a bit of research i suspect a cam lobe wear (possibly a lifter failure accompanying) so i pulled the tappet cover and the cam and lifters on brief inspection looks ok.
    Next is a possible injector seal failure (the copper ones that seal the injector to the head) hence why i didnt do a compression check.
    Vw manual states an easy diy but im missing some vw specific tools and the car has a warranty and its fairly newly bought (albeit secondhand)
    So, i have booked it into vw last week (they will open her up tomorrow) and i gave them instructions. i dont want to leave diagnosis in their hands or leave the issue with the dealer that sold me the car as they will start on a replace everything till we find the issue basis and then probably not cover it.
    To pull injectors
    Call me when they are out so i can have them ultra sonic bathed (just the bottom part with the laser cut intake holes that are tiny)
    I will inspect the cam and lifters properly with them
    After i give the injectors back they must reinstall with new orings, new rocker bolts, new unit injector adjustments bolts) and copper heat shield washers and swap injector 5 and 1 to see if misfire follows injector
    If after assemble the misfire continues on cylinder 5 its probably a faulty piston or rings
    If misfire follows injector then that injector is dud
    Question to you guys. Regardless of diagnosis what is my position with the dealer that sold me the car? (i dont mind if my experiment with vw comes out of my pocket but failing that what are my options?)
    Sent via iPad & Forum Runner
    Jul 2008
    Pretoria-East
    Thanked: 55
    Sorry to hear about the troubles.
    How many km's did you add since buying the car? If not too many, you should approach the dealer to rectify depending on the diagnosis and if the problem/cause can be proven to be a pre-existing defect. The dealer will argue wear and tear if you put unreasonably high additional mileage on the car since the purchase.
    Then again, I don't know much about the consumer protection act. Between that and the warranty, you should probably be OK.
    - Nothing comes at a higher price than that which is free.
    The Windy City
    Thanked: 2206
    Marius,
    I think you need to get proper advice on this.
    My personal take though. Have you engaged with the dealer / warranty / guarantee provider yet? I would do that BEFORE you open the motor, and let the opening instruction come from them.
    Apr 2009
    Bellville
    Thanked: 727
    Marius,
    +1
    If you initiate work without their knowledge/approval, they may just refute liability. Get them in the loop.
    Port Shepstone
    Thanked: 199
    Sorry to hear about your woes, make it the warrantee's problem!
    I have heard this story before, excessive cam play on I think cylinder 2 after injector failure, let me phone a mate who had a similar problem on a T5 tomorrow! Pardon my ignorance but AXE motors have very specific quirks and if you've had one for 5 years you act like an expert! While you're at it carefully inspect the exhaust manifold! IMHO thats where all the shite starts!
    What a life!
    Dec 2011
    Thanked: 1497
    Warranty is pretty worthless. Found out too late. It covers very little and the stuff it does cover is linked to a price which will just be good enough for a tazz.
    An injector service or cam replacement or lifter replacement i can live with. What worries me is that a piston could be cracked or melted. I dont want to foot the bill for a replacement engine which starts at R60k reconditioned.
    I think this was a fault that has been gradually getting worse. I remember fluffy test drove it for me and reported a vibration at low revs which i shrugged off thinking it will clear with a dose of injector cleaner and a spirited drive. It did clear off for a while but it came back every so often.
    Well..... Today they are basically servicing the injectors at my cost and after today i should have a better indication of whats wrong and if its a long time coming failure ill get the previous owner, dealer, insurance and warranty all into the same pot around a table.
    Dec 2011
    Thanked: 1497
    Quote Originally Posted by ThysleRoux View Post
    +1
    Hehe. You dont like being out of the loop heh?
    Its a standard vw procedure done by vw. They cant hold it against me. Then they may as well through it against me if i dont let them know about a vw service.
    My logic and gut tells me its a faulty injector and/or seal or gummy rings.
    My pessimistic murphy luck devil in my ear says its a melted or cracked piston.
    Eish, and you guys know how i feel about dealers working on my cars........
    Nigel
    Thanked: 1052
    To make sure it is not another DVR type issue here, get an inspection camera. Something you can stick down through that injector hole. Just so you can see if there is scarring on the bore, or even a melted piston.
    If you can, pull the sump and make sure there is no sludge.
    That is an expensive motor, so if it was me, I would pull the head and the sump. Make sure all the injectors are good.
    You never know what the previous clowns used for diesel or oil.
    LC 78 Troopie 1HD-FTE
    Dec 2011
    Thanked: 1497
    I doubt there is sludge. I serviced it twice in the last 6000km i have owned it.
    After the injectors are done I will do a compression test before making any decisions on what to do next.
    The VW workshop foreman tells me this is the first 2.5 engine he's had in their workshop.
    Thanked: 257
    Sorry to hear about your misfortune, really sucks! Hope it's only an injector! The excess oil consumption is a worry, as the injector alone won't do that though. Eish, eish, eish!
    Holding thumbs for you.
    You might need my v6 TDI engine ;(, treg going for hail damage assessment today, - over 300 dents, probably 500. Could be totaled
    2007 Touareg 3.0 V6 TDI (Facelift, Air, Rear Diff Lock, Rear Mounted Spare)
    2008 Audi A4 B8 2.0 TDI (Multitronic)
    2009 KTM 990 Adventure (Daily Commuter & Weekend Fun)
    2012 Imagine Trailvan 4-Sleeper
    * consumption needs to be seen in the context that the vehicle is towing an Imagine Trailvan 50% of the time.
