How to connect a Mobile Antenna Connector
Results 1 to 1 of 1
    Thanked: 150
    Default How to connect a Mobile Antenna Connector
    I figured this post is long overdue, so here it is, courtesy of Telegartner.
    We use a slightly different connector whereby the braiding is peeled backwards over the cable and the connector is then screwed onto the cable. The only soldering required is right at the tip of the centre pin. Leave sufficient slack so that the cable wire sticks out slightly, solder the connector pin and then trim the excess wire off. Take care not to blob solder on the outer diameter of the centre pin.
    Take care when soldering with Resin-core solder (i.e. the RED Reel, NOT the Black or Green solder reels) that you only solder the centre pin as shown in the PDF file.
    If you have a Digital Multimeter (or other test means), ensure that there is no continuity between the centre pin and the outer casing, but there should be continuity between the outer casing and the body/chassis of the vehicle and also continuity between the centre pin of the connector and the whip of the antenna. Any other meter readings indicating continuity are fault conditions.
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  1. What Cellphone handset to get??
    By Derick in forum The 4x4 Pub
    Last Post: 2011/05/16, 08:22 AM
  2. Replies: 34
    Last Post: 2010/09/23, 10:50 PM
  3. Free mobile GPS software
    By Dirk in forum GPS & Mapping
    Last Post: 2010/01/14, 12:43 PM
