Marius's Touareg R5 life thread. - Page 88
Page 88 of 151 FirstFirst ... 38 63 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 113 138 ... LastLast
Results 1,741 to 1,760 of 3006
  1. #1741
    Thanked: 1993
    Correction. 17mm.
    I used a wheel nut's nut end with thread and flanges ground off with a breaker bar and 17mm socket to get the gearbox's filler plug off.
    All oils changed.
    Car is at 267'000km and....
    Rear diff was dark black
    Front diff was moderate to dark black
    Transfer case was dark black
    Gearbox was medium black
    Glad I changed them all out.
    Attachment 277176
    I think that is the same size as the VW golf gearbox plug?
    4x4AG : GP0314-NW : EXPIRED
    Ela Diablo: Land Rover S2A 109 PUP
    Ex: 2002 Jeep Grand Cherokee Overland 4.7HO
    Ex: 1989 Land Rover 110 3.5 V8 County Station Wagon
    Ex: 1996 Nissan Sani VG30 4x4 SW
    Ex: 1984 Land Rover 110 V8 Pickup
    Ex: 1995 Nissan TD27 4x4 Double Cab
    Ex: 2003 Hyundai Terracan 3.5 V6
  2. #1742
    Thanked: 622
    My Gariep pics
    towed my trailer from Gariep to East London today.
    Doing mostly 105km/h GPS speed. Power was never an issue. It had plenty in reserve.
    I averaged 11.7l/100km
    The windfarm close to Molteno
    Moving camp because I parked in the wrong area
    chevy engined pajero. Man it sounds nice!
    The most flex you will get in an air suspension treg
    every night was clear with lots of stars
    heading out to donkerpoort trail
    yes, I made it after the third try because I forgot how to use the electrickery.
    More to follow when the internet behaves.
  3. #1743
    Thanked: 622
    serviced the car tonight.
    I went through the whole effort of taking the tappet cover off and sacrificing a liter of clean oil to flush all the dirty oil away in the valve train area. I also poured some clean oil in the filter housing to flush the dirty oil out as well. Then after the old oil has drained, I poured about 500ml of clean oil in the filler cap and let that drain as well.
    I'm sure I got most of the dirty oil out.
    I will now check how quickly the oil goes black.
    So far after 5 minutes of idling the dipstick still show perfectly new golden oil.
    I used Shell Helix HX7 AV oil. Shell charged me R84/liter. Goldwagen wanted R185/liter
    It is a 5w-30 oil as opposed to the Fuchs I used before that was a 5w-40. I will report back after my next drive I can notice a difference in the engine, oil temp and economy.
    266523km on the clock now.
    268401km now
  4. #1744
    Thanked: 622
  5. #1745
    Thanked: 622
    I think I found my funny knock on the suspension. I thought at first it was the subframe bolts.
    Seeing as I already did the lower control arm bushes I looked at the top ones and saw this.
    It's moving laterally back and forth. Goldwagen is getting some for me. R150 each.
    Should be an easy swap. Nothing in the way of the arms.
ID:	281819   Click image for larger version.
  6. #1746
    Thanked: 622
    some gariep offroad pictures at donkerpoort
    joining a rope properly to recover a cruiser
    approach angle is good
    steady foot for the traction control makes light work of 3 wheel drive
    Ground clearance
    1.4 bar - yes, the beetle is heavy!
    Not bad flex for air suspension with anti roll bars front and back.
  7. #1747
    Thanked: 622
    my bushes I need to sort out. Notice how easy they move and notice how they don't bounce back.
  8. #1748
    Thanked: 622
    Dad having a feel of my car. Must be harsh driving 5 cylinders when you are used to 10.
  9. #1749
    Thanked: 622
    bought a pollen filter yesterday from goldwagen..... doesn't fit! Can't return it as I mangled it to much trying to make it fit!
    Bought suspension bushes for the front upper wishbones. I ordered 4, Goldwagen ordered 2.
