Marius's Touareg R5 life thread. - Page 31
Page 31 of 151 FirstFirst ... 6 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 56 81 131 ... LastLast
Results 601 to 620 of 3006
  1. #601
    Sep 2011
    505.01 is goed genoeg. Dits is 'n HC sinteties. 506.01 is bietjie beter want dis vol sinteties en kom gewoonlik 0w40.
    Agente hou nie 506.01 aan nie. Hulle gebruik 507.00 en ek is nie oortuig dat dit die regte olie vir die R5/V10 engine is nie.
    The Genuine VW OIL 5W-40 are approved under VW standards 502, 506.01 and 505.01.
    This is the oil what you should use with the R5/V10 TDi engines.
    Part Number: G 052 167 M2
    Have a look here for product:
    http://4x4community.co.za/forum/show...7&postcount=21
    Many VW dealers will sell you the 507 spec oil or even use it for service because of their own ignorance.
    Cheers,
    2005 VW Touareg R5 TDi (Daddy's cool ride)
    Electric Jeep Super (Little-SWAMBO's ride)
  2. #602
    Thanked: 616
    Tandem pump should be here thursday or friday.
    Would you guys be interested in a live feed on youtube when I drop the engine in?
  3. #603
    Fourways
    Quote Originally Posted by mariusfourie View Post
    tandem pump should be here thursday or friday.
    Would you guys be interested in a live feed on youtube when i drop the engine in?
    nike
  4. #604
    Thanked: 14
    Subscribed!!!
    Bite off more than you can chew - then chew!
  5. #605
    Thanked: 86
    People at work will think I'm weird, but subscribed.
  6. #606
    Thanked: 616
    It will be on saturday most likely. Can't work on it in the week.
  7. #607
    Aug 2010
    Live? Sure!
    2006 T5 4Motion 174HP TDI Seikel Dakar STOLEN IN KALK BAY
    2013 T5 4Motion 180HP TDI Seikel Desert HD Wearing bush stripes with pride
    A6 3.0 Multitronic 225HP
  8. #608
    Thanked: 616
    Just out of interest
    I just had a look at the courier slip for my new engine.
    Engine with ancillaries, manifolds, turbo, some pipes, engine mounting brackets, full of oil, on a tyre, tied down with wires and a pallet it came in at 223kg. I reckon block and head bare to be about 150kg.
  9. #609
    Thanked: 616
    got the tandem pump today with gasket and picked up some coolant and power steering fluid.
    old tandem pump off and surface cleaned
    new tandem pump installed
    engine going in
    engine in sitting on it's mounts and 2 bellhousing bolts installed. Also got one flexplate bolt installed (85NM) - I am able to turn the engine by levering with a large flat screwdriver against the ring gear teeth so no need to remove the front crank seal (which gets damaged in the removal process and costs R890 from VW)
    Not bad for 2 quick hours after work, even if I must say so myself
  10. #610
    Thanked: 616
    A/C also installed and dipstick tube replaced.
  11. #611
    Thanked: 86
    Nice progress. After taking the old tandem pump off, would you say it was necessary to replace/could you see any issues with the old one on closer inspection?Marius, I'm not exactly sure what is meant, but read on the German forums, that special care must be taken in aligning the engine with the transmission 100%, apparently very sensitive to slight deviations. Take care when joining the two.
  12. #612
    May 2010
    Randfontein
    Thanked: 22
    Mooi man, jy vorder goed....
    2010 Toyota 3.0D4D 4x4
    RAW4x4 Predator Suspension / DIY Roof Rack / 265/70R17 BFG AT Ko2 / Frontrunner Rocksliders ......what is next?
    2006 BMW 120d - Adrie's fuelsaver....
    All covered by: TUFFSTUFF INSURANCE PRODUCT
    Member - 4x4 Action Group - 0030
    Member - Jeepclub SA - # 1575
    Member - WegRy
  13. #613
    Thanked: 616
    This is due to the torque converter having a double step when installing.
    To make sure I was fine I used a vernier to check extrusion of flexplate on engine and recess of torque converter in bellhousing. This was within spec according to VW.
    After triple checking I dropped the engine in, aligned it and threaded 2 bolts by hand until bellhousing and engine was flush.
    I then reached in through the starter hole and I could still turn the torque converter with one finger indicating that it hasn't been pinched or squashed.
    ElsaWin is a life saver with this build
Name:	installation dimensions.jpg
ID:	191349   Click image for larger version.
Name:	installing torque converter.jpg
  14. #614
    May 2012
    Thanked: 55
    Nice going!
    The "thermal insulation" is really for sound damping purposes. Europe has stringent noise passby requirements and diesels give off a lot of noise from the crankcases and sumps.
  15. #615
    Thanked: 86
    Another one with this or a similar issue it seems...
    http://capetown-westerncape.gumtree....AdIdZ450768186
    The car is smoking and has some sort of problem with the engine not sure what the problem is the car belongs to a client of ours and he would just like to sell the car as is as he has gone back overseas.
  16. #616
    Thanked: 616
    Got some more work done today
    All bellhousing bolts are torqued down, except the starter bolts.
    All 6 flexplate bolts are torqued to 85NM.
    Engine front thermal and splash shield installed
    Radiator fans and cowlings installed
    air filter to turbo intake installed
    here and there a water pipe connected
    bonnet back on with all it's waterpipes electricals and covers.
  17. #617
    Aug 2010
    Getting there!
  18. #618
    Kaapstad
    Nice Marius, ek is seker jy kan nie meer wag nie !!
    ISUZU DMAX 4X4
  19. #619
    Fourways Johannesburg
    Thanked: 165
    Jis, lyk baie goed Marius.
    Ek hoop regtig dinge loop goed en dat jy een van die dae(Sommer Maandag of hoe?) weer jou "pride and joy" kan ry. Alle voorspoed en sterkte vir jou.
  20. #620
    Jun 2012
    Fourways
    Thanked: 36
    Goeie werk! Wanneer start jy hom?
    ORRA Z150
    Discovery 2 V8 XS
    Discovery 4 SDV6 SE
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
