Marius's Touareg R5 life thread. - Page 53
Page 53 of 153 FirstFirst ... 3 28 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 78 103 ... LastLast
Results 1,041 to 1,060 of 3060
  1. #1041
    Thanked: 947
    I celebrated too quickly. I should've known that the car wasn't losing cooling slowly.
    Car is not cooling again. At least I know there is dye in so will check when I get home for leaks.
    Let's hope I find the leak in an easy place!
  2. #1042
    Thanked: 947
    This is the reason why I don't take my cars to dealers!
    When they initially had the car to diagnose the failing engine they dropped this screw down into the radiator area where it wedged between a cross brace and the condensor.
    I know it wasn't me as I didn't work in that area, and I kept track of every nut, screw and bolt!
    Over time it chaffed through and now I have a leak on the condensor!
    Bliksems!
  3. #1043
    Thanked: 114
    Good thing you found it now. Very similar to what happened to mine after the panelbeaters. Incorrectly routed pipe chaffed through the condensor. Hope the condensor can be repaired.
  4. #1044
    Kleinmond
    Thanked: 64
    Bliksems!
    I did not know you know french.
  5. #1045
    Thanked: 947
    I am hoping the system can be evacuated, the chaffed area soldered/brazed in situ and then vacuum pulled and re-gassed.
  6. #1046
    Thanked: 114
    My condensor had to come out for the repair. Whole job took one day. They charged me R 2 200 in total.
  7. #1047
    Klerksdorp
    condenser is usually a consumable... maybe if someone is lus to weld it, luckily it is not a essential part of the engine so you can give it a try
    "Blue Thunder"
    Gert Ferreira
    Echo4 trailer
    Forum Radio No: 1052
  8. #1048
    Thanked: 947
    I have seen a few radiator repairs done by professionals. I'm confident (and hopeful) this can be done in situ.
  9. #1049
    Thanked: 947
  10. #1050
    Klerksdorp
    that cant be easy to repair
    "Blue Thunder"
    Gert Ferreira
    Echo4 trailer
  11. #1051
    May 2007
    Daar by die gat,in die NK
    Thanked: 47
    took it to an A/C specialist who said the gas was just a little low. Like a balloon will slowly lose it's air, the same with a car's aircon gas.
    So R200 for a topup of gas and UV dye. Let it run for a while and check for leaks.
    No leaks and it cools better than ever. All in all a big relief!
    Quote Originally Posted by kevman View Post
    I don't know who told u that Marius but that not true that a A/C sould not leak gas slowy like a balloon.
    Kevman out
    Kevman is correct, a system don't loose gas, but on car aircon system it does, normally via the compressor pulley, especially when it is not in use for a while (Perhaps the time you changed the engine on the treg) the seal on the pulley of the compressor become dry and loose gas ,when you use it again it lubricates and the leak disappear.
    No one ever ruined their eyesight by looking at the BRIGHT side!!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Nissan King Cab (aka Navara )
    Albert Einstein
    Whoooopa 3 The Goat strike back
    https://www.youtube.com/watch?v=uqw5...ature=youtu.be
    Another teazer.....
    https://www.youtube.com/watch?v=51KljMSXOnI
  12. #1052
    May 2007
    Thanked: 47
    a better picture
    Eish hy gaan baie moeilik sweis, sterkte....ons het op die yskaste se evaporators altyd so epoksie stick gebruik om lekke dig te maak, maar dit was op die laedruk kant, hierdie is hoer druk en ek dink nie dit sal hou nie, wat kos nuwe condenser?
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Albert Einstein
    Another teazer.....
  13. #1053
    Thanked: 947
    Quote Originally Posted by Frans Reichert View Post
    Problem found already.
  14. #1054
    May 2007
    Thanked: 47
    Het gesien (sien post bo) ek praat eindlik oor die algemeen van automotive aircon stelsels, wat gewoontlik na die winter gas kort.
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Albert Einstein
    Another teazer.....
  15. #1055
    Maruis. Daar is alu welding rots op die mark wat jy met n porta pack dan weld teen n lae temp. Kyk by Afrox, weet nie wat dit kos nie. Ek het al n paar so reg gemaak. Dit is nie die maklikste job nie. As jou vlam te warm is gaan jy jou coil stukkend brand in n oog wink. So wees gewaarsku as jy die roete gaan in DIY. As die lek reg gemaak is doen u druk toets. As daar geen lek is nie, trek al die lug uit met 'n vac pump. Kry vir jou 'n skaar en skaal die regte hoeveelheid gas in. Neem aan dit is 'n R134A system.
    Kevman out
    2007 Disco 3 TDV 6 S SWAMBO
    2013 Ford T6 3.2 Super-cab
    2008 Fiat Panda 100HP
  16. #1056
    Thanked: 947
    Ek het daai rods op die internet gesien maar ek het niks experience op dit nie en wil ook nie school fees betaal nie.
    Ek het 'n quote van 'n ou wat al 'n paar van my karre (ek het nog nooit 'n kar gehad wat nie AC issues gee nie ) by hom gehad.
    Hy het my R1500 gekwoteer om condensor uit te haal, tube af the block, reassemble en te gas. Klink na 'n bargain in my ore maar op die stadium moet dit maar wag. Ek's *** broke!
  17. #1057
    Thanked: 947
    this car handles bloody good! It doesn't look heavy on the video but trust me it was close.
    The touareg handled it with ease. No drama, no tyre squeal, and I don't recall seeing the ESP light blink.
  18. #1058
    Thanked: 947
    I am now in a predicament.... sort of
    AC was working 100% and then stopped working. Take it in for a check which shows low gas. Topup and bob's my uncle till the next day.
    Search with UV light and found the leak on the condensor (see previous posts)
    Send car in.
    The take the condensor out, fix it, put it back, pressure test checks out 100%. Evacuate and gas. No cold air.
    He changes the solenoid valve on the pump (no clutch here - a solenoid valve controlled by the ecu allows or restricts gas flow - the pump has an inherent oil system like a car's sump - separate from the refrigerant system) and tells me the pump looks clean with no signs of ageing wear.
    Still no cold air.
    So I shoot over, clear the codes which was obviously present due to the repair.
    Still no cold air
    I recode it via vagcom to ignore the refrigerant sensor (even though errors didn't come back after clearing)
    Still no cold air.
    No the guy tells me he reckons the pump failed. So I jump on my horse and ask him how the hell he reckons the pump failed if it was working before and when he found no debris of any sort in the pump to suggest a failed pump)
    Pressure is good
    Solenoid valve gets voltage and clicks
    compressor rubber coupling is good
    measuring blocks on vagcom shows ecu is engaging the AC pump
    vagcom doesn't show any returning errors
    Now I'm stumped as well as the AC guy so they are getting a VW/Audi electrical boffin out there tomorrow.
    Any ideas?
  19. #1059
    Thanked: 114
    I know it's very sensitive to the quantity of refrigerant, - needs to be filled by weight to exact spec.. Also perhaps condenser now has a blockage/restriction?
  20. #1060
    Thanked: 947
    I have just studied elsawin and I suspect they didnt turn the pump by hand a few times after filling and when they started the car the excess oil in the pump caused the overload protection device (it sits between the freewheel and the pump - looks like a jaffle maker) to sheer due to the pump not being able to compress the oil like a hydrolocked engine ( the R5 pump is always turning, there is no clutch. Only a solenoid valve that controls refrigerant flow) the pump has 50-80ml of oil in the pump sump to prevent dry running in the case of refrigerant loss.
    Thank goodness for this overload device otherwise the pump or the coupling would be toast! I hope you can get spares for it.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
