Marius's Touareg R5 life thread. - Page 150
Page 150 of 154 FirstFirst ... 50 100 125 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 LastLast
Results 2,981 to 3,000 of 3062
  1. #2981
    Thanked: 955
  2. #2982
    Thanked: 955
    Default Re: Marius's Touareg R5 life thread.
    Picked up the platinum (or so it seems when you see what it costs) manifold and gaskets today.
    Its a transporter one so the egr will have to be completely deleted.
  3. #2983
    Thanked: 955
    Brand new OEM part but bought at Goldwagen
  4. #2984
    Thanked: 955
    Bought at Goldwagen as the importer didnt have stock.
  5. #2985
    Thanked: 955
    Started assembling tonight
    Fixed a few connectors and deleted the egr cooler as well as the egr was blanked. Why risk the cooler failing.
    Some plastic bits were brittle and replaced with copper pipes that i flanged.
  6. #2986
    Thanked: 955
    Turbo goes in
  7. #2987
    Thanked: 955
    Manifold, engine mounting and custom copper fittings in to complete the egr cooler delete
  8. #2988
    Thanked: 955
    All buttoned up
  9. #2989
    Thanked: 955
    This is why touaregs are hard to kill and rack up big mileage
    If the coolant or oil is low/too hot, you get a loud beep and a warning on the MFD.
  10. The Following User Says Thank You to MariusFourie For This Useful Post:
  11. #2990
    Jul 2016
    Pringle Bay
    Thanked: 202
    Nice Marius thanks for sharing
  12. #2991
    Thanked: 955
    Test drive revealed no leaks.
    It was a time consuming job due to some amendments but it wasn't too difficult.
  13. #2992
    Jul 2007
    Putfontein, Benoni
    Thanked: 288
    Management not complaining about the EGR bits missing?.
    Audi S6 2008 - v10 Quattro
    Audi A6 Avant - 2005 - 3l TDi Quattro
    Audi A4 TDI - 2007 - 2l TDI
    Audi 90 Coupe - 1995 - 2.8l V6 quattro
    VW Touareg - 2005 - V10 TDi
  14. #2993
    Thanked: 955
    No. All vacuum operated. Old style.
    Only way it can perhaps tell is via the MAF.
    The egr valve has been blanked off for years. I just deleted the cooler now to prevent a future leak. Preventative maintenance and regular services is the key to longevity in my eyes. If you stay on top of things then you don't get once off big bills when it all goes to pot.
  15. #2994
    Thanked: 955
    I pulled dad's 2006 v10 vacuum pipes to the two egr valves and blanked with golf tees to stop them operating.
    His ecu hasn't complained either. Not even via VCDS scans.
  16. #2995
    Thanked: 47
    I was wondering about this, can you just unplug the 2 vacuum solenoid valves that control the EGR?
    Touareg V10
  17. #2996
    Thanked: 955
    Quote Originally Posted by SpiderGear View Post
    Yes. Remember to plug the pipes with a small screw or golf tee
  18. #2997
    Thanked: 47
    No, I mean just unplugging the connectors from the solenoids so they cannot open, instead of unplugging pipes.
    Touareg V10
  19. #2998
    Thanked: 955
    Dad's v10 is purely mechanical with no electrical bits attached.
  20. #2999
    Thanked: 47
    No, there are 2 N18 valves controlling the vacuum to the EGR, one on either side of the engine. I was referring to unplugging them instead of disconnecting the vacuum pipes from the EGR
    Look something like this.
    Touareg V10
  21. #3000
    Thanked: 955
    ECU might see resistance change on the circuit. I would just pull and blank the vacuum tubes. Takes 60 seconds.
    Did dad's one months ago and he hasn't had any lights come on or issues.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
