Marius's Touareg R5 life thread. - Page 34
Page 34 of 153 FirstFirst ... 9 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 59 84 134 ... LastLast
Results 661 to 680 of 3060
  1. #661
    Centurion / Pretoria
    Excellent, very well done.
    That you as well for taking us along on the journey.
    May you get many happy Km from that engine.
    Peet
    2011 VW Amarok BiTDi 4Motion
    2013 Metalian Maxi
    0319
  2. #662
    Thanked: 46
    Brilliant Marius!!!!
    Enjoy driving the Treg again!
    Cheers,
    Jean
    '98 Defender 90 2.8i aka "saad van die psigopaat"
    Defender - http://www.youtube.com/watch?v=y0YKlc8Cwrs
  3. #663
    Witbank
    Thanked: 7
    Default What is next?
    Well done.
    OK, same as your old Gen 2 Pajero. Fix it 100% then sell it. Will you be going back to Mitsu again Marius
    "If you can park your car and NOT turn around to look at it as you walk away, you haven't bought the right car"
    Fancy Nancy - 2009 Pajero 3.8 Liter 24 Valve V6 SOHC MIVEC ECI- Multi Engine 6G75 with 184Kw & 329 Nm.
    Topless Tersia - 96 J-Top SWB 3.0 V6 Pajero. Restoration 99% completed.
  4. #664
    Thanked: 947
    Quote Originally Posted by Renier.deJongh View Post
    Well done.
    I dont think I'll sell it. I told Shalene my next purchase is a new treg or a cayenne, or if mitsu brings out that v6 diesel.
    Until then, I have to just keep this one going.
  5. #665
    Thanked: 15
    Eish - wat sę mens? Ek het sommer 'n knop in die keel gekry toe daai enjin so mooi luier en daai vuiste tref die lug.
    Goed gedaan, Marius. Ek hoop van harte dat dinge nou net voorspoedig sal afloop vir jou.
    Bite off more than you can chew - then chew!
  6. #666
    Thanked: 114
    The Treg sounds like a tractor in that tin shed it is in, especially on some of the early start attempts. When it finally runs smooth, it must have been music to your ears.
    Have you driven it at all? What remains to be done except the bodywork?
  7. #667
    Thanked: 947
    I still have to topup the oil - it's on the low side of the dipstick after the start.
    I need to topup the coolant - antifreeze is in but I need to get the system going and add distilled water
    After that, scan for errors, check for leaks, install the bash plate and then go for the bodywork.
  8. #668
    Thanked: 947
    The finished product with a clean engine cover
  9. #669
    Thanked: 33
    looks mooi. well done
    I have never seen a wild animal feeling sorry for itself.
  10. #670
    Nigel
    Thanked: 769
    Very neat.
    Have you taken it for a run yet?
  11. #671
    Thanked: 947
    Very neat.
    Not yet. Getting some oil today to topup and water to topup antifreeze. Then it's getting it up to temp to check for leaks and problems.
  12. #672
    May 2007
    Daar by die gat,in die NK
    Thanked: 47
    Baie geluk en well done!!
    No one ever ruined their eyesight by looking at the BRIGHT side!!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Nissan King Cab (aka Navara )
    Albert Einstein
    Whoooopa 3 The Goat strike back
    https://www.youtube.com/watch?v=uqw5...ature=youtu.be
    Another teazer.....
    https://www.youtube.com/watch?v=51KljMSXOnI
  13. #673
    Nigel
    Thanked: 769
    Your approach is 100%
    Jou pa het jou def reg gemoer......
  14. #674
    Oct 2012
    Thanked: 11
    Well done Marius - and thank you for taking the time to share this with us
    VW Touareg 3.0 V6 TDI (Terrain Tech)
  15. #675
    Fourways
    Get the cayenne. thats my next one.they can take you further than you think
  16. #676
    Thanked: 114
    Marius, did you perhaps come across the location of diff breathers when you did the work. I know there is one next to the air-filter box, presumably for the front diff. I'd like to understand where and what height the breathers for centre and rear are located? Any idea?
  17. #677
    Thanked: 947
    As far as I remember the gearbox and rear diff run along the top of the gearbox. I didn't touch them so not sure. The one by the airbox is the front diff breather.
  18. #678
    Thanked: 947
    I had the scare of my life today. Filled up oil and coolant. Started it and let it idle for a few minutes to get the temp up.
    I then pushed the revs to 2500rpm and the oil pressure warning came on.
    I thought logically about it, even while scared shitless, and checked the connector on the oil pressure sensor located on the alternator side of the engine, just above the oil pan line on cylinder one (front of engine).
    Connection seemed loose so i clicked it in further. Tried the rev again and same story. I lost hope.
    A thought jumped to me. I got the previous oil pressure sensor off the old engine (deep socket 24mm), quickly fitted it (thanks VW for easy access with a ratchet, extension and socket)' tried again and bob is still my uncle.
    She is now out of hospital and awaiting plastic surgery to the forehead. Dad's gen1 is keeping it company in the meantime. Might avtually get to sort the last bits on the gen1 now as well.
  19. #679
    Aug 2010
    The ear would have heard a noisy top end, grey matter cogs would have said oil pressure problem, and the optimist in you saw a solution.
    But, ja nee, the heart also jumps to 180bpm in an instant.
    2006 T5 4Motion 174HP TDI Seikel Dakar STOLEN IN KALK BAY
    2013 T5 4Motion 180HP TDI Seikel Desert HD Wearing bush stripes with pride
    A6 3.0 Multitronic 225HP
  20. #680
    Apr 2008
    Congrats. Well done! Respects 4x4 Community!
    Andre ZR6AGA
    2009 VW Tiguan 1.4 TSI Field & Track
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
