Marius's Touareg R5 life thread. - Page 13
Page 13 of 151 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 38 63 113 ... LastLast
Results 241 to 260 of 3006
  1. #241
    Thanked: 86
    Quote Originally Posted by Romzotwa View Post
    DIY fix isn't impossible if you look here:
    http://www.clubtouareg.com/forums/f9...rex-73289.html
    The guy did this job in his own home garage.
    This task I would never attempt with my limited skills and tools.
    That takes BIG Balookas.
    Another guy with possibly same problem trying to sell his R5 Treg on Gumtree I see:
    http://johannesburg.gumtree.co.za/c-...AdId=408264791
  2. #242
    Thanked: 616
    spoke to him. Asked him about the engine. Same story. He has a transporter engine he wanted to fit but don't have the time.
    He was very put out when I told him you can't fit the transporter engine to the touareg.
  3. #243
    Thanked: 616
    Deadline has come and gone for the guys to get back to me on engines.
    It's being brought back home on flatbed tomorrow.
    At least Shalene saved a tortoise today
  4. #244
    Can't you use the internals from a used T5 engine?
    Sent from my BlackBerry 9900 using Tapatalk
    2006 Touareg R5 - SPORTSVANS body lift, Alpine Type R sound system:
    http://4x4community.co.za/forum/show...ouareg+stealth
    2010 Volvo XC60 D5 R Design
    2013 Polo Vivo traffic mobile
    2012 Husaberg TE300
  5. #245
    Thanked: 616
    self study document on the R5 engine
    http://vwpress.files.wordpress.com/2.../ssp-305-e.pdf
    I'm not stressed for any parts or work except if the bore is damaged. That's the only funny thing on that engine. The rest is same as any other diesel engine with a few tweaks.
ID:	181361   Click image for larger version.
  6. #246
    Port Shepstone
    Thanked: 83
    Marius, here is another article that might help, don't ask...
    What a life!
  7. #247
    Thanked: 616
    Quote Originally Posted by Quack View Post
    I posted that in my previous post, but thanks anyway
  8. #248
    Thanked: 616
    Default Touareg R5 2.5 TDi Engine swap + more
    INDEX
    *** This page index will only work if your settings are set to 20 posts per page
    Go to your User options and scroll down to where you can set "Number of posts to show per page"
    PRELUDE :
    The actual story starts HERE where the misfire began 2 months after purchase
    Page 1
    Engine arrives back home after diagnosis of low compression on cylinder 5
    Page 2
    Stripping begins
    CCV Discussion
    Page 3
    CCV Discussion continues
    Further stripping
    DIY Crank turning tool
    Engine comes out
    Page 4
    Engine out pics
    Cylinder head off
    Page 5
    Looking for engine replacement options
    Page 6
    Considering a rebuild
    More pictures of damaged bore and piston
    Page 7
    Ombudsman discussion
    More engine pics
    Reason of failure discussion
    Page 8
    Rebuild versus replacement engine discussion continues
    Page 9
    Ombudsman and previous dealer discussion
    V8 Lexus motor option discussion
    Page 10
    Rebuild option rediscussed
    Page 11
    Romzotwa finds a possible 2nd hand engine at a breaker
    Kortgat starts fundraiser thread for replacement engine
    Members start helping out to check out possible replacement engine
    Page 12
    Oil analysis of replacement engine
    Page 13
    Oil analysis discussion
    Compression test being organised
    Page 14
    Compression test results
    Pumpe duse, common rail and plasma coating discussion
    Page 15
    Plasma coating and oil spec discussion
    Tandem pump discussion
    Speculation to reason for original failed engine
    Page 16
    Replacement engine arrives
    New tandem pump discussion continues
    Engine prepped, ready to go in
    Page 17
    Thermal covers discussion
    Catalytic converter removal instruction
    Oil spec discussion
    Engine sleeve discussion
    Page 18
    Oil discussion continue
    Thermal cover pictures
    Engine weight on pallet 223kg
    Tandem pump arrives
    Engine drop in
    Page 19
    Torque converter install discussion
    Engine install pics
    Windscreen damage
    Page 20
    Wiring harnass wrapping discussion
    Codes cleared
    Engine start video
    Page 21
    Finished engine picture
    Page 22
    Oil pressure scare
    Another engine start video after the system has fully primed.
    Vagcom injector measuring blocks at idle
    AntonvBosch starts discussion on his treg that got electrical faults
    Page 23
    AntonvBosch discussion continues
    Tandem pump disassembly link to tdiforums
    Page 24
    AntonvBosch Alternator not turning discussion
    Sump taken off old engine toshow dipstick
    2 stroke oil discussion starts
    Page 25
    Alternator discussion continues
    Geartrain cover removed on old engine
    2 stroke oil discussion continues
    2stroke oil sulphur ratios discussed
    Page 26
    Engine removal short notes
    Windscreen repair pictures
    Page 27
    New engine Pump Jet Valve error on cylinder 5 (N244)
    Possible faults for error discussion - touching on 2SO again
    Page 28
    Injector discussion continues
    Injector removal, install and coding discussion
    Page 29
    Injector connector removal notes and pictures.
