Marius's Touareg R5 life thread. - Page 52
Page 52 of 153 FirstFirst ... 2 27 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 77 102 152 ... LastLast
Results 1,021 to 1,040 of 3060
  1. #1021
    Aug 2010
    Quote Originally Posted by Chriseleven View Post
    On a related topic - can the fuel consumption readout be re-calibrated. Looks like VW set the computer to flatter themselves. My actual consumption is well above what the vehicle calculates.
    Calibration may be an issue
    My screenshot attached and Fuelly at bottomName:  ImageUploadedByTapatalk1367234178.772587.jpg
    4S
    2006 T5 4Motion 174HP TDI Seikel Dakar STOLEN IN KALK BAY
    2013 T5 4Motion 180HP TDI Seikel Desert HD Wearing bush stripes with pride
    A6 3.0 Multitronic 225HP
  2. #1022
    Aug 2010
    Don't know how you manage to keep your speed down when the treg is so comfortable cruising at silly speeds. Wish I had a bit more self control
    Use cruise control and buy a steak or toy with savings
    4S
  3. #1023
    Jun 2012
    Thanked: 152
    Same issue for me, OBC is typically about 2L/100km optimistic on my consumption.
    2012 Q7 4.2 TDI
    Birkin SR20DET race car
  4. #1024
    Jun 2012
    Thanked: 152
    Quote Originally Posted by parafanaylya View Post
    4S
    I constantly use the CC, but just cannot get myself to set it 120km/h, it is usually set at about 125km/h actual speed (130km/h indicated). I know the extra speed does not have a big impact on journey time but does have a significant impact on fuel consumption due to the size of the car.
    2012 Q7 4.2 TDI
  5. #1025
    Thanked: 19
    Weirdly in my Treg, the onboard computer says I am averaging about 12.5l/100km, but when calculated on Fuelly I get less than 11....
  6. #1026
    Thanked: 947
    Yes, onboard display can be adjusted via vagcom.
    However, it's usually accurate so have the injection quantity deviation checked to make sure the injectors aren't out of spec.
  7. #1027
    Aug 2010
    My T5 4Motion indicated speed/consumption
    120: 10.6/100
    116: 9.6/100 (actual 120)
    100: 7.4/100
    I travel @ 116 and save about R100 per tankful. Ie since Jan 2013 21 tanks. Belongs to me, not the sheiks.
    4S
  8. #1028
    Thanked: 947
    I managed 8.5l/100km back from Douglas to East London.
    100km/h average on the MFD which included about 100km gravel, 2 stop and go's and 3 nature breaks. I ten to drive between 120-130km/h indicated which is about 115-125 actual.
    I find I drive way more economical than the cruise control. If I use cruise control the consumption average quickly climbs.
    At one point I passed a new land cruiser V8 that was towing an offroad caravan at 140km/h. I was behind it in Queenstown and was trying hard to get past it. (I wanted to see the caravan and car combo better, hence the speed so don't bludgeon me, it was just a pass - he later came by me again when I settled back to my own speed).
    Now I know that car can comfortably tow at that speed, but hell.... an evasive maneuver and that trailer becomes VERY heavy!
  9. #1029
    Lonehill, JHB
    Thanked: 413
    Ja, that is not safe at all
    2014 Pajero 3.2DiD SWB
    2008 Pajero Gen4 3.2DiD LWB - SOLD
    2016 Nissan Qashqai 1.2T Acenta
    Metalian Maxi
    4x4AG 0110
  10. #1030
    Aug 2010
    agreed, but I prefer cruising and not worrying about the speed. A little more relaxed, and not as tiring
  11. #1031
    Thanked: 947
    Great. Aircon stopped working today.
    Checked the gas filled ports and there is some gas in there
    Checked with UV light for leaks - can't see any
    VCDS scan reveals no codes
    Fuses are fine
    Rubber coupling is fine
    Output test via VCDS reveal the radiator fans are working
    With the AC on the hot side gets hot and the cold side gets slightly cool so maybe the gas is low. Any ideas from anybody before I send it in?
  12. #1032
    Feb 2012
    Kokanje.Modimole
    Julle ry te vinnig! Was die week van Modimolle na Harrismith en terug (895km). Waar ek kan ry ek @ 2200rpm. Lyk my so 106km/uur.Brandstofverbruik; 12,9km/l (7,75l/100km) ligter op remblokkies en loop heelwat koeler. (R5 Tdi 2004 met 270000km). My ouderdom laat toe dat ek so stadig kan ry.As ek reg onthou was die gem.spoed 91km/u)
  13. #1033
    Port Shepstone
    Thanked: 131
    Marius I remember on my Carravelle I had a similar problem when the "kinetic coupling" to the AC pump failed.
    What a life!
  14. #1034
    Thanked: 114
    All I can say, if the aircon needed a refill (which would indicate a leak), the VCDS will report this from my own experience, so I think the issue is a different one.
  15. #1035
    May 2007
    Daar by die gat,in die NK
    Thanked: 47
    Fuses are fine
    Kyk of daar 'n klein tank is langs die condenser, daar behoord 'n "sight glass" op te wees. kyk of die gas borrel as die aircon aan is.
    Maar die suction pyp (dik een) moet sommer lekker koud word. Ek reken hy kort gas. Het jy nie die pomp geontkoppel nou met die hard oorplanting nie?
    No one ever ruined their eyesight by looking at the BRIGHT side!!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Nissan King Cab (aka Navara )
    Albert Einstein
    Whoooopa 3 The Goat strike back
    https://www.youtube.com/watch?v=uqw5...ature=youtu.be
    Another teazer.....
    https://www.youtube.com/watch?v=51KljMSXOnI
  16. #1036
    Sep 2011
    Quote Originally Posted by Treg View Post
    Sjoe, 270k KMS!!!
    Jy ry lekker baie rond....en ons almal weet hoekom...want jy kan in gemak en styl...
    Dis wonderlike nuus, ek het juis nou die dag gewonder hoe dit nog gaan met jou en die blou Treg...
    Ek is bly al die probleme is mooi op gelos en iets van die verlede.
    Nog net 200 KMS dan is my TReg op 170k KMS.
    Ek hoop regtig myne gaan ook baie goeie diens en plesier lewer in die toekoms.
    Groetnis,
    2005 VW Touareg R5 TDi (Daddy's cool ride)
    Electric Jeep Super (Little-SWAMBO's ride)
  17. #1037
    Sep 2011
    Fuses are fine
    I assume you most probably did, but you check for a blocked pollen filter?
  18. #1038
    Thanked: 947
    took it to an A/C specialist who said the gas was just a little low. Like a balloon will slowly lose it's air, the same with a car's aircon gas.
    So R200 for a topup of gas and UV dye. Let it run for a while and check for leaks.
    No leaks and it cools better than ever. All in all a big relief!
  19. #1039
    Thanked: 114
    Happy for you, - strange it did not show on VCDS. Mine threw a fault on the low coolant situation. Might be different on the R5 then.
    Don't quite agree with the lose gas slowly story. It should not, if it is, it has a leak. The leak is probably too small to detect in this case.
  20. #1040
    I don't know who told u that Marius but that not true that a A/C sould not leak gas slowy like a balloon.
    Kevman out
    2007 Disco 3 TDV 6 S SWAMBO
    2013 Ford T6 3.2 Super-cab
    2008 Fiat Panda 100HP
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
