Marius's Touareg R5 life thread. - Page 47
Page 47 of 153 FirstFirst ... 22 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 72 97 147 ... LastLast
Results 921 to 940 of 3060
  1. #921
    Thanked: 114
    Nice video, understand it 100% now. Had a look at my V6 TDI... yes much more complicated, - still researching.
  2. #922
    Thanked: 114
    Think I got lucky, just figured out that on my V6 TDI, which is still the BKS (165kw) engine code, the EGR is the vacum type. The CASA (176kw) are all electronic.
    Marius, in the attached diagram, I need your help understanding this piece of machinery. What is part 15 opposed to part 30. I assume I need to plug hose 4 opposed to hose 14... or both?
  3. #923
    Thanked: 947
    Just blank number 4.
    Number 14 is a vacuum diaphragm that actuates a butterfly in the egr cooler to determine how much coolant is sent through the cooler.
    Can you pull your intake hose to have a look at how clean your intake and/or throttle body is?
  4. #924
    Thanked: 114
    I'll have a look. So possibly, I could shut down the cooler with that valve. The EGR cooler is a part that is known to fail on BKS V6 TDI's.
  5. #925
    Thanked: 947
    Not that simple. Thats just a diverter valve.
    To truly eliminate you will have to bridge the two coolant pipes that go in and out of the cooler. Blank the vacuum pipe. If the cooler doesnt have a oil feed then you can remove the cooler altogether.
  6. #926
    Aug 2010
    Thanked: 52
    V6 TDi engines aren't known to fail so you may be OK, but if you have the itch..... have it done!
    Problem is I suspect the V6 TDi has post CAT sensors that will need fooling or need to be mapped out.
    This is what I have been told by the "dealers" and I was strongly advised NOT to have it removed.
    Chris.
  7. #927
    Thanked: 947
    I decided to take the air filter out tonight and dust it out a bit.
    How's this for a bit of clever design.
    Air comes up out of that tube in the middle and hopefully any water will back to the bottom and drain out.
    You really have to scoop a lot of water to get water in the engine.
    Pictures of the airbox with filter and front cover removed.
ID:	201504   Click image for larger version.
  8. #928
    Vereeniging
    Hi all, i called Tim he can only see me on the 8th April, so since AR said they can not sort it out, decided since the car will be standing for 3 weeks why not give it to another auto elec. and gues what he sorted all my electronics out, lights, PDC everything 100%, after 3hrs that he worked on the car, WTF... what did the previous auto elec. do?
    Only problem still now is the high vibration that comes from the motor, he said it can be from the injector side, timing adjustment, etc. But also maybe from the balancing on the crankshaft, what do you guys recon. The engin mountings is 100%. I am so close of driving that silver baby..
    When i dropped it of at the auto elec. I stood for a few seconds to admire the sight of the Treg standing on dirt road and the goodrich tyres makes a great visible impact.
    A beautifull sight indeed, just there i remembered why i bought it.
    I guess this is like a marriage you take with all the good and the bad....
    Missing Treg keep eyes wide open
  9. #929
    Thanked: 947
    Quote Originally Posted by AntonvBosch View Post
    A vibration makes me have a furious cold sweat. Have a Vagcom scan for errors as well as injection quantity differences across the injectors.
    Also have a compression test done.
    I hope you don't walk my walk. It isn't nice!
  10. #930
    Thanked: 947
    A better pic of the culprit
  11. #931
    Thanked: 947
    and another better pic
  12. #932
    Thanked: 947
    East London to Kokstad. All good.
  13. #933
    Thanked: 947
    came back yesterday and the car kept that average of 8.9l/100km for the entire trip to Durban and back through roadworks, roadblocks and speedbump temp roads.
    All in all my confidence in the car is coming back.
  14. #934
    Thanked: 114
ID:	203895Nice, glad it's going well.
    My Treg also had a full long weekend, 2000 km's in total: JNB - Malelane - Satara - Orpen - Mopani - Malelane - JNB.
    No problems, average consumption 10.00 l / 100 km. Including KNP driving slow on the dirt roads, and crazy traffic back home yesterday. N4 is a disaster just after Nelspruit.
    Even spotted a forum members Treg in the KNP - Devon's R5 (attached)... Devon, you are a very kind sibling to let your brother take your Treg to Kruger!
  15. #935
    Sep 2012
    +1
    "If you want something you've never had, you have to do something you've never done"
    2007 VW Touareg 3TDi V6 with air suspension
  16. #936
    Aug 2010
    Thanked: 52
    How was the game-viewing?
    Chris.
  17. #937
    Thanked: 19
    I wasn't using the Treg as I was in Ithala NP in a friend's Prado for the weekend, so I let my brother take it through to Kruger. He mentioned that he saw you there and got a nice photo of our 2 Treg's parked side by side, I will upload it later tonight
  18. #938
    Thanked: 114
    Chris - Game viewing was good, lots of Rhino... think they are fleeing the eastern border. Lots of Lion, Ellies, Waterbuck, Hippos. Few sightings of Ground Hornbill, and I had a midnight encounter with a Honey Badger trying to raid our stuff... confronted him, - forgot how agressive they are. Won't be messing with one of those again.
    Devon - cool, looking forward to the photo . Just FYI, your brother was driving nicely
  19. #939
    Thanked: 19
    Kortgat, here's the photo from Kruger.... Can't remember what campsite it was at...
  20. #940
    Thanked: 947
    Quote Originally Posted by DevonEllett View Post
    Man that's pretty!
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
