Marius's Touareg R5 life thread. - Page 16
Page 16 of 151 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 41 66 116 ... LastLast
Results 301 to 320 of 3006
  1. #301
    Oct 2012
    Secunda
    Good progress. Keep us posted.
    Francois
    V6 Tuna
  2. #302
    Aug 2010
    starter out. weird that VW used 18mm bolts for it.....
    VW use 10mm bolts with 18 hex head usually. Many years ago they used the same size bolts with 19 hex head.
    4S TT
    2006 T5 4Motion 174HP TDI Seikel Dakar STOLEN IN KALK BAY
    2013 T5 4Motion 180HP TDI Seikel Desert HD Wearing bush stripes with pride
    A6 3.0 Multitronic 225HP
  3. #303
    Potchefstroom
    Aaahhhh. Some new pics. Started building and breaking lego to get some dismantling action... ;-)
    Looks nice. Ring gear and flywheel looks clean. so no leaking oils seals there as well. Will you change that also now the engine is comming out?
    Wag... moet nou die vleis draai voor dit brand.
    Enjoy!
    So begin dit...
  4. #304
    Jukskei Park
    Looks good Marius, holding thumbs!
    2008 9A Discovery 3 TDV6 SE "Binky"
    2015 Amarok Auto Highline
  5. #305
    kathu
    Thanked: 468
    Unfortunately the head can only be removed after the engine is out. The camshaft sprocket and tensioner bolts are at the back of the head.
    By the look of things the alternator also sits at the back. Sjoe some Volla engineer never worked on engines him self
  6. #306
    Thanked: 622
    With the intake removed access is reasonably easy.
  7. #307
    kathu
    Thanked: 468
    Marius,
    All the manufactures do it. It becomes harder and harder these days to work on a car. At the end it is still the costumer paying up. Simple jobs involve hours of stripping before it can be done. Keep up the good work.
  8. #308
    Nigel
    Thanked: 517
    This is a bit OT, but yes they make it difficult to service the car.
    My son is at Toyota and they had to do valve springs on some of the Lexus, under warranty. You need to drop the whole front subframe. Front suspension, engine, gearbox, the lot.
  9. #309
    Thanked: 622
    bellhousing bolts (you now know what's to follow right....... )
    jip. Engine is out (Finger up to all the naysayers and VW who said it couldn't be done - that it had to be done from the bottom is utter bollocks! )
    rear of engine view
    starter location with access cutaway fro flexplate bolts
    front of engine
  10. #310
    Thanked: 622
    alternator side with A/C pump removed
    tandem pump
    engine bay
    A/C pump on the side with radiator still in place. No damage to the radiator (and i used a bolt on the front of the engine for the chain hoist that was 2 inches too long.
    The view
    Now the next step is to fabricate some timing locking tools, and pull the head.
  11. #311
    Jukskei Park
    Nice Marius; that hanging engine is giving me goosebumps of prettyness!
  12. #312
    Thanked: 14
    Quote Originally Posted by Theunis Kruger View Post
    +1! Well done!
    Bite off more than you can chew - then chew!
  13. #313
    You must walk like John Wayne, considering how big your balls are to try this yourself.
    2006 Touareg R5 - SPORTSVANS body lift, Alpine Type R sound system:
    http://4x4community.co.za/forum/show...ouareg+stealth
    2010 Volvo XC60 D5 R Design
    2013 Polo Vivo traffic mobile
    2012 Husaberg TE300
  14. #314
    Thanked: 86
    Just brilliant. Very curious to see what awaits inside.
  15. #315
    Nigel
    Thanked: 517
    Excellent. Just turn that motor to TDC for no1. There should be timing marks....
  16. #316
    Jul 2010
    Greenstone
    Thanked: 15
    As before I believe that Marius will be rewarded for his effort and the problem will be head or ring related ,I believe the block will be OK and the problem repairable with no need to visit the bank manager....let's keep our fingers crossed.
    Well done so far
  17. #317
    Aug 2010
    well done mate. Mine is going to Tim.
  18. #318
    Thanked: 622
    Just saw the reposessed advert online that the scammer pulled the pictures from
    https://mycars.co.za/index.aspx?AssetRef=MC21500
  19. #319
    Thanked: 622
  20. #320
    Thanked: 86
    Bastard. Sad to see that Treg like that, very poor condition. Wonder how much it went for?
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
