Marius's Touareg R5 life thread. - Page 137
Page 137 of 151 FirstFirst ... 37 87 112 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 ... LastLast
Results 2,721 to 2,740 of 3006
  1. #2721
    Henley on Klip
    Default Re: Marius's Touareg R5 life thread. Something like that
    Start with a fuel filter change and return line volume test.
    Check my thread for details. Sorry i am not more specific. Im on my phone and far from home.
    I will do. Thank you.
    UPDATE:
    Changed the fuel filter this morning and tooks it for a short run. It's still smoking at start and idle but not as much and the smoke now seems a shade or 2 darker in the blue direction, but still smells like diesel. Hardly smoking when driving.
    I also noticed that there is some smoke coming from somewhere near/on the exhaust manifold. But think I'll let the mechanic figure out where its coming from.
    I'll check in the morning if the filter change has helped with the starting issue. Lets hope so. I'd still like to hook it up and check the injector readings with VCDS.
  2. #2722
    Henley on Klip
    I have only ever tried three castrol engine oils. GTX, magnatec and long life, all in my jetta 3 1.8 CSX. All three caused sludge and resulted the engine to use oil. Perhaps it was due to the inherent rich mixture found in carburetted cars allowing a bit of petrol to mix with the oil. FI engines may be better. I did drive the car very hard though when I had it. I pulled the sump to fix an oil leak on 300'000km (about 50'000km on delo at that stage) and the honing marks were still visible. Sold it on 320'000km still running perfect.
    Changed to delo and problem solved.
    Castrol makes good gear oils but Im not convinced on their engine oils. Many report very good results from Castrol however. Each to his own.
    I would never use anything other than 505.01 in my R5. It contains special additives for the cams as the lifter cam lobes are narrow to make space for the wide cam lobe that actuates the PD injector.
    My dad has about 260'000km on his v10, but remember that the cam manufacturing on the v10 may be different on it.
    The only real instances reported of cam failure are on the R5 and 1.9 tdi. I would stick to 505.01 5w-40 for my R5. I believe only Liqui Moly and Fuchs provide the 505.01 spec in the 5w-40 weight oil.
    Sent from my iPad
    Planning a service for my Treg and wondering whether to go with the 505.01 spec oil or 506.01 and if the 506.01 then which brand to go with, Liqui Moly Synthoil Longtime Pro 0W-30 or RAVENOL WIV SAE 0W-30 http://ravenol.co.za/product/ravenol-wiv-sae-0w-30/
  3. #2723
    Thanked: 622
  4. #2724
    Thanked: 622
  5. The Following User Says Thank You to MariusFourie For This Useful Post:
  6. #2725
    Thanked: 622
  7. #2726
    Thanked: 622
  8. #2727
    Thanked: 622
  9. #2728
    Thanked: 622
  10. #2729
    Thanked: 622
  11. #2730
    Thanked: 622
    Wind was howling from the front almost all the way to CT. Economy wasn't good. Only managed 10l/100km.
    Pictures above are through seweweekspoort pass. Absolutely stunning scenery!
  12. #2731
    Thanked: 622
    Safely home this time. I didn't use BP Bellville this time round. The volla performed flawlessly.
    Damn, slaapstad is well managed. Well impressed, apart from the average speed cameras in the 80 zones up Lowry's.
  13. #2732
    Thanked: 622
    Default Re: Misfire 2 months after purchase - engine swap
    6500km later. Seems like they are wearing down slowly. No measurable wear on the indicator so far.
    Granted a lot was open road but I suspect my insistent pursuit of proper alignment and the all wheel drive plays a large part.
    Also, 3500 km since last service. Rings are sealing nicely and combustion is clean, else the oil would be a lot blacker. Lack of egr probably helps in keeping it clean as well
  14. #2733
    Jan 2014
    Thanked: 18
    ge-impressed
  15. #2734
    Aug 2010
    Thanked: 32
    Quote Originally Posted by Desperate Dan View Post
    ge-impressed
    BAIE
    Chris.
  16. The Following User Says Thank You to ChrisLab For This Useful Post:
  17. #2735
    Thanked: 86
    Hmmm reconsidering an EGR blank on mine now...
  18. #2736
    Thanked: 188
    This is not Seweweeks, is it? Huisrivier?
    Tyrannosaurus R5 and a second hand British Tata
    Quote Originally Posted by 2beFree View Post
    Jan your signature says it all
  19. #2737
    Thanked: 622
    Quote Originally Posted by JanB View Post
    Cant remember the name. It was on the way to seweweeks.
  20. The Following User Says Thank You to MariusFourie For This Useful Post:
  21. #2738
    Sep 2015
    Johannesburg Fourways
    @MARIUS, the mud tyres look awesome!
    how is the on-road performance at high speed above 100km/h? is there confidence inspiring grip or nervous as hell?
  22. #2739
    Thanked: 622
    Quote Originally Posted by GreenJustin View Post
    More than enough grip but some of the gti dynamics has been lost. You can feel the big blocks moving around.
    Onroad performance is completely acceptable in my books. Its not a sportscar but still handles great with muds.
  23. The Following User Says Thank You to MariusFourie For This Useful Post:
  24. #2740
    Thanked: 622
    Luckily no damage
    Please pardon the language.
    https://youtu.be/hWKjJ4hVPCs
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
