Marius's Touareg R5 life thread. - Page 33
Page 33 of 151 FirstFirst ... 8 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 58 83 133 ... LastLast
Results 641 to 660 of 3006
  1. #641
    Thanked: 605
    Clearing codes
    This was the code errors from all the faffing about when the engine packed up and got tinkered with
    VAG-COM Version: Release 409.1-S
    Chassis Type: 7L - VW Touareg
    Scan: 01,02,03,05,06,08,09,11,15,16,17,19,1C,22,29,34,36 ,37,39,45,46,47,55,56,65,68,6E,77
    Address 01: Engine
    Controller: 070 997 016 P
    Component: R5 2,5L EDC G000AG 1011
    Coding: 0011175
    Shop #: WSC 02532
    6 Faults Found:
    18072 - Control Circuit for PD Injectors: Electrical Malfunction
    P1664 - 000 - -
    18080 - Coolant Fan Control 1: Open or Short to Ground
    P1672 - 000 - - - Intermittent
    16567 - Fuel Temp. Sensor A (G81): Open or Short to Plus
    P0183 - 000 - - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 000 - - - Intermittent
    18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High
    P2185 - 000 - - - Intermittent
    18308 - Coolant Fan Control 2: Open or Short to Ground
    P1900 - 000 - - - Intermittent
    Readiness: N/A
    Address 02: Auto Trans
    Controller: 09D 927 750 BP
    Component: AL 750 6A 0596
    Coding: 0004136
    Shop #: WSC 31414
    3 Faults Found:
    01166 - Engine Torque Signal
    004 - No Signal/Communication - Intermittent
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    16997 - TCM Processor Malfunction
    P0613 - 004 - No Signal/Communication - Intermittent
    Address 03: ABS Brakes
    Controller: 7L0 907 379 G
    Component: ESP ALLRAD MK25 0203
    Coding: 0006402
    Shop #: WSC 31414
    3 Faults Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 05: Acc/Start Auth.
    Controller: 3D0 909 135 N
    Component: Kessy 6610
    Coding: 0000232
    Shop #: WSC 31414
    3 Faults Found:
    00457 - Control Module for Network (J519)
    01299 - Diagnostic Interface for Data Bus (J533)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 08: Auto HVAC
    Controller: 7L6 907 040 H
    Component: CLIMAtronic R/L X 3716
    Coding: 0000020
    Shop #: WSC 31414
    No fault code found.
    Address 09: Cent. Elect.
    Controller: 7L6 937 049 N
    Component: 3001
    Coding: 0113916
    Shop #: WSC 00000
    5 Faults Found:
    00978 - Lamp for Low Beam: Left (M29)
    010 - Open or Short to Plus - Intermittent
    00070 - Starting Battery Voltage
    008 - Implausible Signal
    00907 - Intervention load Management
    01520 - Rain and Light Recognition Sensor (G397)
    008 - Implausible Signal - Intermittent
    00084 - Electrical System Battery Switch-Over Relay (J549)
    Skipping Address 15-Airbags
    Address 16: Steering wheel
    Controller: 7L6 953 549 D
    Component: Lenksäulenmodul 3301
    Coding: 0000031
    Shop #: WSC 31414
    Address 17: Instruments
    Controller: 7L6 920 881 A
    Component: KOMBIINSTRUMENT RB8 3135
    Coding: 0007721
    Shop #: WSC 02646
    1 Fault Found:
    Address 19: CAN Gateway
    Controller: 6N0 909 901
    Component: Gateway K<>CAN 0101
    Coding: 0000006
    Shop #: WSC 00000
    1 Fault Found:
    Address 1C: Level Sensing
    Controller: 7L6 919 879 A
    Component: JCI PathPoint 2200
    Coding: 0000000
    Shop #: WSC 00000
    Address 22: AWD
    Controller: 0AD 927 755 BE
    Component: TRANSFERCASE 0122
    Coding: 0000000
    Shop #: WSC 00000
    1 Fault Found:
    Address 29: Left Light
    Controller: 3D0 909 157
    Component: EVG GDL+AutoLWR(l) 0001
    Coding: 0000003
    Shop #: WSC 02263
    1 Fault Found:
    00492 - Body kink Angle from Level Control Module
    Address 34: Level Control
    Controller: 7L0 907 553 F
    Component: LUFTFDR.-CDC- 3C3P1 3081
    Coding: 0015521
    Shop #: WSC 02631
    2 Faults Found:
    01400 - Suspension Level Control
    001 - Upper Limit Exceeded
    Address 39: Right Light
    Controller: 3D0 909 158
    Component: EVG GDL+AutoLWR(r) 0001
    Coding: 0000003
    Shop #: WSC 31414
    1 Fault Found:
    Address 46: Central Conv.
