Pajero 3.2 Starter service
Results 1 to 3 of 3
    Thanked: 838
    Default Pajero 3.2 Starter service
    It was starting a bit slow so I thought I'd remove the starter and give a good clean.
    I came in from the left side of the car. Both through the engine and from underneath.
    I had to remove the autobox dipstick holder to gain access to the top starter bolt.
    There are only two bolts holding it on - 14mm
    The starter feed to the solenoid is a 12mm nut and then a spade connector on the solenoid.
    I dropped it out from underneath the car.
    It was dirty as hell inside.
    A good clean and reassemble has drastically improved the starter spinning speed.
    Starter on the bench pre-disassembly
    Gunk on the armature
    Gunk on the brushes
    The part number for the starter
    The solenoid with plunger
    Looking into the solenoid with plunger removed
    The lever arm that gets moved by the solenoid plunger and engages the starter bendix to the ring gear on the flywheel/flexplate
    Starter bendix. Looks fantastic after 296'000km of use. Mitsubishi uses good materials!
    All cleaned up and ready for reassembly
Name:	2012-05-11 15.10.33.jpg
ID:	145739   Click image for larger version.
Name:	2012-05-11 14.53.43.jpg
ID:	145740   Click image for larger version.
Name:	2012-05-11 14.53.18.jpg
ID:	145741   Click image for larger version.
Name:	2012-05-11 14.42.57.jpg
ID:	145742   Click image for larger version.
Name:	2012-05-11 14.39.41.jpg
ID:	145743   Click image for larger version.
Name:	2012-05-11 14.39.16.jpg
ID:	145744   Click image for larger version.
Name:	2012-05-11 14.38.55.jpg
ID:	145745   Click image for larger version.
Name:	2012-05-11 14.38.37.jpg
Name:	2012-05-11 14.38.25.jpg
    Thanked: 838
    Thanked: 72
    Default Re: Pajero 3.2 Starter service
    Hello,
    Resurrecting an old thread with a question;
    Do you know why or how all that gunk gets in there?
    Andrew
    Andrew to all.
  1. 2001 Pajero coil springs 3.2 DID
    By rcoetz02 in forum Mitsubishi
    Last Post: 2011/01/03, 07:48 AM
  2. Pajero service in Pta - where to?
    By Leatherman in forum Mitsubishi
    Last Post: 2009/09/20, 08:22 PM
  3. Service Intervals?? Pajero 3.5 V6 1999
    By macjohnw in forum Mitsubishi
    Last Post: 2009/09/15, 08:09 PM
  4. Pajero 100 000km service
    By slojo in forum Mitsubishi
    Last Post: 2008/08/08, 11:29 AM
  5. New Pajero
