Marius's Touareg R5 life thread. - Page 69
Page 69 of 153 FirstFirst ... 19 44 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 94 119 ... LastLast
Results 1,361 to 1,380 of 3060
  1. #1361
    Thanked: 114
    Does it leak where the pipe goes into the elbow? Surely the pipe does not just wedge into the elbow but is secured somehow? If it simply slides in there, I'd go the Pratley Epoxy route and mould the stuff all around it. Possibly add another connection to the pipe (thinking from LPG gas fitting with a hose-clamp) and extend the pipe, thereby you do not mess up the original pipe should the epxy prove to be not permanent.
  2. #1362
    Thanked: 947
    It leaks where the brass nut meets the plastic elbow.
    If i had no option i would epoxy the whole thing but that makes it difficult to reverse the fix.
    I like oem fixes so im trying that first.
    Sent from my iPad 2
  3. #1363
    Thanked: 114
    I'm the other way around, DIY then OEM... but you farming guys have all the moola for OEM, Julius is right.
    How does the pipe connect to the elbow part? Screw in?
  4. #1364
    Thanked: 947
    If only I was a rich farmer.....
    Far from it.
    The part costs next to nothing. It's the pain of getting it to me quickly, so I can get back home on Sunday to start work Monday, that's the issue.
    Sent from my iPad 2
  5. #1365
    Douglas
    Maruis ek verstaan jy is in Douglas. Ek bly hier. Bel my 0828227898
    2007 Pajero 3.2 DID GLS OME : 2005 Echo 4
  6. #1366
    Thanked: 947
    Quote Originally Posted by janzu View Post
    Is dit jou wit pajero met FWN registrasie nommer wat buite staan op die hoofpad.
    Sent from my iPad 2
  7. #1367
    Jul 2010
    Greenstone
    Thanked: 41
    That looks very similar to a pneumatic push on fitting, I have a suspicion that a decent hydraulics shop may be worth a call, there is a seal that allows the elbow to swivel on the threaded bit. It looks like a standard 1/8th fitting.
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  8. #1368
    Thanked: 114
    Did you get the part? Assume you are on the road heading home?
  9. #1369
    Thanked: 947
    I tried various places. Douglas is a mining and farming community and they do t keep that small size.
    The part that was sent from cape town was mistakenly sent by the secretary via normal overnight instead of express overnight so the friday shipment will only be here monday.
    I couldnt find a means to get the bloem parts to me.
    So, when the part arrives tomorrow, i will fit it and test the suspension. If that was the issue i'll head home via bloem to get the other part as a backup as the one from cape town is second hand.
    If there is another issue with the car tuffstuff will have to be called upon to get me and the car home.
    Sent from my iPad 2
  10. #1370
    Thanked: 947
    Leak fixed. Ecu not happy about car level.
    New error via vcds. Vehicle extremely un-level.
    Will play a bit more later, else insurance call tomorrow.
    Sent from my iPad 2
  11. #1371
    Thanked: 947
    I couldn't give up.
    I played around with vcds and eventually found a function that activates the air suspension with ignition on and engine off.
    I heard a hiss and traced it to under the fuse box in the engine bay in the rain tray.
    A bliksemse f**** rot het die front left air pypie vir aandete gehad.
    I'll get a push lock fitting tomorrow and join the pipe again.
    So, it wasn't the car's fault after all. It was mother nature and it could have been any car's vacuum pipe, fuel pipe or wiring.
    Sent from my iPad 2
  12. #1372
    Northcliff
    Rats rearranged my wife's X3 engine bay a couple of years ago as well.
    What can one do as prevention?
    Common Sense is so rare it is like a Super Power.
  13. #1373
    Pinetown
    Thanked: 63
    Ai man.
    As die kar jou nie pyne gee nie klim die natuur in.
    Rotte en muise kan gaos veroorsaak, vriende moes die kar herbedraad en paneel klop werk doen.
    Rot het die een draad gekou, kortsluiting veroorsaak en die huidige met die ewige verwissel.
    Ongelukkig het die aansitter begin draai en die voertuig laat vorentoe loop in die werksbank in. Ligte, sier rooster en buffer vervanging was die uit einde.
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop, net jammer ek moet werk om te oorleef
    2017 BL - Kewer B1115 - op bestelling, aflewering einde Nov 2017
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - bos en kamp tyd => in die mark/te koop
    2010 Ford Ranger 2.5 DT DC XLT - rondloop ry ding met bietjie ekstra krag (Verkoop)
    2005 Chev Aveo - Afgeskryf (2016)
    2005 Opel Corsa 17DTi - Geruil (warm enjin)
    2003 Opel Corsa 17DTi - Geruil (warm enjin)
    2000 Nissan Hardbody - Geruil (pyne by die duisended)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998
  14. #1374
    Thanked: 947
    Goeie genugtig, so ek het eintlik niks om oor te kla nie
    Sent from my iPad 2
  15. #1375
    Thanked: 114
    I know in Germany people have big issues with rodents called 'Maders'. You get ultrasonic devices which run off the vehicles battery (very low consumption), which deters them.
    Consider it revenge for this:
  16. #1376
    Thanked: 947
    All buttoned up. All good.
    Sent from my iPad 2
  17. #1377
    "Two things are infinite. The universe and human stupidity. ..... and I'm not so sure about the universe"
    Albert Einstein
    If you see spelling mistakes in my posts, use as many of the goodies below as required to fix it!
    ABCDEFGHIJKLMNOPQRSTUVWXYZ
    abcdefghijklmnopqrstuvwxyz0123456789
  18. #1378
    Thanked: 947
    Amazing how a car can cause so much stress and so much relief at the same time.
    Sent from my iPad 2
  19. #1379
    Thanked: 947
    Ok, so the beetle wasn't going to let me off that easy.
    Big judder from the engine. Feels electrical. Intermittent.
    Pull over and scan via vcds. Speed sensor G28 implausible signal. I know that's the one by the power steering pump. I jack up the car via the (now working) air suspension and climb underneath to check the plug.
    I fiddle with the plug and the engine dies.
    Limp 10kms to steynsburg. Find a workshop, gather three male and three female crimping lugs. Cut off the connector at both ends and join the wires.
    All good now. Heading on.
    What next? At least it's all small stuff to be expected from an ageing car.
    Sent from my iPad 2
  20. #1380
    Jul 2010
    Greenstone
    Thanked: 41
    I agree with the small things causing big stress.....after my water pump oil leak, everything was fine untill this week she started dropping oil again. I initially had that sinking feeling, but after investigation found that the sump insulation was still full of oil from the original leak (the tell tale pipe is tucked into the insulation) After this weekends long drive and off road driving, the oil had clearly shifted in the insulation and was now dripping from the sump plug cut out. It is amazing how a small ammount of oil looks so big when its on concrete.
    To put my mind at ease I taped a small plasic bag onto the tell tale pipe and left it in a visible position. There is no oil in the bag therefore the water pump is fine. I should remove the insulation and clean it out but it seems like a tricky job with the crossmember in the way
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