    Dec 2011
    Thanked: 1497
    If the injector's copper seal is gone it can suck oil back into the combustion chamber and blow it back out at force which vaporizes it and the ccv pulls it through the engine.
    I only though of this theory after nursing the car back home from durban. Then tuffstuff came to the party and arranged a flatbed to take it to vw.
    Thanks TS!
    Garsfontein, Pretoria
    Hi Marius
    Sorry to hear about this issue, never nice to have this on a newly bought vehicle...
    I won't stick my neck out here, as I'm more a petrol fan. But, I would like to find out what oil was put into the R5 in these last 2 services? Brand and grade would be good to know.
    Good luck!
    '09 JEEP Grand Cherokee 3.7 Laredo
    * 2.5" OME Lift with TJX XGS Gold Edition shocks
    * Thule Loadbars and Roof basket
    '11 Echo 4 Boswa - Met lekker baie goedjies, myne gemaak!
    Previous:
    '07 JEEP KJ 3.7l Sport - Write-off
    *WARNING* Any posts or comments are intended for recreational consumption, but could contain information that is confidential, privileged or unsuitable for overly sensitive persons with low self-esteem, no sense of humour or irrational morals or social beliefs. If you have stumbled across this post by accident, any dissemination, distribution or copying of its content is not authorised (either explicitly or implicitly) and constitutes an irritating social faux pas. Unless the word absquatulation has been used in its correct context somewhere other than in this warning, it does not have any legal or grammatical use and may be ignored. No animals were harmed in the creation of this profile, although the stoep-kakkertjie next door is living on borrowed time, let me tell you! Those of you with an overwhelming fear of the unknown will be gratified to learn that there is no hidden message revealed by reading this post backwards. I hope you enjoy this post and find if useful. If not, well then get over yourself. Live Without Limits! #JEEP<o</o
    Dec 2011
    Thanked: 1497
    Quote Originally Posted by MonsterKJ View Post
    Hi Marius
    Good luck!
    First service
    Shell helix HX7 AV - 505.01
    Second service
    Fuchs Titan GT1 - 505.01
    Thanks Marius, As I said, I'm no pro here but, If I may...
    Sir Henris; would this at ALL have any resemblance to what happened to DVR (jnr)? (Referring to the info above)
    Oil grade and all that jazz?
    My apologies, a simple google-machine search revealed that these oil are of excellent quality. I'm sure there is no need for alarm on this aspect.
    All the best Marius, hope it gets sorted after the injector wash/swop!
    Previous:
    Dec 2011
    Thanked: 1497
    If I may...
    Oil grade and aal that jazz?
    unless the previous service was done by an idiot.
    The car has a full service history with VW for most of it's life and both oils I used are made to the same synthetic standard.
    As I said Marius, I apologise for that comment. I edited while you were replying.
    Previous:
    Dec 2011
    Thanked: 1497
    no apology needed. You didn't say anything wrong. All opinions are welcome, hence why we post on the forum.
    im trying to figure out now when they are working on it so I can go there and keep an eye.
    Thanked: 257
    I hope you are correct on this.
    The oils you have used are of-course 100%. Think this can be traced back to the slight judder which was apparent from day one of ownership. Did you in any way mention the judder to the dealer?
    I'm going to search the German VW and Treg forums for you and see if I can find anything relevant.
  19. #19
    Dec 2011
    Thanked: 1497
    my search the last week has revealed in order of likelihood
    injector seals
    dud injector
    worn cam lobes and/or lifters
    gummy rings
    failed piston
    I have just sent an email to the dealer who sold me the car, plus the VW garage that took the VW in and made it available as a sale (dealer acted as middleman in a sense), the ombudsman & the warranty company. I copied all in on the same mail so let's see what response I get.
  20. #20
    Thanked: 257
    Ok, lots of info on the R5 on the German forums. Failure of one cylinder in many threads, nearly always associated with the incorrect oil used in the vehicles history somewhere (can be a long time ago). 507 being the most common mistake made.
    The incorrect oil causes the crankshaft bearings to develop excessive tolerance, this leads to irregular sliding motion of the piston/s, whereby the cylinders plasma coating slowly seperates from the cylinder wall with an eventual crack forming in the piston.
    http://www.touareg-freunde.de/archiv...p/t-12850.html
    I do hope it's not the above, and impossible to conclude without compression tests etc...
  1. New Touareg 3, RNS 850 Firmware Update
    By DJMAXIZA in forum Volkswagen
    Last Post: 2017/08/07, 07:03 AM
  2. Tyre life and tread percentage
    By rechardt in forum Tyre chat
    Last Post: 2014/11/13, 12:34 PM
  3. Life - II
    By JDeV in forum The 4x4 Pub
    Last Post: 2014/09/10, 11:33 AM
  4. Touareg Spare and a Prado lurking in the dark
    By amaTokka in forum Volkswagen
    Last Post: 2014/04/24, 08:59 PM
  5. VW Touareg
    By 4ePajero in forum Volkswagen
    Last Post: 2008/05/01, 12:18 PM
