Marius's Touareg R5 life thread. - Page 117
Page 117 of 151 FirstFirst ... 17 67 92 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 142 ... LastLast
Results 2,321 to 2,340 of 3006
  1. #2321
    Thanked: 188
    Ek dink baie mense het uit jou thread geleer, ek onthou nog die eerste keer toe ek die thread gesien het. Ek het sommer 'n knop in my keel gekry toe ek die goed lees!
    Net so.
    Ironically, the your beetle's failure and this thread gave the rest of us (well, me at least) a lot of confidence in our vehicles. May you resist the itch of a V10 for a few more years and contribute to the body of knowledge on the R5!
    Tyrannosaurus R5 and a second hand British Tata
    Quote Originally Posted by 2beFree View Post
    Jan your signature says it all
  2. #2322
    Thanked: 622
    The confidence in my R5 is keeping the V10 itch at bay.....barely.
    I just can't get myself to get anything other than a touareg again but the new one doesn't offer anything more than my current one apart from slightly better performance and economy. I can buy a lot of fuel for that price.
    I will have to keep this R5 for a while still and maybe get a cayenne IF I manage to get my qualification finished and start earning enough money.
    My boss had a cayenne and that car is just awesome! The interior and the small suspension tweaks makes a HUUUGE difference.
  3. #2323
    Aug 2010
    Thanked: 32
    Quote Originally Posted by JanB View Post
    Net so.
    Hey, what about us poor V6 TDI owners.
    Chris.
  4. #2324
    Thanked: 188
    Quote Originally Posted by ChrisLab View Post
    Chris.
    Reflected glory for you!
  5. #2325
    Dec 2013
    Klapmuts
    Thanked: 23
    Lekker man!
    Jacques
    05 VW R5 Touareg
    03 VW Jetta TDi (platkar)
  6. #2326
    Thanked: 622
    This is a weird way of getting stuck in your driveway
  7. #2327
    Thanked: 28
    I don't see a problem? All I see is a pile of steaks and biltong?
    Touareg V10
  8. #2328
    Thanked: 622
    I have been unhappy with the rebound of the air suspension for a while.
    I have done all bushes except for the lower control arm front bushes which seemed fine when I did the other ones.
    So yesterday afternoon and I jacked up the car and looked for play and found play on that bush.
    So I pulled the lower control arm quickly and surprise surprise the bush is fine.
    Sat back and thought about the play and then it hit me.
    The bolt has play in the barrel of the bush.
    So, I have to order some eccentric bolts from VW - R109 each!
    I'm wondering If I shouldn't order the bushes as well as the bush barrel might be worn. But I suppose doing the bolts is easy. If that doesn't fix it, I will pull the arm again and change the bushes.
    PS : I was very upset that I had to reassemble with those dud components as I need the car tomorrow.
  9. #2329
    Thanked: 622
    So if you feel a loud thud when going over a bump as if the air suspension is rebounding too hard, jack up the wheel and wiggle the wheel while holding at 3 & 9 o'clock positions. Then look at the lower control arm front bush for play.
  10. #2330
    Jan 2014
    Thanked: 18
    Are the bushes rubber or nylon. I remember once getting bushes replaced in situ where the guys injected molten nylon and so saving having to have the whole ball joint replaced. Wish I could find those guys again.
  11. #2331
    Thanked: 622
    Not sure but the balljoint is not serviceable.
    The bushes are rubber and I had the arm out in less than 20 minutes.
    Much easier working with the complete arm on the bench.
  12. #2332
    Thanked: 237
    So what qualification are you working on. You have contributed much to this forum and you seem to be pretty confident swinging a spanner. I am sure you could open a workshop tomorrow in jhb and half this forum would queue up to bring their beetles through to you. I know I would happily bring my tractor through of you were anywhere near midrand. I think the mitsubishi guys would also come through to you as well.
    Stephen
  13. #2333
    Thanked: 622
    Mechanical engineering. I wish I had the capital and guts to start my own workshop.
  14. #2334
    Thanked: 622
  15. #2335
    Thanked: 622
    changed out the eccentric bolts yesterday. The clunk is 90% gone. (the one you get when the wheel crests a bump - feels like the rebound is too aggressive)
    I suspect the bush barrell is also worn due to the movement against the bolt.
    So two new bushes on order.
    schematic courtesy of dad.
    for those that want to DIY
    mark eccentric bushes to the subframe
    jack car to max and lock the suspension by holding the lock button for 15 sec (ignition ON)
    jack up wheel (and remove for access)
    21mm spanners needed for the eccentric bolts, shock bolt and balljoint nut
    remove the shock bolt and two eccentric bolts
    undo balljoint nut and press out the balljoint
    swivel the control arm towards the rear of the car (90 degrees) to have the balljoint clear the cv hub
    now the control arm is out
    press out the bush
    press in new bush
    ala Haynes Manual - reverse the process for installation.
    even though you marked the eccentric bolts, have alignment done.
Name:	General layout.jpg
ID:	368332   Click image for larger version.
  16. #2336
    Thanked: 622
    Prototype 1
ID:	368617   Click image for larger version.
ID:	368618   Click image for larger version.
  17. #2337
    Thanked: 622
    prototype 2
    It clamps so hard I can't move it with brute strength to the point I back off for fear of breaking the roof carrier.
    It sits like the proverbial dog business to a woolly blanket.
    I like it. Easy, simple, and strong.
    I will use a safety tether until I have tested in all conditions.
ID:	368685   Click image for larger version.
ID:	368686   Click image for larger version.
ID:	368687   Click image for larger version.
  18. #2338
    Dec 2014
    Vanderbijlpark
    Thanked: 21
    Dual battery done and dusted. Thanks for all the bits Dad!
    Marius,
    Did you install a breather pipe for the battery?
    Audi A4 B6 1.8T 2002
    VW Touareg R5 2.5TDI 2005 (SWAMBO)
    There is nothing like can't. Only don't want to try.
  19. #2339
    Thanked: 622
  20. #2340
    Dec 2014
    Vanderbijlpark
    Thanked: 21
    May I suggest you look into that. Although a sealed unit, they still vent. Though less.
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
