Marius's Touareg R5 life thread. - Page 118
Page 118 of 151 FirstFirst ... 18 68 93 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 143 ... LastLast
Results 2,341 to 2,360 of 3006
  1. #2341
    Thanked: 616
    Quote Originally Posted by Tracer87ZA View Post
    May I suggest you look into that. Although a sealed unit, they still vent. Though less.
    Thanks for the heads up. Will definitely have to investigate.
  2. #2342
    Thanked: 616
    I was thinking about the tether.
    A rope attached to the one roof brace through the wheel bolt hole on the rim and the attached to a carabena that is attached to the wing nut?
    something like this? Just have to get the length right so it doesn't flap around. Doing it this way allows me to twist the rope a few times to put some xtra tension as well.
    Thoughts? I don't want this tyre through someone's windshield
  3. #2343
    Thanked: 616
    Holy smokes....I have overtaken the Toyota Pictures thread in views....
  4. #2344
    Thanked: 86
    Think you may as well then simply loop a ratchet tie-down through there.
  5. #2345
    Thanked: 616
    Even though it's not a major effort, I'm always looking for a solution that is quick and easy.
    Ek hou nie van sukkel nie
  6. #2346
    Jan 2014
    Thanked: 18
    marius
    you are a man of means. simplest way is to make a 5 prong spindle that is welded with a hole in the middle that your lug nut screws onto. Those spindles will go from the centre down the bolt holes as a way of it not moving.
    or have that welded onto your cross brace and sticking up through the wheel and then bolted down by a couple of wheels nuts.
  7. #2347
    Thanked: 616
    That will involve too much cost and it will be heavy (scratching the roof)
    I want an easy system that even Shalene can use and manage.
  8. #2348
    Thanked: 616
    So, took the controls arms off today again to put the new bushes in.
    About 30 minutes each side to get the arms off
    Had to improvise to get the bushes out - I never had the right tools for the job
    Some pictures of the bolts, tools used and ..... French control arms...
    They are hefty arms. Weigh a ton! No wonder you can tow aircraft with the car.
ID:	368903   Click image for larger version.
ID:	368904   Click image for larger version.
ID:	368905   Click image for larger version.
ID:	368906   Click image for larger version.
ID:	368907   Click image for larger version.
  9. #2349
    Thanked: 616
    new bushes arrived. Pressed them in.
    All buttoned up on both sides in less than an hour.
    Prelim test drive later tonight which has to be followed by alignment.
  10. #2350
    Thanked: 189
    Baie nice!
    Sent from my iPhone
  11. #2351
    Thanked: 28
    Is that VW bushes or Porsche?
    Touareg V10
  12. #2352
    Thanked: 616
    VW bushes. The only suspension bushes that are different on the porsche is the other lower control arm bushing. The touaregs and normal cayennes have a soft hydro bushing. The cayenne turbo has a sturdier rubber bushing (which I fitted a while ago) - it looks like I installed it yesterday and it has done 40'000+ hard kilometers.
    The top control arm bushings (7L0 407 077) I replaced were torn.
    I suspect the previous mechanic didn't tighten them at the resting position.
    The bushings I replaced today still looked fine. I replaced them because of excessive play between the bolts and the inner barrel of the bushing. Again, I suspect a previous repairer didn't tighten the tracking bolts properly.
    I will be sure to mark the tracking bolts once the alignment is done and tighten the bolts properly at home (and inspect that the alignment didn't move)
  13. #2353
    Jan 2014
    Thanked: 18
    ge-impressed
  14. #2354
    Thanked: 616
    old hydro bushes versus cayenne turbo bushes (original VW - 7L0 407 182 E)
    The ones I changed today are the 7L0 407 183 A bushes
  15. #2355
    Thanked: 28
    Any idea on the cost for all the bushes on the top and bottom control arm? I might tackle it this weekend.
    Touareg V10
  16. #2356
    Thanked: 616
    Quote Originally Posted by SpiderGear View Post
    I can't even remember what I paid for these two..... long week so far
    I did order them last week in my defence.
    Best is to phone the dealer with the part numbers. Be sure to get the sway bar bushes as well. They clunk like hell when finished.
  17. #2357
    Thanked: 616
    here is the cayenne bush part number if you want to get a quote for that. It replaces the 7L0 407 182 E bush in the schematic above.
  18. #2358
    Thanked: 28
    Thanks Marius. I will start phoning around.
    Touareg V10
  19. #2359
    Aug 2010
    Thanked: 32
    Me thinks; they should just give you your degree
    Chris.
  20. #2360
    Thanked: 616
    Quote Originally Posted by ChrisLab View Post
    Chris.
    I agree. They give them out in government so why cant I have one?
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
