Marius's Touareg R5 life thread. - Page 116
Page 116 of 151 FirstFirst ... 16 66 91 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 141 ... LastLast
Results 2,301 to 2,320 of 3006
  1. #2301
    Dec 2013
    Klapmuts
    Thanked: 23
    Die Facebook link werk...
    Hoe het jy die ryery met die spaarwiel op die dak gevind? Ek het die naweek so 1000 km rouad trip gedoen (met die wiel op die dak)
    Jacques
    05 VW R5 Touareg
    03 VW Jetta TDi (platkar)
  2. #2302
    Thanked: 618
    Quote Originally Posted by JacBrand View Post
    Slightly higher fuel consumption on the highway.
    Never felt it, never heard it, never thought about it. It was like it wasn't there at all.
    Definitely an easy way to take a full size spare if the interior packing space is needed.
  3. #2303
    Thanked: 618
    I have been having poor reception since I installed the double din. Even though I did the aerial mod, which helped, it was really poor.
    So I bit the bullet finally and drilled a hoke in the roof to fit a powered aerial from a mk3 golf and ran a new aerial wire through the roof to the back of the radio.
    My reception is now outstanding!
  4. #2304
    May 2013
    Thanked: 35
    Neat.
    Is that not going to interfere with your roofrack/sparewheel combo now?
    Current: 2017 Renault Sandero 900cc Turbo Dynamique (Company)
    Ex:
    2005 Volvo XC70 2.5T Geartronic
    SWAMBO: 2012 Honda CRV 2.2 i-DTEC Auto Executive
  5. #2305
    Thanked: 618
    No. I spaced it exactly so it doesnt interfere with the rear door or roof racks or sparewheel.
  6. #2306
    Aug 2010
    Thanked: 32
    Wel done young man.
    Chris.
  7. #2307
    Hillcrest, Malaysia
    Thanked: 1482
    I absolutely hate having to drill holes in my cars.
    I use thru the glass capacitive couple antenna. It uses a super self adhesive tape that will glue an elephant to a marshmallow.
    Nice job there Marius.
    ZS5KAD Yeasu Ft-897D
    2 V8's a V6 and an inline 4
    If youíre incompetent, you canít know youíre incompetent. . . . The skills you need to produce a right answer are exactly the skills you need to recognize what a right answer is.
  8. #2308
    Thanked: 618
    I also hate drilling the car but this is a better option for the touareg. I tried that stick on one with the double din install but the reception was poor. I suspect its the thick windows and glazing of the touareg or perhaps the funny alloys they use.
    For me the aerial on the roof looks standard so I bit the bullet.
    PS : the roof aluminium alloy is helluva thick!
  9. #2309
    Thanked: 189
    The other option is to fit the unit inside the side mirrors. Like the Amaroks etc....
    Sent from my iPhone
  10. #2310
    Thanked: 618
    Running an aerial through the doors the mirrors sounds like an impossible job to me as an after thought.
  11. #2311
    Thanked: 28
    Wat was fout met die reception na jy die double DIN geinstalleer het?
    Touareg V10
  12. #2312
    Thanked: 618
    Quote Originally Posted by SpiderGear View Post
    The factory radio communicates with a diversity box and amplifier switching between different aerials located in the right, left & middle rear window.
    Try as I may I couldn't find a way to get those aerials working with an aftermarket radio.
    In the end I ran a normal run of the mill aerial cable all the way to the back with a simple powered aerial I bought from Midas.
    I have a little causeway bridge on the gravel road about 2km from my house and with the previous aerial mod (with Fakra adapters and all sorts) the reception would be breaking up, where the factory radio was clear.
    Now with the aftermarket aerial, I have perfect signal.
    Murphy's law : The fakra adapters was more effort and more expensive than running the normal aerial cable with normal aerial to the roof.
  13. #2313
    Thanked: 86
    How well do you think a cheap whip antenna concealed under the left front fender would work? The fender is plastic as you know. I'm sure not as well as your solution, but I will not drill a hole in my roof. That said, you did a good job of it. Should be better than the current diversity mess I have.
  14. #2314
    Thanked: 618
    Well, the nice thing about an antenna under the front fender is that it is reversible.
    The bad thing is you have to find a place through the firewall.
  15. #2315
    Thanked: 86
    Any ideas where I should look first?
  16. #2316
    Thanked: 618
  17. #2317
    Thanked: 618
    Problem is that the rain tray is so deep you cant use the brake pedal rubber grommet like most cars.
  18. #2318
    Thanked: 618
    Today, exactly three years ago, I bought the beetle.
    It's been a roller coaster but I have learned a lot. Thanks to everybody for the comments and input so far.
    It's been great.......and it's not over yet!
  19. #2319
    Jan 2014
    Thanked: 18
  20. #2320
    Thanked: 189
    Ek dink baie mense het uit jou thread geleer, ek onthou nog die eerste keer toe ek die thread gesien het. Ek het sommer 'n knop in my keel gekry toe ek die goed lees!
    Sent from my iPhone
  3. Life - II
    By JDeV in forum The 4x4 Pub
  5. VW Touareg
