Marius's Touareg R5 life thread. - Page 74
Page 74 of 151 FirstFirst ... 24 49 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 99 124 ... LastLast
Results 1,461 to 1,480 of 3006
  1. #1461
    Thanked: 618
  2. #1462
    Thanked: 618
    I spoke too soon.
    wanted to go to a friend. Got on the highway and it's still missing under load.
    VCDS reveals no codes.
    I suspect it might be the injector harnass.
    Eish. Feeling pretty down now to still have the issue after the breakdown, injector swap for nothing....
  3. #1463
    Thanked: 618
    at light throttle the car is perfect and when stationary it revs up fine as well with no miss.
  4. #1464
    Thanked: 618
    I suspect I know what the issue is.
    Apparently the loom is a common issue on the 1.9 TDi's which is identical to the R5 except the R5 has an extra connector.
    The loom is a very basic wiring system and shares a coomon ground that comes from the end of the loom.
    I suspect due to the fact that the loom sits in a hot oily climate it can be prone to corrosion on the ground connection.
    I think I will just spray some cleaner on the bundle and then some flux and then solder these connections together. Why VW didn't do so from the get go escapes my mind.
    My suspect!
  5. #1465
    Thanked: 618
    Looking at the pics now, I think I should solder the spade connectors as well.
    Do it once right heh?
  6. #1466
    Thanked: 618
    quick question : what is solder's melting temperature?
    I don't want the solder to melt when the engine is working hard.
  7. #1467
    Vredeslof
    For normal solder used in electronics it is around 180 degrees. You also get high temp solder, but its fairly scarce
  8. #1468
    Thanked: 618
    Quote Originally Posted by cacti View Post
    For normal solder used in electronics it is around 180 degrees. You also get high temp solder, but its fairly scares.
    Thanks. Will a solder connection there last the oil and heat cycles inside an engine?
  9. #1469
    Hillcrest, Malaysia
    Thanked: 1482
    Normally about 300 deg C., but I am not going to google for the exact temp.
    Soldered connections are about the worst possible option. Crimp connections are the only option on high reliability circuits.
    If you look at the wiring loom of a Jet Fighter you won't find one single soldered connection.
    ZS5KAD Yeasu Ft-897D
    2 V8's a V6 and an inline 4
    If youíre incompetent, you canít know youíre incompetent. . . . The skills you need to produce a right answer are exactly the skills you need to recognize what a right answer is.
  10. #1470
    Vredeslof
    I don't think oil is an issue... But what temperature does the oil get?
  11. #1471
    Vredeslof
    Fluffy you get HMP solder that is rated at around 300 degrees. Normal solder is around 180 depending on the make. I build a reflow oven for surface mount electronics a while ago and the solder that I used to fix the probe to a temporary pcb melt at 183 degrees. Since solder paste must heat up to around 230 degrees I had to use HMP solder.
  12. #1472
    Thanked: 618
    That's very interesting. I always thought solder was a better connection. Not in terms of reliability but in terms of conductivity.
    I don't want to remove the crimp that is currently there. I want to clean the oil from that crimp connection and add a solder connection on top. Basically put a drop of solder there and blow torch for a couple of seconds to get the soler melting into the crimp connection.
    my main concern is the heat cycles. Can the soldered connection cope with the heat cycles or will it go brittle?
  13. #1473
    Hillcrest, Malaysia
    Thanked: 1482
    Agree 100%.
    I was inappropriately referring to ROHS compliant materials in a specific area of application. Hence the referral to the crimp connections in wiring looms.
    Automated PCB assembly has it's own set of very special materials and requirements.
    Either way, and the point of my post, one would be hard pressed to find a soldered joint on a modern car wiring loom.
  14. #1474
    Vredeslof
    +1
  15. #1475
    Thanked: 618
    do you maintain that a crimp connection is the better connection in my intended application in a hot oily heat cycle environment?
    Perhaps cost is a factor as soldered connections takes more time and costs more than crimp connections.
  16. #1476
    Hillcrest, Malaysia
    Thanked: 1482
    Nope, a proper crimp connection is just far superior in every possible way.
  17. #1477
    Thanked: 618
  18. #1478
    Jul 2010
    Greenstone
    Thanked: 15
    Hi Marius,
    Make sure that the actual injector harness connections are good. I had a miss under load that was traced to the injector connections, I re tensioned the two pins on each injector and the miss has gone for good.
    Those connectors are subjected to heat cycles as well as high frequency vibrations,
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  19. #1479
    Thanked: 618
    Thanks Rowan.
    I had the same idea so I did just that with the harness from the old engine, as well as extra crimping the ground junction.
    I have just changed out the harness and about to go for a test drive.
    Hold thumbs.
  20. #1480
    Thanked: 189
    Thumbs up
    Thanks Rowan.
    Hold thumbs.
    Holding thumbs!
    Sent from my iPhone
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