    Controller: 7L0 959 933 E
    Component: 2L HSG 0201
    Coding: 0000065
    Shop #: WSC 02646
    4 Faults Found:
    00927 - Terminal 30 (Right)
    011 - Open Circuit - Intermittent
    01516 - Terminal 30: Left
    00926 - Terminal 30
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Address 47: Sound System
    Controller: 7L6 035 456
    Component: 08K Audioverst. 0105
    Coding: 0000000
    Shop #: WSC 00000
    Address 56: Radio
    Controller: 7L6 035 195
    Component: Radio DE2 0012
    Coding: 0001017
    Shop #: WSC 31414
    Address 68: Wiper Electr.
    Controller: 7L0 955 119 L
    Component: Front Wiper 4027
    Coding: 0000855
    Shop #: WSC 31414
    Address 6E: Ctrl Head Roof
    Controller: 7L6 919 044 K
    Component: DACHDISPLAY 0538
    Coding: 0000000
    Shop #: WSC 31414
    End --------------------------------------------------------------------------------------------------
  2. #642
    Thanked: 605
    she lives again!
    It was torture making the starter work like that but that's the process stated in the manual as there is no primer pump. There is a feed pump in the tank that feeds the tandem pump tht feeds the injectors.
  3. #643
    Dec 2010
    San Sebastian Peninsula, Vilanculos Mozambique
    Thanked: 8
    Congratulations Marius!!
    I feel for that starter motor though. But as you say, that's what the manual says.
  4. #644
    Nigel
    Thanked: 501
    Congrats. She is alive.
    Next time, pressurise the tank a bit. Use some compressed air, with a rag to seal in some of that pressure. It will force that fuel to the motor and help.
  5. #645
    Thanked: 605
    Next time? Eish, I shudder to think if I had to do this again!
  6. #646
    Nigel
    Thanked: 501
    Maybe not on that car, but on some other car maybe.
  7. #647
    Glenconnor
    Thanked: 20
    Fantasties!! Wel gedaan! Hoop hy gaan jou baie plesier gee! Daardie vyfsilinder klink darem maar mooi!
  8. #648
    Jun 2008
    Thanked: 179
    Nice work marius!!! Makes me think of what I have achieved in that same time it has taken you to get to this point.
    Turns out I have done very little. Congrats
    Ironman Suspension
    40mm Body lift
    31x10.5x15 Cooper STTs
  9. #649
    Dec 2012
    In my agterplaas in die WC
    Thanked: 63
    Baie geluk. Daai twee vuiste in die lug het alles gese oor hoe jy voel!
  10. #650
    Thanked: 164
    Great stuff !!!
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250
    Jaco
  11. #651
    Aug 2010
    eeeha.
    How does she drive?
    2006 T5 4Motion 174HP TDI Seikel Dakar STOLEN IN KALK BAY
    2013 T5 4Motion 180HP TDI Seikel Desert HD Wearing bush stripes with pride
    A6 3.0 Multitronic 225HP
  12. #652
    Fourways Johannesburg
    Thanked: 164
    Awesome, Awesome, Awesome!!!
    Baie geluk Marius!
  13. #653
    Thanked: 86
    Awesome, well done Marius!
    Was this now with fresh oil and everything?
  14. #654
    Lonehill, JHB
    Thanked: 239
    Frikkin Genius!
    2014 Pajero 3.2DiD SWB
    2008 Pajero Gen4 3.2DiD LWB - SOLD
    2016 Nissan Qashqai 1.2T Acenta
    Metalian Maxi
    4x4AG 0110
  15. #655
    Pretoria-East
    Thanked: 31
    Congrats with a job well done!
    - Nothing comes at a higher price than that which is free.
  16. #656
    Aug 2010
    Delmas
    Thanked: 11
    Mooi!
    BlinkGat Products
    Manufacturing of Aluminium and
    Stainless Steel custom made Products
    Sarel 082 820 9413
    www.blinkgatproducts.com
  17. #657
    Geluk Marius. Jys n yster!
    Sent from my GT-P5100 using Tapatalk HD
    2009 Freelander 2 S TD4
    Bush Baby
  18. #658
    Secunda
    Thanked: 7
    Well done man! Ek het nog 'n entjie om te gaan...
    Ek's baie bly jou wa is weer aan die go, geniet hom!
  19. #659
    JHB
    Thanked: 35
    Congrats Marius!
    What an awesome achievement!
    2012 Bi Turbo 4Motion
    285/70R17 BF Muds, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and no software.
    BMW 1200GS ADV
  20. #660
    Mooi River
    Thanked: 9
    congrats
    hope u get many happy kms
    2000 Ford Courier DC 2.5TD 4x4
    2001 Range Rover P38 VOGUE
    2002 Volvo S60 2.4T
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