    Picture of first drive
    Page 30
    Licensing procedure with microdots from DEKRA
    Microdots under UV Light
    Injector adjustment
    D1S HID replacement bulb discussion
    Page 31
    Bulb replacement pictures
    HID vs Halogen discussion
    AntonvBosch Alternator discussion
    Page 32
    Alternator discussion continues with rough running engine
    Chriseleven radiator fan running on discussion
    Piston 5 on old engine out - pics and discussion
    0-100 km/h video
    Touareg Launch mode discussion
    Page 33
    Further discussion on reason for failure on cyl5 (heat failure specifically)
    EGR discussion starts
    Page 34
    EGR discussion continues
    EGR disable DIY instructions and Video
    Airbox pictures of the inside
    Macro picture of failed piston
    Page 35
    First long trip feedback
    EGR & CCV discussion
    Catch can discussion with V6 TDi
    Suspension bushes ordered from Porsche
    Page 36
    Suspension bushes fitted DIY.
    AntonvBosch engine failure options discussed
    Page 37
    Night time cockpit photo
    EGR & economy discussion
    Passenger door sag fix
    Page 38
    Photo compilation video
    Door sag fix discussion
    Economy, range and fuel tank size discussion
    GPS vehicle changed to touareg (plus pajero model download)
    Page 39
    Fuel economy discussion
    AC problem starts
    Page 40
    Fuel economy discussion continues
    AC issue found
    Page 41
    AC problem discussion continues
    Touareg dash cam - dodging dog
    AC pump clutch pictures, failure and discussion
    Page 42
    Another dog dodge dash cam video
    AC issue discussion continues
    Air strut lifespan discussion
    Page 43
    Air strut discussion continues
    GPS install in center cubby hole on top of dash
    AC bearing assembly strip pictures
    Boost pipe O-rings clean
    Page 44
    Boos pipe o-ring clean discussion continues
    Ferndale outing pics
    Smoky idle discussion
    Touareg W12 turbo videos
    Page 45
    Replacing turbo seals
    Vacuum pipe diagram for VGT, EGR and intake manifold shutter flap
    Gonubie Pine forest outing
    Page 46
    Cleaned up engine bay picture
    Fuel economy history
    Turbo dismantled pictures
    Nearly Head On Collision on dirt video
    Link to another R5 engine swap thread
    Kortgat's link to to 507.00 and bearing failure
    Oil spec discussion
    Page 47
    Almost head on collision on N2 video
    Double Mouth Camping
    Cold Start Throttle body video
    Offroad wheel cam timelapse video
    Touareg with Lexus V8 discussion
    New Tyres - Apollo Hawkz 235/65/17 R/Ts
    Page 48
    Air suspension explained
    VGT Turbo actuator video
    Gauteng trip economy
    Page 49
    Webasto heater kickc in for the first time
    Oil spec discussion
    Page 50
    Oil spec discussion continues
    Spotlights installed
    Hogsback photos
    Nearly hit a buck - dash cam video
    Page 51
    Headlight ballast failure due to short circuit & water ingress
    Alternator coupling and freewheel failure (plus video and DIY instructions)
    Page 52
    Alternator removal pictures
  9. #249
    Thanked: 616
    Still no response from the engine seller. Giving up now.
  10. #250
    You sir, are a brave man.
    2012 Husaberg TE300
  11. #251
    Thanked: 616
    Following on from this thread
    http://www.4x4community.co.za/forum/...d.php?t=130745
    Basically misfire on cylinder 5 and later diagnosed as low compression. Low compression cause is still unknown. Engine hasn't been opened yet.
    Plan is to take engine out, opened and then decide from there on replacement or recondition.
    "Knoppies" got delivered back home today
    Cylinder 5's cam lobes and lifters (a bit dusty from travelling and being looked at)
    Quote Originally Posted by Wedgy View Post
    Brave or stupid.....
    I'll soon find out.
  12. #252
    Nigel
    Thanked: 510
    Go for it Marius.
    Man made it and man can fix it.......
  13. #253
    Sep 2011
    We all will support you.
    Good luck mate...
    2005 VW Touareg R5 TDi (Daddy's cool ride)
    Electric Jeep Super (Little-SWAMBO's ride)
  14. #254
    Thanked: 7
    Sterkte Marius, hierdie thread van jou gee my sommer n groot lus om self die HEMI se exhaust manifolds uit te haal.
    Sterkte en neem baie fotos.
    Groete
    Andre
    Isuzu KB300 D-teq auto 4x4 D/Cab
    1996 Nissan Patrol.........To be continued!!
    Andre Thuynsma
  15. #255
    Thanked: 86
    You are already a legend, just for giving it a go!
    Looks like you have sufficient space there. All the best to 'Knoppies' LOL...
  16. #256
    Thanked: 14
    +1!
    Bite off more than you can chew - then chew!
  17. #257
    Thanked: 165
    Subscribed. Best of luck.
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250
    Jaco
  18. #258
    Jan 2011
    I'll give Marius credit, his work and advice on 4M40 motors has given me the confidence to slowly try smaller work on my LWB, even if its simple tasks like spacer mods etc.
    Go for it Marius and good luck!
  19. #259
    Jun 2012
    Mikpunt, Durbanville
    +1 Subcribed!!!
    Good luck Marius
    Nicholas Gibson
    2005 Gen 3 Pajero 3.2 DiD Auto LWB
    Mods:
    ARB front bumper, OME, Lynx Bash Plate, Lynx Rock-sliders, Lynx rear steel bumper, Front Runner 40lt Long range tank, Madman EMS2 engine management module, dual battery system, 700FF spots
    Corsa 1.4 Club (swambo)
    "In my house I'm the boss, my wife is just the decision maker." - Woody Allen
  20. #260
    Jukskei Park
    Good luck Marius; hope it works out for the best.
    Subscribed!
    2008 9A Discovery 3 TDV6 SE "Binky"
    2015 Amarok Auto Highline
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
