Marius's Touareg R5 life thread. - Page 5
Page 5 of 151 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 30 55 105 ... LastLast
Results 81 to 100 of 3006
  1. #81
    Innie Kaap
    Thanked: 523
    Quote Originally Posted by bvandyk View Post
    Is it ethical to expect them to pay if they didnt know about the problem?
    If the reports from the original VW dealer and the indy's that checked it out shows a clean bill of health, Marius will obviously not have a claim, but unless he lodges one, this may never be disclosed.
    I'm not saying that the seller must just cough up, guys. All I'm saying is that the CPA is there and Marius should make use of it - win or lose.
    4.7lt V8 Grand Cherokee LTD (WJ)
    082 975 9746
    thysleroux(at)mweb.co.za
    RooiTjiep OVERHAULED - Forum Style
    I refuse to be POLITICALLY CORRECT just for the sake of being accepted by others - DEAL WITH IT !!!!!!
  2. #82
    Thanked: 72
    Quote Originally Posted by ThysleRoux View Post
    .....then 200 voice will scream - they are useless anyway, Rattax! And 25 guys will share their experience with indy's and the AA
    Overkill - isn't!
    uys@stofpad4x4.co.za
    www.stofpad4x4.co.za
    Why you need Stofpad4x4 Rock sliders
    Office: 012 654 7723 (sales)
  3. #83
    Thanked: 610
    As a matter of interest... Did you use 2SO?
    One tank about halfway into ownership
    Oh, and why did you take it to the dealers and not an indie?
    Warranty requirements
    I'm awaiting the inspection reports. Any contradictory finds and I win
    If everything checks out then I just have the tiny warranty to fall back on.
  4. #84
    Innie Kaap
    Thanked: 523
    LOL
    I would assume the VW dealer, at least, will have proper diagnostic reports, including compression tests.
    082 975 9746
  5. #85
    Thanked: 72
    LOL
    I'm supplying the tester as I have a rubber grommet tester as opposed to their glowplug removal steps tester.
    Ja!!! Maar met watter meter is dit gemeet?
    Alle grappies op 'n stokkie. Verlies van druk word veroorsaak deur: (en help my uit hier)
    1. Ringe wat pap geword het
    2. Ringe wat gebreek het (eeuwwwww)
    3. Valves wat lek
    Ek kan nie sien hoe een van hulle 'n intermittant vibrasie kan veroorsaak nie?
    Overkill - isn't!
  6. #86
    Jan 2009
    Thanked: 29
    LOL
    Do you really think they do diagnostic reports and compression tests on every vehicle before they sell it?
    I highly doubt it.
    Good luck Marius, I really hope this thing gets sorted 100% by VW and your warranty
    Land Rover Defender 100 PU V8
    Jaguar XF
  7. #87
    Innie Kaap
    Thanked: 523
    3. Valves wat lek
    Die silinder "lining" wat beskadig is, soos wat hier vermoed word - en die lae kompressie kan 'n vibrasie veroorsaak.
    @bvandyk - As Volksie 'n voertuig inruil en daar is 'n enjinvibrasie aanwesig, sou hulle blÍrrie stupid wees as hulle dit NIE doen nie !! Ek vermoed die handelaar wat dit aan Marius verkoop het, het van die vibrasie geweet - hoekom anders sou hy die Treg by DRIE indy's laat nagaan het ?
    082 975 9746
  8. #88
    Thanked: 610
    the gunk on the injector tips led me to believe that the gunk on the rings were keeping compression and making it intermittent.
    My long distance driving probably cleared the rings of gunk that kept the compression moderately.
  9. #89
    Thanked: 610
    The plot thickens as well.
    VW East London says that the engine need to go to Tavcor PE as they (EL) don't have the necessary equipment to strip the engine.
  10. #90
    Jan 2009
    Thanked: 29
    And by the use of 2SO
    Jaguar XF
  11. #91
    Innie Kaap
    Thanked: 523
    What is VW's official take on the use of 2SO ?
    082 975 9746
  12. #92
    Jan 2009
    Thanked: 29
    Eish what are we starting here
    Jaguar XF
  13. #93
    Innie Kaap
    Thanked: 523
    You did
    I'm just concerned that they may blame the use of 2SO for the damage, if they have a policy AGAINST the use.
    082 975 9746
  14. #94
    Thanked: 610
    if it was 2SO, why only the one cylinder?
  15. #95
    Robertson/ Larissa, Greece
    Thanked: 420
    On VW diesels a faulty injector often cause a vibration, sometimes to the extend that one would think an engine mounting or wheel balancing is the problem. Very weird feeling.
    My take on this is that an injector started to fail, caused overfueling and that let to the piston seizing in the bore causing low compression. Hope I'm wrong but have seen it more than once.
    To achieve greatness, stop asking for permission!
  16. #96
    Innie Kaap
    Thanked: 523
    I'm not saying it is the cause, Marius, but a dealer in a bind, could use anything to get out paying big bucks. Must be the cynic in me, but I don't trust any dealer workshop.
    082 975 9746
  17. #97
    Nigel
    Thanked: 508
    Sounds about right.
    Bad spray pattern.
  18. #98
    Thanked: 610
    my initial thought was an injector, however a compression test revealed very low compression on cylinder no5
  19. #99
    Thanked: 420
    Marius, read the second part of my post again
  20. #100
    Thanked: 610
    sorry, missed that part.
    Looks more and more like I have to find R60k for an engine from remtech and do the swap DIY.
    At least you guys will get a build thread that hasn't been documented online before.
    Problem is to find the R60k.... Eish.
    I'll have a venter trailer, quad bike in the classifieds soon to help fund the engine.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
