Marius's Touareg R5 life thread. - Page 128
Page 128 of 151 FirstFirst ... 28 78 103 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 ... LastLast
Results 2,541 to 2,560 of 3006
  1. #2541
    Thanked: 86
    Default Re: Misfire 2 months after purchase - engine swap
    I think it's 8mm. I dont know. I had nuts lying around that fitted.
    The fuse you can get from outdoor warehouse. Dont know what they are called.
    Can you give me some clues as to the best way to route the cabling on the outside of the vehicle, as you did on yours?
  2. #2542
    Thanked: 616
    Stuck in office. Can't check now but I recall running it between fuel tank and it's cover, cable tying it to to the fuel tank cover brackets.
    Will try to get some pictures for you later on.
  3. #2543
    Thanked: 86
    😉 hint hint
  4. #2544
    Thanked: 616
    Sorry. Lots going on.
    One pictures shows cables coming out of the battery box. The other shows the left rear control arm.
ID:	395026   Click image for larger version.
  5. #2545
    Thanked: 616
    Default Re: Touareg R5 engine build
    a bit clearer
ID:	395035   Click image for larger version.
  6. #2546
    Thanked: 86
    Thank you, that really helps!
  7. #2547
    Thanked: 616
    Once you just get going it becomes easier. Sorry for the crappy pics. If you need better ones I can maybe make a video of the routing.
  8. #2548
    Thanked: 86
    So you had to make holes from the front battery and then again at the rear. In the battery box in front, where did you place those holes?
  9. #2549
    Thanked: 86
    Ok see where you did it on the front now.
  10. #2550
    Thanked: 616
    Yes, I had to make holes in the battery box. For my rear battery I just removed some of those plastic bungs.
  11. #2551
    Thanked: 86
    I'm putting a marine type switch by the front battery. Better to put that before or after the fuse?
    Edit: has to be after if I use the Treg's fuse facility
  12. #2552
    Thanked: 616
    Fuse as close as possible to the battery. One at main battery AND one at aux battery.
  13. #2553
    Thanked: 616
    Awesome roadtrip yesterday. Always a pleasure with a touareg.
    9l/100km. And that with larger tyres and full size spare on the roof. Not bad for an 11 year old car.
ID:	395158   Click image for larger version.
ID:	395159   Click image for larger version.
  14. #2554
    Kortgat you have the same Touareg as mine 2007and I ran my cable inside the car. See the full thread , Search Volkswagen Brad Harris.
    "I am not sure if the R5 has the channel.
    The V6 channel runs from the spare wheel well on the left side and goes under the back seat and foot well and then under the front seat to the battery. In some places it has plastic ducts/covers.
    This channel is inside the car.
    I hope you can find it."
    Doug
    Touareg V6 TDI 2007
  15. #2555
    Thanked: 86
    Quote Originally Posted by Doug View Post
    Kortgat you have the same Touareg as mine 2007and I ran my cable inside the car. See the full thread , Search Volkswagen Brad Harris. "I am not sure if the R5 has the channel. The V6 channel runs from the spare wheel well on the left side and goes under the back seat and foot well and then under the front seat to the battery. In some places it has plastic ducts/covers. This channel is inside the car. I hope you can find it." Cheers Doug
    Hi Doug. Thank you. I did find that channel, but still opted for the under vehicle method as my primary reason is a brad Harris plug at the tow bar. So was easier and safer to take the wiring underneath. I'll post some pictures of my install.
  16. #2556
    That makes sense and yes it is a lot easier.
    Touareg V6 TDI 2007
  17. #2557
    Thanked: 28
    I want to add a BH plug to the V10, can I connect to the rear battery or should I use the front one? I remember reading that the rear battery is charged in 20min intervals so I'm a bit worried about the possibility of draining the rear battery.
    Touareg V10
  18. #2558
    Thanked: 616
    The rear battery is the starter battery in the v10 so use the front battery rather
  19. #2559
    Thanked: 616
    Awesome weekend away with family
ID:	396286   Click image for larger version.
ID:	396287   Click image for larger version.
  20. #2560
    Jan 2015
    Vredenburg
    Thanked: 173
    Lyk heerlik Marius.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
