Marius's Touareg R5 life thread. - Page 121
Page 121 of 153 FirstFirst ... 21 71 96 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 146 ... LastLast
Results 2,401 to 2,420 of 3058
  1. #2401
    Thanked: 888
    Quote Originally Posted by Ralphmoehrke View Post
    Hi. You will be pleased to see I listened.😊
    Would checking this pipe be a way of assessing if there is a problem with low compression on one or more cylinders?
    Best test is an injector reading via vcds.
  2. #2402
    Oct 2015
  3. #2403
    Thanked: 888
    Had a scare today. Heard a weird noise in the dash when accelerating and braking. Turned out to be a loose speaker but back to the story....
    I suspected water in the bulkhead so pulled the wheel liner to find I already pulled the drain plug last time. Then I heard a hiss. Checked the tyre, nothing.
    Then checked the connector where the airline comes in. Spray some soap.... Bubbles. Daaaaammmn!
    When I wash I usually follow up with a squirt of q20 in that area so it cant be corrosion.
    Cleaned the area, backed off the connector a quarter turn and tightened a quarter turn plus a tenth of a turn. Job done. No more leaks. That was a close call scare. Joh!
    The after test. No more bubbles
  4. #2404
    Thanked: 888
    You need a special tool to turn that connector. The nut just keeps the pipe in, it is separate to the connector. Do t tighten via that nut, you will strip it.
    You can see the teeth marks where I used waterpump pliers to nip the connector tight.
  5. #2405
    Thanked: 111
    You need a special tool to turn that connector. The nut just keeps the pipe in, it is separate to the connector. Do t tighten via that nut, you will strip it. You can see the teeth marks where I used waterpump pliers to nip the connector tight.
    Glad it's nothing. The guys that did the 'refurb' on mine simply used a vice grip on that pressure retention valve.
  6. #2406
    Thanked: 45
    So what happened to the water in the bulkhead?
    Touareg V10
  7. #2407
    Thanked: 888
    There was no water. It was a loose speaker in the dash that sounded like water.
  8. #2408
    Thanked: 888
    A small panorama of all the stuff behind the wheel liner
  9. #2409
    Thanked: 45
    So what caused the leak? IS there an o-ring on that connector?
    Touareg V10
  10. #2410
    Thanked: 888
    Quote Originally Posted by SpiderGear View Post
    I haven't removed one yet. I suspect it is just a tapered thread that seals it.
  11. #2411
    Thanked: 888
    Beetles all over the place.
  12. #2412
    Thanked: 888
    Quote Originally Posted by kobus Visagie View Post
    Ek sien net `n Touareg en a scooter ?
    Watse kontrapsie plak jy daar teen jou voor ruit ?
    Dashcam
  13. #2413
    Thanked: 888
    Ek dink dis wet in Rusland agv insurance fraud.
  14. #2414
    Thanked: 888
    A bushbuck ran into the side of the car last night. No damage at all. Just a wipe of the dust. I stopped to check on the bush buck but he must have been ok. He was nowhere to be found.
ID:	376093   Click image for larger version.
ID:	376094   Click image for larger version.
  15. #2415
    The Windy City
    Thanked: 1528
    INDEFLATE, Now available in the online shop!
    Click below for more info.
    http://www.4x4community.co.za/shop/i...&product_id=68
  16. #2416
    Thanked: 888
  17. #2417
    Thanked: 888
  18. #2418
    Oct 2006
    Walmer Heights, Port Elizabeth
    Thanked: 24
    And then big boom?
    1999 Colt Rodeo 3.0 V6 4x4-Build
    1998 Pajero Gen 2 SWB 3.0 V6 4x4-Resurrection
    1997 Ford Ranchero Outback 4.0 - Build
    SOLD
    1979 Landrover Series 3 88" Ford 3.0 V6 - Build
    1980 Landrover Range Rover 3.5 V8 - Build
    1979 Landrover S2A 109" with Chev 4.1
  19. #2419
    Thanked: 888
    Quote Originally Posted by Racer-X View Post
    And then big boom?
    Nooooooooooooo!
  20. #2420
    Thanked: 888
    This is my catch can setup - very simple very easy. Excuse the dirty engine bay. I drive a lot of gravel.
    The catch can is actually a water filter but made entirely out of plastic including the filter screen. It manages to trap the oil without degrading the plastic. I have had it in the car now for about 2 years and it is still in good condition.
    The oil clings to the filter screen and collects at the bottom and the crankcase ventilation goes back to the intake.
    I drain about 150ml every 5'000km from it.
    The filter can be had from any co-operation or hardware store selling water pumps and filters etc.
ID:	376892   Click image for larger version.
ID:	376893   Click image for larger version.
ID:	376894   Click image for larger version.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
