Useful Mitsubishi Links
Results 1 to 20 of 20
    Thanked: 37
    Default Useful Mitsubishi Links
    Feel free to add - I will keep these consolidated
    Various useful links to articles on the 4x4Community Forum
    External Links
    Videos of some nicely kitted out Mitsu's
    Projects
    Dakar History
    Comments on the web which might help searching for documents
    • "Begbie wrote: They (manuals) are freely available via the web, if you use the right software to find them. I have file sharing software called EMULE, i did a search on pajero and voila - heaps of manuals, and loads of pics and rally movies"
    Carpe Diem Scrotum
    Cape Town Weather and Imagery
    Richards Bay
    Another site with loads of Mitsu tech info and manuals that can be downloaded:
    http://bojo.hopto.org/Auto/Japan/Mitsubishi/
    Gerrit Loubser
    Richards Bay
    Paarl
    Johann Bredell
    Default Reverse light problem
    Hello Simon
    Pajero 3500 gls 1999
    I have been looking for a link to help me with finding the sensor for the reverse light. I looked on the gearbox and found lots of them but witch one is it?
    Ken
    Quote Originally Posted by SimonB View Post
    External Links
    Projects
    Dakar History
    4ePikanini Guest
    Quote Originally Posted by kenlus View Post
    Hello Simon
    Ken
    In my Rebuild I had a look at that switch. - The reverse lights are on page 2 - My quoted post below.
    Quote Originally Posted by 4ePikanini View Post
    Spent last night troubleshooting why my reverse lights weren't working.
    Found the switch underneath the gearbox in 5 minutes as 45 minutes in the FSM yielded no results. grounded the two wires and the lights worked so the switch has to be the culprit.
    I removed the switch with great difficulty
    - my recommendation is to remove the console in the cabin to gain access to the big rubber grommet that feeds the wires from the tranny and transfer case switches. You can then unplug the harnass connector under the radio and push the rubber grommet through.
    The connector plug is just left of the date stamp in the picture below
    You then have enough space to get a 19 ring in there to the reverse switch.
    There is not enough space for the open end of the wrench so you have to use the ring with the wrench pointing to the front of the vehicle away from the switch. The only way to use the ring is to cut the two wires and feed them through as it won't go over the connector. - I'm just using lugs to connect them again.
    ( Ideally a 19mm brake line spanner bent in an S-shape would have been great - or a socket with a handle on it so you can feed the wires through the centre of it - but I can't go grinding my spanner 10o'clock at night now, can I?)
    I then had the switch out and the halfhearted attempt at fixing it by the previous guy was a laugh ( I wish my camera was working ) but I have experience on fixing this switch ( fixed one on the transfer case not so long ago )
    I chipped away at the plastic on top of the switch to expose some extra wire. Clean good with engine degreaser and then brush with soldering flux. After testing the switch and making sure it worked the way it should ( it just creates continuity between the 2 wires coming out of it - can't remember if it's at rest position or pressed in position ) I then soldered on some wires to extend the 2 wires that came out of it. I then used a strong epoxy like builder to cover my solders and strenthen that part of the switch. Also put some shrink sleeve right against the switch on the wires for some extra protection. - I'm very happe with it.
    tested it again to make sure I didn't make a boo boo and all is well.
    Fitted it and my reverse light don't work
    I then spotted the washer I forgot to put in so I'll get back onto it tonight as it was a bit late at that stage and centre console was snoring on the back seat
    Cornwall, UK
    Default Triton 2.5 DI-D - 2007 Service Manual
    Package includes: Service Manual, Technical information manual, Body repair manual.
    Use the "Regular Download" option - to get it free. It is 200MB big.
    http://www.sendspace.com/file/n2ca39
    "We do not quit playing because we grow old, we grow old because we quit playing"
    Oliver Wendall Holmes
    Johan (ZS1JV, M0ZJV)
    2007 JK, CRD (SOLD)
    Dacia Duster Lauréate dCi 110 4x4
    Default Twitter
    Thanks for the cool links!
    By the way, Mitsubishi's Xplore magazine has recently started a Twitter account. Follow us on: XploreMag
    We retweet more cool Mitsusbishi-related links there.
    Cheers,
    XploreEd
    Various workshop manuals for various engines ,fuel systems and gearboxes
    Hope this helps
    http://www.mitsubishi-motors.kiev.ua/info.php?id=20
    Jan 2011
    Secunda
    Colt diff lock engage, don't want to disengage. Even if power to diff lock is shut down. Please help!!!!!
    dorahumphries
    Default Dave James
    I would appreaciate some advice.
    Is there any fundalmental improvement in real terms between the pajero swb 120 kw and the 140 kw.
    Glenwood /C.T
    Default Workshop manuals
    Hi Guys
    I have tried almost every link to get a manual for a colt 2004 2.8td D/C 4x4 or L200 as its other name ( I think )
    Im not the best computor boffon either but when I see all these download here or click here to download I just dont seem to get what I want please help
    Erik
    Pajero 2006 3.2 Glx
    Fortuner 4x4 3.0 D4d 2013
    Jun 2012
    Gillitts
    Quote Originally Posted by Erik View Post
    Hi Guys
    Erik
    Hi Erik
    I have also been trying, if you do succeed please let me know.
    regards
    Thanked: 1009
    For the engine?
    Just google the following
    4m40 pdf manual
    You will find plenty.
    Sent via iPad & Forum Runner
    Glenwood /C.T
    Hi Guys
    Thanks for the info BUT it keeps on telling me error on web page eish
    shall keep trying
    thanks
    Pajero 2006 3.2 Glx
    Glenwood /C.T
    I got it by George I got it
    Now all I need is one for the body steering rack and suspension etc etc etc Hi Brunco do as Marius suggest I had to right click first to save as target then it worked
    Thanks Guys
    Pajero 2006 3.2 Glx
    rustenburg
    Default 4m40 manual
    send me a mail then i can mail u the manual my email is nicoglta@gmail.com
    Hi Guys
    Erik
    Jul 2010
    Trichardt
    Bellville
    Thanked: 12
    Complete Denso fuel system manual for 4m41 and 4d56.
    http://www.newtriton.net/phpbb/viewt...p?f=38&t=18306
    Gabs Botswana
    Thanked: 33
    Default online service and engine manual
    http://faq.out-club.ru/download/paje...1/index_M2.htm
    Found this quite usefull
    Cheers !!
  1. Mitsubishi Offroad Xplorers Club
    By Ralph_Clark in forum Mitsubishi
    Last Post: 2014/08/14, 06:19 PM
  2. Links Directory
    By Dirk in forum The 4x4 Pub
    Last Post: 2009/06/26, 11:08 PM
  3. Mitsubishi Motors East London - The Adventure Begins Event
    By Ralph_Clark in forum Eastern Cape
    Last Post: 2008/07/29, 10:32 AM
  4. Mitsubishi Motors Eastern Cape Training
    By Dirk in forum Calender & Events
    Last Post: 2006/09/21, 09:58 AM
  5. Mitsubishi Offroad Xplorers Training Saturday 30 September
    Last Post: 2006/09/21, 09:53 AM