    Strip the suspension, press in the new bush. WRONG BUSH!
    Spend 2 hours removing new bush.
    Needless to say I'm pretty livid at the moment.
    But while it's fresh in my mind here is the procedure for getting to the front upper wishbone. There is no space for the front bolt to come out unless you drop the strut mounting.
    So, jack up the air suspension to max
    hold lock button in console for 10 seconds to get jack mode
    loosen wheel nuts
    jack up the corner and support with axle stands
    remove wheel nuts
    remove wheel
    take off upper balljoint nut and release ball joint with balljoint tool (i unscrewed the nut until flush with thread end and gave a smack with a 4 pound hammer. One shot and it was loose)
    remove sway bar link bottom bolt
    get something under the bottom balljoint like bricks or something and build up so the gap between blocks and balljoint is about 2 inches (this saves the knuckle and CV joints from dropping too far down in the next steps)
    remove the bolt that connects the strut to the lower control arm
    undo one of the 10mm nuts on the level sensor and put it away safe somewhere
    now
    remove the three 16mm bolts in the engine compartment (one is in the rain tray)
    hold the strut bracket with one hand when removing the last bolt
    the strut bracket will now be able to drop down far enough for you to remove the two bolts that hold the upper wishbone to the strut bracket
    Actually not hard at all. I got mine out in about 15 minutes but it feels like a nightmare to me due to the bloody wrong parts issue.
    For reference the bushes that came out of mine are 7L0 407 077
    Both the bushes that came out the front left so far had huge cracks and the center piece was completely loose from the rest of the bush!
  10. #1750
    JHB
    Thanked: 35
    Really enjoy reading all about your work on the Treg, pity about the wrong parts though. Keep it up.
    2012 Bi Turbo 4Motion
    285/70R17 BF Muds, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and no software.
    BMW 1200GS ADV
  11. #1751
    Thanked: 622
    As it stands
  12. #1752
    Thanked: 622
    this is what the bushes look like. I could remove the inner part by hand. It was completely detached.
  13. #1753
    Thanked: 622
    Bush dimensions out of interest
    40mm outer diamter
    10mm inner diametr
    42mm length
  14. #1754
    Thanked: 622
    went searching for bushes in town this morning.
    Couldn't find any.
    Resorted to ordering bushes from Audi (cheaper than VW for the same part..WTH? ) @ R843.60 for the 4 bushes.
    I said I'll take the bushes out of the new q7 on the floor and they can just replace it when the new ones come. They didn't bite
    No car for the weekend. Eish!
  15. #1755
    Thanked: 86
    Thank you for the info Marius, no doubt this will be of interest as my Treg ages.
    Sometimes think how long I'll still keep it. Then I look at what replacement vehicles are available, and my decision is always to keep it. Cannot see anything materially better with which I would be happy.
  16. #1756
    Thanked: 622
    my thinking as well.
    If I trade mine in I have to start fixing a car all over again and it wont be as nice as this one.
    Slowly I'm getting this car in order and then it's a R600k car that I'm driving. I can't buy that now. The only replacement I'll consider is a new ML 250 BlueTec or Cayenne or new treg but that is far out of my budget.
  17. #1757
    Aug 2010
    Thanked: 32
    + a Gazillion on that.
    Chris.
  18. #1758
    Thanked: 622
    sorted the front left upper wishbone bushes today and reassembled the suspension.
    151 photos. 20 seconds apart. 3fps.
  19. #1759
    Thanked: 622
    remember to only tighten everything once the car is at rest in it's normal ride height position.
  20. #1760
    Thanked: 86
    sorted the front left upper wishbone bushes today and reassembled the suspension. 151 photos. 20 seconds apart. 3fps. <a href="http://www.youtube.com/watch?v=wgxTQQaPp_U">YouTube Link</a>
    Cool, all done in 50 seconds.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
