Marius's Touareg R5 life thread. - Page 142
Page 142 of 151 FirstFirst ... 42 92 117 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 LastLast
Results 2,821 to 2,840 of 3006
  1. #2821
    May 2016
    Thanked: 360
    Default Re: Marius's Touareg R5 life thread. Something like that
    Two wheel bearings on the way and I'm starting to think how to do it.
    It's not a conventional bearing that you can use the old outer race to drive in the new bearings. And I don't want to drive the new expensive bearings in on the inner race.
    And I'm not paying R5k for the tool set you need to do it.
    So, I'm thinking about taking the knuckle off completely, moering the old one out, then put the knuckle in the oven on hell for a bit, and put the bearing in the freezer for a bit. The expansion difference should have it drop right in?
    Any problems with this? I can't think of any. Your thoughts?
    Pictures?
    ex 4ePajero (yes, I'm back! )
    2006 VW Touareg V10 TDi
    ex Gen1 Pajero 3.2 Di-D (retired )
  2. #2822
    Robertson/ Larissa, Greece
    Thanked: 421
    I'd also like to see what it looks like. Is it any different to say a Golf's front wheel bearing other than much bigger?
    To achieve greatness, stop asking for permission!
  3. #2823
    Thanked: 616
    Pictures?
    This is the wheel bearing
    https://www.rexbo.eu/optimal/wheel-b...00013?c=100579
    I haven't stripped the hub yet.
    The ebay tool kit
    http://www.ebay.com/itm/GEN-2-Compac...-/181090277425
  4. #2824
    Thanked: 616
    This is the schematic of the rear but principle is the same.
    10 -> Touareg R5 bearing
    5 -> All the other touaregs' bearings
  5. #2825
    Thanked: 616
    provided the heat and cold provides enough clearance it should drop in easily.
    Is there any downside to expose a bearing to such extreme cold? Some cars live in such cold temps so it can't be that bad.
    The hub in the oven can't be that bad. It's just metal. No electronics or balljoints or rubber or anything.
  6. #2826
    May 2016
    Thanked: 360
    1. Knock the old bearing out.
    2. Remove the innards, so that you have only the outer shell (ring) left.
    3. Split this with an angle grinder.
    4. Use this (split ring) to press the new bearing into place (the fact that it is split, will ensure that it does not stick in the hub with the new bearing)
  7. #2827
    Thanked: 616
    Getting the old bearing out should be easy. I can use force.
    The new bearing is a sealed unit so it can't be split.
    There is no conventional means of pressing it in on the outer race. It can only be hammered in on the flange which is basically hammering on the inner race.
    The tool kit allows you to press behind the flange with n adapter onto the outer race through the wheel holes.
    My only option is the oven freezer method or hammer method or wait 6 weeks for a R5k kit.
  8. #2828
    May 2016
    Thanked: 360
    You are not getting my idea (I used it years ago on a Audi 200)
    You split the OLD bearing's outer shell.
    This will seat on the new bearing's outer shell as well (so the power is applied to the outside)
    Use a press to press the new bearing into the hub.
  9. #2829
    Thanked: 616
    You can't seat the old outer race onto the new outer race from the drive direction.
  10. #2830
    Thanked: 616
    is is the method with the specialised kit
    Mute the sound
    https://www.youtube.com/watch?v=R5FIq1W7hPM
  11. #2831
    Thanked: 28
    Wow, that tool set makes it look so easy!
    Touareg V10
  12. #2832
    Thanked: 421
    Ok that is for doing it in situ. I'm sure ypu can build a simialr "tool" yourself fairly easily. If you take off the hub, other possibilities open up.
  13. #2833
    Thanked: 616
    Quote Originally Posted by SpiderGear View Post
    I want to take the hub off and do this. That's easy peasy and I can't see the downside.
    https://www.youtube.com/watch?v=x-fugJSzA8U
  14. The Following User Says Thank You to MariusFourie For This Useful Post:
  15. #2834
    Feb 2015
    Piet Retief
    Thanked: 14
    I see no issues with the oven freezer method. It has been used in engineering on industrial machines for quite a while and you don't hear of them ever failing because of this.
    If I have it correct for every degree above about 70 C the hub should expand by 0.1 or something of the sort. Combine that with the frozen bearing it should slide right over as you say.
    2006 Ford Ranger 4000 V6 - When the going gets tough
    1990 Honda Ballade 160i - When the tough is too expensive on fuel
    Built Ford Tough.
  16. The Following User Says Thank You to 4xFord For This Useful Post:
  17. #2835
    Thanked: 616
    Quote Originally Posted by 4xFord View Post
    Awesome. I thought as much. I'm gonna try it that way.
    I just need them to arrive now.
  18. #2836
    May 2016
    Thanked: 360
  19. #2837
    Thanked: 616
    R868 vat and import duty. Eina blikemmer!
  20. #2838
    Thanked: 616
    Stripped the one side
  21. #2839
    Thanked: 616
    Im not a film maker so excuse the search for words and bad narrating
    https://youtu.be/pRiqA57Vz1k
  22. #2840
    Aug 2010
    Thanked: 32
    Marius, what are you doing in the EP
    WE NEED YOU UP HERE
    Chris.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
